Looking for parts of my '79
04-09-2009, 07:52
Hello All,
I've got a '79 FC-33 w/ Cat 3208 NA. I'm looking for new motor mounts and
replacement LED tail and marker lights. Anyone have any sources and/or part
numbers? Any help would be greatly appreciated.
Thanks,
Lin
04-09-2009, 11:14
Lin - I got rear mounts from Bluebird a while back. Because this is a chassis
part also used in school busses, it is likely they can still supply them.
BB could not supply front mounts. I've found a mount that should work but have
not tried them yet. If I pull of a successful front mount swap I will post the
details.
Changing the rear mounts made a big difference in noise and vibration.
Bob Griesel '84 FC31 WLII WA
--- In WanderlodgeForum@yahoogroups.com, "lin_borkey" wrote:
> Hello All,
> Thanks,
> Lin
04-10-2009, 06:07
Lin,
If you can look at your mounts, they should be a round donut type mount. It's a
pretty standard mount, from what I've learned, so any decent truck parts house
should be able to fix you up. You may also be able to find your lights there as
well. They do have a bunch of light style available.
Good Luck
John
have not tried them yet. If I pull of a successful front mount swap I will post
the details.
> > Hello All,
and replacement LED tail and marker lights. Anyone have any sources and/or part
> > Thanks,
> > Lin
