Cannon plugs
04-11-2009, 13:02
Cannon plugs
Hi Guys
I have a cannon plug with a bad wire in it. It is on the female side. Can
you buy them or would it be better to bypass the wire around the plug. If you
can buy them. Is there a good source.This plug has my parking lights & my 12
volt inside.
Don Spithaler
89 SP 36'
Butler, PA
04-11-2009, 14:12
Cannon plugs
I'd bypass the plug.
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us.
"Host of the Annual Bluebird Quartzsite Rally"
On Sat, Apr 11, 2009 at 6:02 PM, Don Spithaler <"dspithaler@gmail.com"> wrote:
Hi Guys
I have a cannon plug with a bad wire in it. It is on the female side. Can you buy them or would it be better to bypass the wire around the plug. If you can buy them. Is there a good source.This plug has my parking lights & my 12 volt inside.
Don Spithaler
89 SP 36'
Butler, PA
04-11-2009, 15:08
Cannon plugs
Curt    Do you know what makes one wire go bad in a plug of 24 wires?
Don Spithaler
89 SP 36'
Butler, PA
On Sat, Apr 11, 2009 at 10:12 PM, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
Curt Sprenger
Anaheim Hills, CA
Hi Guys
Don Spithaler
89 SP 36'
Butler, PA
04-11-2009, 15:51
Cannon plugs
Heat, vibration, moisture, connect/disconnect, wire end(s)/connectors not the best at initial assemble, bad grounds, stress on the wire bundle or a wire in the bundle, etc., all leading to arching, deterioration and eventually no connection.
Just rewire the one bad wire outside the plugs.
Good luck.
Curt Sprenger
Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
On Sat, Apr 11, 2009 at 8:08 PM, Donald Spithaler <"dspithaler@gmail.com"> wrote:
Don Spithaler
89 SP 36'
Butler, PA
Curt Sprenger
Anaheim Hills, CA
Hi Guys
Don Spithaler
89 SP 36'
Butler, PA
04-12-2009, 06:48
Cannon plugs
Note, too that the cannon plugs are mostly for the manufacturer's
convenience during the initial assembly of the vehicle. They are of
minimal use to the owner -- there's little reason to ever unplug one
other than to look for problems. So, re-wiring a couple of wires
around the plug is not likely to cause an difficulties down the line.
El Sobrante CA
aeonix1@...
> Good luck.
> Curt Sprenger
> Anaheim Hills, CA
04-13-2009, 12:53
Cannon plugs
--- In WanderlodgeForum@yahoogroups.com, "Don Spithaler" wrote:
> Hi Guys
volt inside.
> Don Spithaler
> 89 SP 36'
> Butler, PA
I would like imformation on cannon plugs, if you hear anything. richard 89WB40
04-14-2009, 03:47
Cannon plugs
Have not looked at the cannon plugs we have onour coaches, but usually they can be repaired.
Have you looked intothat?
try MCM electronics to purchase.
Bill 84 FC 35 SB "$quanderlodge"
Terrace, B.C. Canada
Now with a new friend-happy design! Try the new Yahoo! Canada Messenger
04-14-2009, 04:56
Cannon plugs
I'd spray the cannon plugs with one of those water/corrosion resisting products
like Corrosion-X. Disconnect the plug and give the contacts a thorough dose.
Corrosion-X is an aircraft corrosion inhibitor which molecularly binds with a
variety of metals, forming a long lasting barrier. NFI.
David Brady
'02 LXi, NC
-----Original Message-----
Sent: Apr 14, 2009 11:47 AM
Subject: [WanderlodgeForum] Cannon Plugs
