Electric heat
06-07-2005, 06:05
Electric heat
Ok, I am need of some direction. We are in the middle of setting up a
huge sale this weekend and don't have time to spend in a long troubleshooting procedure. We have basically moved into the coach and this morning it was a bit nippy so I tried to turn on the electric heaters. The one in the bathroom worked correctly, however the one in the galley did not. This is a '95 WBDA 4203.... I switched the thermostat over from the "cool" setting to the "heat" setting and could hear the relay under the galley click, but the heater failed to come on. Then I remembered that the front A/C and the galley heater shared a C/B and that the Front A/C master (on the drivers left panel) needed to be on. However, when I turned it on, the compressor for the front A/c came on. I tried switching the thermostat to heat; To off, and all other variations. Even turned the center thermostat to the off position. The front A/C compressor still came on whenever the A/C master was turned on. So as to get some heat in the coach this morning, I turned on the Aquahot and it worked normally. Later in the morning, I tried again and with the front thermostat on either heat or cool, the front compressor still comes on with the front A/C master. Seems like there must be a changeover relay someplace that is stuck. I don't know where it might be and am too busy to chase it right now. I am in hopes that Jeff or Ralph might know exactly where to look. Or tell me that my thinking is completely wrong... Thanks for the help, George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Currently in CA trying to get everything sold!!!! |
06-07-2005, 07:02
Electric heat
George: Sorry, Iam not Jeff or Ralph but, I'll tell you what work's
for me. In our 93 we have a low power light on the a/c thermostat, there is a switch below this that move's left and right. I move this switch to the low side and the a/c compressor will not come on and the heater work's. Don't ask me why. It just work's for me....Bob 93pt Illinois |
06-07-2005, 07:46
Electric heat
You're almost there. Simply turn the A/C Thermostat off on the
middle thermostat in the galley. Then with the center switch turned on on the dash, you should have your heat. That is, if you have a heater in the galley. On my 92, I have electric in the bath and at the front dash only. If that's your case, then turn on left switch on the dash and turn off the thermostat above the driver's seat. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Ok, I am need of some direction. We are in the middle of setting up a > huge sale this weekend and don't have time to spend in a long > troubleshooting procedure. We have basically moved into the coach and > this morning it was a bit nippy so I tried to turn on the electric > heaters. The one in the bathroom worked correctly, however the one in > the galley did not. > > This is a '95 WBDA 4203.... I switched the thermostat over from the > "cool" setting to the "heat" setting and could hear the relay under > the galley click, but the heater failed to come on. Then I remembered > that the front A/C and the galley heater shared a C/B and that the > Front A/C master (on the drivers left panel) needed to be on. > However, when I turned it on, the compressor for the front A/c came > on. I tried switching the thermostat to heat; To off, and all other > variations. Even turned the center thermostat to the off position. > The front A/C compressor still came on whenever the A/C master was > turned on. > > So as to get some heat in the coach this morning, I turned on the > Aquahot and it worked normally. > > Later in the morning, I tried again and with the front thermostat on > either heat or cool, the front compressor still comes on with the > front A/C master. Seems like there must be a changeover relay > someplace that is stuck. I don't know where it might be and am too > busy to chase it right now. I am in hopes that Jeff or Ralph might > know exactly where to look. Or tell me that my thinking is completely > wrong... > > Thanks for the help, > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD Currently in CA trying to get everything sold!!!! |
06-07-2005, 08:40
Electric heat
Hi Ron, & Bob,
Solved part of the problem. Ron was correct in that I needed the "Center master switch" in the on position to get the electric heater to work. So that part does work. And the wife thanks you. I guess I am getting senile and forgetful - I was sure it was the front switch that was needed. I still have the problem that the compressor on the front A/C runs when the front master is turned on. It made no difference on the position of the controls on the front thermostat. The only thing the front thermostat seems to control is the blower for the front A/C. I can control the speed of the blower or it works in auto. The blower runs only when cool is selected on the right selector switch. The power switch on the thermostat will turn the blower on or off but has no effect on the compressor. The Front A/C master is the only thing that will turn the compressor off. Again, I am figuring it is a stuck relay. Any ideas as to where it is, if that is the problem. BTW, I do not have a low power light on the thermostats. There are four controls. Fan speed, vertical operation, (lo, med, hi, and auto) on the left side; Power (on and off) a slide switch at the lower middle; Mode switch, vertical operation, (Cool, fan, fan, & gas heat) on the right side; and the temperature control across the top. With all the variations BB has used over the years, I know it can be difficult to identify the equipment sometimes. I hope this helps someone who is more knowledgeable than I. (which isn't difficult) George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Currently trying to bale out of CA. ronmarabito2002 wrote: > You're almost there. Simply turn the A/C Thermostat off on the > middle thermostat in the galley. Then with the center switch turned > on on the dash, you should have your heat. That is, if you have a > heater in the galley. On my 92, I have electric in the bath and at > the front dash only. If that's your case, then turn on left switch > on the dash and turn off the thermostat above the driver's seat. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator > > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > wrote: > >>Ok, I am need of some direction. We are in the middle of setting > > up a > >>huge sale this weekend and don't have time to spend in a long >>troubleshooting procedure. We have basically moved into the coach > > and > >>this morning it was a bit nippy so I tried to turn on the electric >>heaters. The one in the bathroom worked correctly, however the > > one in > >>the galley did not. >> >>This is a '95 WBDA 4203.... I switched the thermostat over from > > the > >>"cool" setting to the "heat" setting and could hear the relay > > under > >>the galley click, but the heater failed to come on. Then I > > remembered > >>that the front A/C and the galley heater shared a C/B and that the >>Front A/C master (on the drivers left panel) needed to be on. >>However, when I turned it on, the compressor for the front A/c > > came > >>on. I tried switching the thermostat to heat; To off, and all > > other > >>variations. Even turned the center thermostat to the off > > position. > >>The front A/C compressor still came on whenever the A/C master was >>turned on. >> >>So as to get some heat in the coach this morning, I turned on the >>Aquahot and it worked normally. >> >>Later in the morning, I tried again and with the front thermostat > > on > >>either heat or cool, the front compressor still comes on with the >>front A/C master. Seems like there must be a changeover relay >>someplace that is stuck. I don't know where it might be and am > > too > >>busy to chase it right now. I am in hopes that Jeff or Ralph > > might > >>know exactly where to look. Or tell me that my thinking is > > completely > >>wrong... >> >>Thanks for the help, >> >>George Lowry >>'95 WBDA 4203 & GM 4106 (for sale) >>Spearfish, SD Currently in CA trying to get everything sold!!!! > > > > > > > > > Yahoo! Groups Links > > > > > > > > > |
