Valve stem extenders??
06-07-2005, 13:56
The valve stem on my inside dualie is not accessible by most tire
inflators at gas stations or truck stops. I have done some research and have found several options to extend the valve stem so it can be reached by a regular inflator. What is the risk of leaving the extender on permanently vs. just using the extender to inflate the tire? Also if I leave the extender on, does anyone have experience with the rubber inserts that hold extenders in the round hole in the wheel? Steve Meach 84FC35 Paw Paw, MI |
06-07-2005, 14:10
Steve,
I've used the extender and rubber inserts for several years...always there and no problems at all. Curt Sprenger â87PT38, Anaheim, Calif. SFMEACH wrote: > The valve stem on my inside dualie is not accessible by most tire > inflators at gas stations or truck stops. I have done some research > and have found several options to extend the valve stem so it can be > reached by a regular inflator. What is the risk of leaving the > extender on permanently vs. just using the extender to inflate the > tire? Also if I leave the extender on, does anyone have experience > with the rubber inserts that hold extenders in the round hole in the > wheel? > > Steve Meach > 84FC35 > Paw Paw, MI |
06-07-2005, 14:18
From: "Curt Sprenger" To: Sent: Tuesday, June 07, 2005 9:10 PM Subject: Re: [WanderlodgeForum] Valve stem extenders?? That is the same kind I use made by Good Year Bob Loomas 85 PT 36 > Steve, > I've used the extender and rubber inserts for several years...always > there and no problems at all. > > Curt Sprenger â87PT38, Anaheim, Calif. > > > > > SFMEACH wrote: > >> The valve stem on my inside dualie is not accessible by most tire >> inflators at gas stations or truck stops. I have done some research >> and have found several options to extend the valve stem so it can be >> reached by a regular inflator. What is the risk of leaving the >> extender on permanently vs. just using the extender to inflate the >> tire? Also if I leave the extender on, does anyone have experience >> with the rubber inserts that hold extenders in the round hole in the >> wheel? >> >> Steve Meach >> 84FC35 >> Paw Paw, MI > > > > > > > Yahoo! Groups Links > > > > > > > > > |
06-07-2005, 15:54
I jumped on the Crossfire option to make monitoring and filling of
rear tires easy.... Blowouts and leaks.......... Crossfire employs a safety feature that automatically isolates the "good" tire in the event of a blowout. When a blowout occurs, the internal safety valve closes immediately with only a slight loss of pressure to the "good" tire. In slow leak situations, the valve isolates both tires after a pressure drop of approximately 10 P.S.I. See below website for more info and the best price I have seen. I paid $68 each including install. http://www.wholesale4all.com/crossfire.htm Dave Beatty 83 FC35SB (BirdCage) Federal Way, Wa --- In WanderlodgeForum@yahoogroups.com, bobloomas wrote: ----- Original Message ----- From: "Curt Sprenger" To: Sent: Tuesday, June 07, 2005 9:10 PM Subject: Re: [WanderlodgeForum] Valve stem extenders?? That is the same kind I use made by Good Year Bob Loomas 85 PT 36 Steve, I've used the extender and rubber inserts for several years...always there and no problems at all. Curt Sprenger `87PT38, Anaheim, Calif. SFMEACH wrote: The valve stem on my inside dualie is not accessible by most tire inflators at gas stations or truck stops. I have done some research and have found several options to extend the valve stem so it can be reached by a regular inflator. What is the risk of leaving the extender on permanently vs. just using the extender to inflate the tire? Also if I leave the extender on, does anyone have experience with the rubber inserts that hold extenders in the round hole in the wheel? Steve Meach 84FC35 Paw Paw, MI |
06-07-2005, 22:57
Hi Steve,
I could never reach the inside dual either. The crossfire system seems to be the way to go (as others have said before me) You purchase a unit with a pre-set pressure calibration for around $60 each. If you avoid one blowout, its paid for itself many times over. The small rubber inserts in each valve adapter seem to be leak free. I have not had to add any air since installing them 9 months ago. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "SFMEACH" <sfmeach@y...> wrote: > The valve stem on my inside dualie is not accessible by most tire > inflators at gas stations or truck stops. I have done some research > and have found several options to extend the valve stem so it can be > reached by a regular inflator. What is the risk of leaving the > extender on permanently vs. just using the extender to inflate the > tire? Also if I leave the extender on, does anyone have experience > with the rubber inserts that hold extenders in the round hole in the > wheel? > > Steve Meach > 84FC35 > Paw Paw, MI |
06-08-2005, 02:37
Myers supply has it all, Good website http://myerstiresupply.com
Go to shop on line then to products N to Z. All valve extensions and accessories are listed under V Another site that has more than I need to know. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "SFMEACH" <sfmeach@y...> wrote: > The valve stem on my inside dualie is not accessible by most tire > inflators at gas stations or truck stops. I have done some research > and have found several options to extend the valve stem so it can be > reached by a regular inflator. What is the risk of leaving the > extender on permanently vs. just using the extender to inflate the > tire? Also if I leave the extender on, does anyone have experience > with the rubber inserts that hold extenders in the round hole in the > wheel? > > Steve Meach > 84FC35 > Paw Paw, MI |
06-08-2005, 04:14
Steve,
I use an extender and the rubber insert for stabilizing it in the wheel. I also added the Double Seal caps to make checking pressures faster and easier. I have had no problems so far. - Rick 87FC35 Rochester, MN --- In WanderlodgeForum@yahoogroups.com, bobloomas > > ----- Original Message ----- > From: "Curt Sprenger" > To: > Sent: Tuesday, June 07, 2005 9:10 PM > Subject: Re: [WanderlodgeForum] Valve stem extenders?? > > That is the same kind I use made by Good Year > Bob Loomas 85 PT 36 > > > > Steve, > > I've used the extender and rubber inserts for several years...always > > there and no problems at all. > > > > Curt Sprenger `87PT38, Anaheim, Calif. > > > > > > > > > > SFMEACH wrote: > > > >> The valve stem on my inside dualie is not accessible by most tire > >> inflators at gas stations or truck stops. I have done some research > >> and have found several options to extend the valve stem so it can be > >> reached by a regular inflator. What is the risk of leaving the > >> extender on permanently vs. just using the extender to inflate the > >> tire? Also if I leave the extender on, does anyone have experience > >> with the rubber inserts that hold extenders in the round hole in the > >> wheel? > >> > >> Steve Meach > >> 84FC35 > >> Paw Paw, MI > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > |
06-08-2005, 04:50
Steve:
Got the furnace motor, should be working today? I use the valve extenders that make it just to the inside edge of the outer wheel, and be sure they have a hex on each end so you can tighten with a wrench, leave them there. Good ones work perfectly. The rubber plug is also nice, Alcoa makes some, you will need slightly longer extenders then. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "SFMEACH" <sfmeach@y...> wrote: > The valve stem on my inside dualie is not accessible by most tire > inflators at gas stations or truck stops. I have done some research > and have found several options to extend the valve stem so it can be > reached by a regular inflator. What is the risk of leaving the > extender on permanently vs. just using the extender to inflate the > tire? Also if I leave the extender on, does anyone have experience > with the rubber inserts that hold extenders in the round hole in the > wheel? > > Steve Meach > 84FC35 > Paw Paw, MI |
06-08-2005, 11:24
The longer the extention the more centrifical force and wiggle,
which could possibly lead to valve stem or seal fatigue. For now no extenders, Just a screw on cap with the ability to check the air pressure. I use a straight shank air chuck and a straight air pressure gage. But you do need to bend over and peak into that hole in the rim for the inner dual. With extenders, the stem could possibly be about eight or more inches long. I have no experience with the black plug that looks like a hocky puck. Bill 88FC,My old hocky knees and back would like to try the blackplug --- In WanderlodgeForum@yahoogroups.com, "Rick B" > Steve, > > I use an extender and the rubber insert for stabilizing it in the > wheel. I also added the Double Seal caps to make checking pressures > faster and easier. I have had no problems so far. > > - Rick > 87FC35 > Rochester, MN > > --- In WanderlodgeForum@yahoogroups.com, bobloomas > > > > ----- Original Message ----- > > From: "Curt Sprenger" > > To: > > Sent: Tuesday, June 07, 2005 9:10 PM > > Subject: Re: [WanderlodgeForum] Valve stem extenders?? > > > > That is the same kind I use made by Good Year > > Bob Loomas 85 PT 36 > > > > > > > Steve, > > > I've used the extender and rubber inserts for several years...always > > > there and no problems at all. > > > > > > Curt Sprenger `87PT38, Anaheim, Calif. > > > > > > > > > > > > > > > SFMEACH wrote: > > > > > >> The valve stem on my inside dualie is not accessible by most tire > > >> inflators at gas stations or truck stops. I have done some research > > >> and have found several options to extend the valve stem so it can be > > >> reached by a regular inflator. What is the risk of leaving the > > >> extender on permanently vs. just using the extender to inflate the > > >> tire? Also if I leave the extender on, does anyone have experience > > >> with the rubber inserts that hold extenders in the round hole in the > > >> wheel? > > >> > > >> Steve Meach > > >> 84FC35 > > >> Paw Paw, MI > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > |
