Park Brake Air Valve
04-21-2009, 06:57
Our bird is in storage,
So does anyone have the part number for the Push / Pull park spring brake valve??? This is one of the parts I would like to replace, before our next trip. Bill 88 FC Michigan |
04-21-2009, 07:08
04-21-2009, 07:22
Bill:
Try B-W 289954 http://www.wbparts.com/rfq/2530-01-503-7903.html Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 06:57 PM 4/21/2009 +0000, you wrote: >Our bird is in storage, >So does anyone have the part number for the Push / Pull park spring brake >valve??? >This is one of the parts I would like to replace, before our next trip. > >Bill 88 FC Michigan > > |
04-21-2009, 07:24
04-21-2009, 09:30
Mine has been problematical for some time, so I just ordered a reman PP-1 from
http://www.anythingtruck.com - $31.50+11.48 shipping. Leroy, there is a line on the exhaust port. I have not tried to trace where it goes, do you know? I assume it is to keep noise down, but blockage in that line would certainly make operation problematical. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 4/21/2009 at 12:24 PM Leroy Eckert wrote: >Bill, on my coach the push /pull control valve assembly is a Bendix PP-1, >30PSI. >Try http://www.anythingtruck.com. Remans available. My book shows BB number for >what it's worth is 0900266. I can send you a photo of the drawing if you >like.. >Leroy Eckert >1990 WB-40 Smoke N Mirrors >Dahlonega, GA >Royale Conversion > >--- On Tue, 4/21/09, pattypape > >From: pattypape >Subject: [WanderlodgeForum] Park Brake Air Valve >To: WanderlodgeForum@yahoogroups.com >Date: Tuesday, April 21, 2009, 2:57 PM > > > > > > > > > > > > > > > > > > Our bird is in storage, > >So does anyone have the part number for the Push / Pull park spring brake >valve??? > >This is one of the parts I would like to replace, before our next trip. > > > >Bill 88 FC Michigan |
04-21-2009, 13:07
Thanks for the inputs, Leroy has the BB #0900266 & Ralph has the Bendix #
289954 This leads to several available, Bendix tech support calls it a 289954 N, (N) for new number, maybe a revision ?? So, I think I will take Ernie's advise and wait until I can remove it and match it , I need to find out if the plumbing is copper or plastic. I do not want to re-plumb in the tight space. Thanks again, Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Bill, on my coach the push /pull control valve assembly is a Bendix PP-1, 30PSI. > Try http://www.anythingtruck.com. Remans available. My book shows BB number for what it's worth is 0900266. I can send you a photo of the drawing if you like.. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Tue, 4/21/09, pattypape > > From: pattypape > Subject: [WanderlodgeForum] Park Brake Air Valve > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, April 21, 2009, 2:57 PM > > > > > > > > > > > > > > > > > > Our bird is in storage, > > So does anyone have the part number for the Push / Pull park spring brake valve??? > > This is one of the parts I would like to replace, before our next trip. > > > > Bill 88 FC Michigan > |
04-21-2009, 15:44
Hopefully yours will have the paper band around it with all of the numbers. I
have mine sitting in front of me, and it reads Bendix 289954 PP-1 30 P.S.I. Bendix has a page on their site that indicates just about everything was renumbered in 2007, mostly by adding a letter or two. See http://www.bendixvrc.com/itemDisplay.asp...entID=4572 for pictures and diagrams. On 4/22/2009 at 1:07 AM pattypape wrote: >Thanks for the inputs, Leroy has the BB #0900266 & Ralph has the Bendix ># 289954 >This leads to several available, Bendix tech support calls it a 289954 >N, >(N) for new number, maybe a revision ?? >So, I think I will take Ernie's advise and wait until >I can remove it and match it , >I need to find out if the plumbing is copper or plastic. >I do not want to re-plumb in the tight space. >Thanks again, > >Bill 88 FC Michigan > >--- In WanderlodgeForum@yahoogroups.com, Leroy Eckert >wrote: >> >> Bill, on my coach the push /pull control valve assembly is a Bendix >PP-1, 30PSI. >> Try http://www.anythingtruck.com. Remans available. My book shows BB number for >what it's worth is 0900266. I can send you a photo of the drawing if you >like.. >> Leroy Eckert >> 1990 WB-40 Smoke N Mirrors >> Dahlonega, GA >> Royale Conversion >> >> --- On Tue, 4/21/09, pattypape >> >> From: pattypape >> Subject: [WanderlodgeForum] Park Brake Air Valve >> To: WanderlodgeForum@yahoogroups.com >> Date: Tuesday, April 21, 2009, 2:57 PM >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> Our bird is in storage, >> >> So does anyone have the part number for the Push / Pull park spring >brake valve??? >> >> This is one of the parts I would like to replace, before our next trip. >> >> >> >> Bill 88 FC Michigan >> > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
04-21-2009, 22:58
04-22-2009, 00:10
Leroy/ Don:
If you slide under the drivers side front bumper area and look up there should be a small hose that is open ended and that will be the exhaust from the PP-1 valve. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 03:58 AM 4/22/2009 -0700, you wrote: Don, I do not know where the |
04-22-2009, 00:44
