Genny cooling issues
04-30-2009, 08:51
Hi Everybody -
Ernie and all - Thanks on the pointers on the Chrysler power seat controls. Found one, and after a little plastic modification it fit and works perfectly. Now we can move the co-pilot's seat again!
This one's a little more critical. Late last week we had the generator worked on after it completely stopped producing power - its rotor bearing was shot and the stator and rotor were about to start arcing due to insulation wear. Had them "washed, baked and dipped," and $1700 later are now getting plenty of power. However, it seemed to be overheating still, as it did on last year's long trip. We have a 1986 PT-40 with the side-mounted radiator and the Kohler / Yanmar12.5K generator. So I've pulled the radiator and
noted that the fan wasn't getting any current from the generator. I bypassed the feed and found that the fan blades were binding on the housing. I've now got the binding fixed, so it will rotate freely - but two things still baffle me:
1. Is there a circuit breaker or fuse somewhere on the power feed to the fan that could have blown because the fan blades were stuck? Any idea of where to look for this?
2. Have noted that the fan was installed so that the airflow is from outside to inside - pulling air through the radiator and exhausting it out through the cage and to the center of the coach. Is this normal? Functional? Flipping the fan blade doesn't help - it's got scooped fins and only collects air in one direction. Thoughts? The guys who repaired the genny suggested I get a 12V radiator fan at a local auto parts store, but then I'm faced with having that switch on when the genny's
running.
Thanks!
Greg Young
86 PT-40 Bluefire
itching to get on the road.
Each time you judge yourself you break your heart.
-Kirpal Venanji
04-30-2009, 09:00
Hi Greg:
Open the gen set slide and on the left side of the control box see if there
is a switch. This is not the start stop or preheat switch. Some of the
Yammar sets have a switch that cuts the cooling fan off.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 01:51 PM 4/30/2009 -0700, you wrote:
>Hi Everybody -
>pulled the radiator and noted that the fan wasn't getting any current from
>genny's running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
04-30-2009, 09:19
Hey Ralph - Thanks for the pointer. No such switch on my control box - there are three wiring harnesses (one on the back leading to the coach and two on the tront leading to the genny), one 10A bus fuse (which is still good) and the start/stop and preheat switches. That's all.
Thanks!
Greg
86 PT-40
Escondido CA
To:
WanderlodgeForum@yahoogroups.com
Sent: Thursday, April 30, 2009 2:00:36 PM
Subject: Re: [WanderlodgeForum] Genny cooling issues
Hi Greg:
Safe travels,
Duncan, Oklahoma
>Hi Everybody -
>genny's running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
04-30-2009, 09:20
Greg, there are a few elecrical components on the inside wall that you can see when you run the gen. tray out. and there is also at least one fuse on the controll box on top of the generator, butI think thats ones for the 12 volt generator starter circuit. I would check out the solenoids and the electric box that I mentioned on the inside wall.
Also with the generator tray out if you crawl under the coach you will see in the generator encloshure area above where the generator sits when the tray is in, there are 2, 12volt blowers and some duct tubing, these help to remove hot air and should come on when the generator starts. Mine weren't working soI went to a junk yard and got a couple blowers out of a couple late 70s model Dodge pickups to replace mine. You could use any 12 volt blower that was about the rite size. The one'sI took were easy to pull as they were high on the fire wall andI just had to pull a few screws and a wire conector to remove them. If you end up replacing those motors make shurebefore youmount and wirethem up that the rotation is correct so that both fans are drawing air into the blower inlet.
Wayne
To: Wanderlodge Forum
Sent: Thursday, April 30, 2009 3:51:35 PM
Subject: [WanderlodgeForum] Genny cooling issues
Hi Everybody -
This one's a little more critical. Late last week we had the generator worked on after it completely stopped producing power - its rotor bearing was shot and the stator and rotor were about to start arcing due to insulation wear. Had them "washed, baked and dipped," and $1700 later are now getting plenty of power. However, it seemed to be overheating still, as it did on last year's long trip. We have a 1986 PT-40 with the side-mounted radiator and the Kohler / Yanmar12.5K generator. So I've pulled the radiator and noted that the fan wasn't getting any current from the generator. I
2. Have noted that the fan was installed so that the airflow is from outside to inside - pulling air through the radiator and exhausting it out through the cage and to the center of the coach. Is this normal? Functional? Flipping the fan blade doesn't help - it's got scooped fins and only collects air in one direction. Thoughts? The guys who repaired the genny suggested I get a 12V radiator fan at a local auto parts store, but then I'm faced with having that switch on when the genny's running..
Thanks!
Greg Young
86 PT-40 Bluefire
itching
to get on the road.
-Kirpal Venanji
04-30-2009, 09:41
Thanks Wayne - I've seen the blowers and wondered what they were for. I will check to see if they're operating.
I infer from your statement that the airflow on the radiator fan is intentional - that it's supposed to pull air in across the radiator and exhaust into the genny compartment, then blown down and out by these blowers? (Pretty convoluted - but I'm not a thermal or any other kind of engineer...)
Thanks again!
Greg
Sent: Thursday, April 30, 2009 2:20:56 PM
Wayne
Hi Everybody -
Thanks!
Greg Young
86 PT-40 Bluefire
itching
to get on the road.
-Kirpal Venanji
04-30-2009, 09:45
Ok:
The power to the fan motor come directly from L1/L2/LO. these points are
located behind the vented plate on the back side of the Kohler gen
housing and are on isolated studs. Were they wired back properly? The
motor can be configured as 100VAC or 220 vac, double check the way the
motor is wired then check the wiring from the motor to the isolated
studs. You can see those connections in your gen set manual on the 2 line
wire diagram.
Safe travels,
Duncan, Oklahoma
Thanks!
Greg
86 PT-40
Escondido CA
Hi Greg:
there
Safe travels,
Duncan, Oklahoma
>Hi Everybody -
generator
bearing
$1700 later are
still,
from
rotate
of
it out
guys
auto
>genny's running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
Safe travels,
Duncan, Oklahoma
04-30-2009, 14:58
WhenI replaced my 2 blowers Ikept theblower housings above the generator but pulled the electric motors out of themand then put the junk yard motors back into them, thats why it's important to make shure they rotate the correct direction tocausethe air to flow out the duct pipes.
Good Luck
Wayne
Sent: Thursday, April 30, 2009 4:41:47 PM
Thanks again!
Greg
Wayne
Hi Everybody -
2. Have noted that the fan was installed so that the airflow is from outside to inside - pulling air through the radiator and exhausting it out through the cage and to the center of the coach. Is this normal? Functional? Flipping the fan blade doesn't help - it's got scooped fins and only collects air in one direction. Thoughts? The guys who repaired the genny suggested I get a 12V radiator fan at a local auto parts store, but then I'm faced with having that switch on when the genny's running...
Thanks!
Greg Young
86 PT-40 Bluefire
itching
to get on the road.
-Kirpal Venanji
05-02-2009, 11:51
Hi - Update on this project...
In our case the fan was wired into the breaker box on the side of the genny compartment. Someone (perhaps the shop that repaired the genny) had wired it into L1/L2, which since it's a 110V unit wasn't working. I switched the white lead to L0 and it's working fine now. There's a little more vibration than I'd like on the fan, so will be trying to adjust that. And as Wayne pointed out, one of the two blowers at the back top of the compartment was shot - the squirrel cage was shreded and detached from the motor. But the other's still working its little rodent heart out. I'll be replacing the dead one shortly. Ran the genny with all three cruise-Air units running (about 55A total load on both legs) and it peaked at a little
over 190 degrees water temp after about an hour. This was with the radiator shroud off and in the sunlight, but only 75 degree ambient temperature. We'll be in 110 degrees later this year and will need to make this work better. Hopefully the blower and the shroud replaced to improve airflow will give us the additional headroom we need. But always appreciate suggestions!
This is fun! I'm no gearhead - my college degree was in English & Philosophy. But I love learning new skills, and it is such a joy to have so much knowledge and willingness to share it available from you all!
We would make it to one of the BB rallys, but are a little afraid that we would be embarrassed by all of your beautiful rigs. We don't go for the classic polished look of a machine that just came off the showroom floor... But we are very concerned about keeping it running and functional. However, we
are slowing decorating Bluefire in Burner style - adding animated elwire on the outside and various fabrics inside, to go with the 15'x30' projection screen gear we carry on top along with our 16 foot tall Saguaro cactus.
With all this, we should be on the road east by Monday. First stop Phoenix and then on to Toast, an event on the AZ/NM border. Will post our story on our website (www.52weekburn.org) and will let you know when it's been update. It's empty right now.
Thanks again for all your help!
Greg & Barbara Young (AKA Smoke Blower and Luscious to our Burner friends)
1986 PT-40 Bluefire
About to leave home base in Escondido, CA
-Kirpal Venanji
Sent: Thursday, April 30, 2009 2:45:59 PM
issues
Ok:
wire diagram.
Safe travels,
Duncan, Oklahoma
Thanks!
Greg
86 PT-40
Escondido CA
Hi Greg:
there
Safe travels,
Duncan, Oklahoma
>Hi Everybody -
generator
bearing
$1700 later are
still,
from
rotate
of
it out
guys
auto
>genny's running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
Safe travels,
Duncan, Oklahoma
05-02-2009, 11:57
Greg- come to one of our Lone Star rallies. Brenda and I have a 26 year old coach. Mechanically great- she needs paint. Don't care, couldn't afford paint- just can afford diesel. We have lots of coaches that are not showroom new.
83PT40
Wanderlodge
Date: Saturday, May 2, 2009, 6:51 PM
In our case the fan was wired into the breaker box on the side of the genny compartment. Someone (perhaps the shop that repaired the genny) had wired it into L1/L2, which since it's a 110V unit wasn't working. I switched the white lead to L0 and it's working fine now. There's a little more vibration than I'd like on the fan, so will be trying to adjust that. And as Wayne pointed out, one of the two blowers at the back top of the compartment was shot - the squirrel cage was shreded and detached from the motor. But the other's still working its little rodent heart out. I'll be replacing the dead one shortly. Ran the genny with all three cruise-Air units running (about 55A total load on both legs) and it peaked at a little over 190 degrees water temp after about an hour. This was with the
We would make it to one of the BB rallys, but are a little afraid that we would be embarrassed by all of your beautiful rigs. We don't go for the classic polished look of a machine that just came off the showroom floor... But we are very concerned about keeping it running and functional. However, we are slowing decorating Bluefire in Burner style - adding animated elwire
With all this, we should be on the road east by Monday. First stop Phoenix and then on to Toast, an event on the AZ/NM border. Will post our story on our website (www.52weekburn. org) and will let you know when it's been update. It's empty right now.
1986 PT-40 Bluefire
-Kirpal Venanji
Ok:
The power to the fan motor come directly from L1/L2/LO. these points are located behind the vented plate on the back side of the Kohler gen housing and are on isolated studs. Were they wired back properly? The motor can be configured as 100VAC or 220 vac, double check the way the motor is wired then check the wiring from the motor to the isolated studs. You can see those connections in your gen set manual on the 2 line wire diagram.
Safe travels,
Duncan, Oklahoma
Thanks!
Greg
86 PT-40
Escondido CA
Hi Greg:
Safe travels,
84FC35 "Ruff
Diamond"
Duncan, Oklahoma
>Hi Everybody -
from
>genny's
running.
>Thanks!
>Greg Young
>86 PT-40 Bluefire
Safe travels,
Duncan, Oklahoma
05-02-2009, 15:27
--- In WanderlodgeForum@yahoogroups.com, Greg Young wrote:
........decorating Bluefire in Burner style ............to our Burner friends)
> 1986 PT-40 Bluefire
Greg, please forgive my un-coolness, but, what's a burner?
<!--[if gte mso 9]>
Normal
0
\/\/\…Fred
__________________
Fred & Wendy Bellows
Queen Creek, AZ (so.east Phx)
'90 SP36
"Maunder Maximum"
photos of coach
and upgrades
current location
