Fwd: Re: Street-side slobber tube leaking oil and coolant
05-04-2009, 09:49
--- In DetroitDiesel@yahoogroups.com, "evansengine"
--- In DetroitDiesel@yahoogroups.com, "trudylundgren" > Coolant out the air box drain tube would probably be leaking liner o-rings. The 92 series is a wet liner engine and there are 2 o-rings just above the air box area to seal in the coolant around the top of the liner. Usually fail due to overheat. > > > --- End forwarded message --- |
05-04-2009, 09:52
