Batteries not charging-both engine and coach
05-04-2009, 18:02
My batteries wont charge after I found them discharged.grand kids knocked
shorepower plug out. I pluged it back in and a couple of days later they are still dead. I have the diagrams for the chargeing circuit. There are four bosch relays in the circuit to allow the current to the buss and then to the battery bay. One of the wires that goes to the coil of one of the relays goes to the front elec panel.What else is neccesary to charge the batterys.relay or whatever.I have been working on this for two weeks with no results. Anyone have ideas or knowledge of this circuit please advise? thanks in advance Ed Gardels 89SP Arlington Tx |
05-05-2009, 03:43
Ed,
Some chargers need at least some charge to get started. I have had to put a small trickle charger on the boat to get the batteries up enough to turn on the main charger. The protection circuits in modern chargers need some voltage to insure that they are connected properly.
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ed Gardels Sent: Tuesday, May 05, 2009 1:03 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Batteries not charging-both engine and coach My batteries wont charge after I found them discharged.grand kids knocked shorepower plug out. I pluged it back in and a couple of days later they are still dead. I have the diagrams for the chargeing circuit. There are four bosch relays in the circuit to allow the current to the buss and then to the battery bay. One of the wires that goes to the coil of one of the relays goes to the front elec panel.What else is neccesary to charge the batterys.relay or whatever.I have been working on this for two weeks with no results. Anyone have ideas or knowledge of this circuit please advise? thanks in advance Ed Gardels 89SP Arlington Tx |
05-05-2009, 05:01
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler"
>Thanks for the response, Chuck. Actully i tried that a couple of weeks ago, but the chargers didnt keep up. Its the first time that the engine batteries went down too. I think that a clue to my problem, since it deals with both seperate banks of batteries. I have also tested the battery isolator. I have exausted my ideas. Thanks Ed Gardels 89SP Arlington Tx > Ed, > > Some chargers need at least some charge to get started. I have had to put a > small trickle charger on the boat to get the batteries up enough to turn on > the main charger. The protection circuits in modern chargers need some > voltage to insure that they are connected properly. > > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ed Gardels > Sent: Tuesday, May 05, 2009 1:03 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Batteries not charging-both engine and coach > > > > > > My batteries wont charge after I found them discharged.grand kids knocked > shorepower plug out. I pluged it back in and a couple of days later they are > still dead. I have the diagrams for the chargeing circuit. There are four > bosch relays in the circuit to allow the current to the buss and then to the > battery bay. One of the wires that goes to the coil of one of the relays > goes to the front elec panel.What else is neccesary to charge the > batterys.relay or whatever.I have been working on this for two weeks with no > results. > Anyone have ideas or knowledge of this circuit please advise? > thanks in advance > Ed Gardels 89SP > Arlington Tx > |
05-05-2009, 05:49
How long was the coach 'off power'? It might be that the batteries were discharged to a level where they are beyondresuscitation.
It is also possible that the batteries are so low that there isn't enough power to trip the relay. I think someone said it takes a minimum of 10.8 volts. (If you're below 10.8 volts, see he first paragraph.) Finally, try putting a portable charger on the engine batteries (or the house batteries) to get them up about 11 volts so the relays will operate. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On May 4, 2009, at 11:02 PM, Ed Gardels wrote:
05-05-2009, 06:12
Hi Ed:
Just a curious question to start; Have you checked the output dc voltage from your chargers? they should be reading 14.1 or so dc volts at the source. If only reading 12.3 vdc then the chargers have taken a hike on you. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 05:01 PM 5/5/2009 +0000, you wrote: >--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > >Thanks for the response, Chuck. Actully i tried that a couple of weeks > ago, but the chargers didnt keep up. Its the first time that the engine > batteries went down too. I think that a clue to my problem, since it > deals with both seperate banks of batteries. I have also tested the > battery isolator. I have exausted my ideas. > Thanks > Ed Gardels 89SP > Arlington Tx > > Ed, > > |
05-05-2009, 10:37
Ed,
I'm not too far away if you are not comfortable checking this out. Pete may be right if the batteries were taken to zero or are fairly old they may be beyond recovery. We can be optimistic. I have forgot to turn off both battery switches and discharged my Trojans twice and they have come back. I have a little over Six years on them and just had them checked by the dealer and he said there was no reason to replace them yet.
- Chuck Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ed Gardels Sent: Tuesday, May 05, 2009 12:02 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Batteries not charging-both engine and coach --- In "WanderlodgeForum%40yahoogroups.com", "Chuck Wheeler" >Thanks for the response, Chuck. Actully i tried that a couple of weeks ago, but the chargers didnt keep up. Its the first time that the engine batteries went down too. I think that a clue to my problem, since it deals with both seperate banks of batteries. I have also tested the battery isolator. I have exausted my ideas. Thanks Ed Gardels 89SP Arlington Tx > Ed, > > Some chargers need at least some charge to get started. I have had to put a > small trickle charger on the boat to get the batteries up enough to turn on > the main charger. The protection circuits in modern chargers need some > voltage to insure that they are connected properly. > > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX > > > _____ > > From: "WanderlodgeForum%40yahoogroups.com" > [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of Ed Gardels > Sent: Tuesday, May 05, 2009 1:03 AM > To: "WanderlodgeForum%40yahoogroups.com" > Subject: [WanderlodgeForum] Batteries not charging-both engine and coach > > > > > > My batteries wont charge after I found them discharged.grand kids knocked > shorepower plug out. I pluged it back in and a couple of days later they are > still dead. I have the diagrams for the chargeing circuit. There are four > bosch relays in the circuit to allow the current to the buss and then to the > battery bay. One of the wires that goes to the coil of one of the relays > goes to the front elec panel.What else is neccesary to charge the > batterys.relay or whatever.I have been working on this for two weeks with no > results. > Anyone have ideas or knowledge of this circuit please advise? > thanks in advance > Ed Gardels 89SP > Arlington Tx > |
05-05-2009, 10:48
Dumb question Ed, but do you have 110 volts to your chargers?
Chet Geist
1981 FC33, Austin, Texas
05-05-2009, 11:59
--- In WanderlodgeForum@yahoogroups.com, "Chet Geist"
> > Dumb question Ed, but do you have 110 volts to your chargers? > Good question Chet, but yes I do but I havent mesured it. As a mater of fact I saw on the PDI(Power Dynamics)web page today(Ive been using their troublesooting chart), that if the input is low the output can be low. I might get to that tommorrow. This afternoon I took out the batteries to put on my other charger in the garage. Thanks Ed Gardels 89SP Arlington TX > Chet Geist > 1981 FC33, Austin, Texas > > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Ed Gardels > Sent: Tuesday, May 05, 2009 1:03 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Batteries not charging-both engine and coach > > > > > > My batteries wont charge after I found them discharged.grand kids knocked > shorepower plug out. I pluged it back in and a couple of days later they are > still dead. I have the diagrams for the chargeing circuit. There are four > bosch relays in the circuit to allow the current to the buss and then to the > battery bay. One of the wires that goes to the coil of one of the relays > goes to the front elec panel.What else is neccesary to charge the > batterys.relay or whatever.I have been working on this for two weeks with no > results. > Anyone have ideas or knowledge of this circuit please advise? > thanks in advance > Ed Gardels 89SP > Arlington Tx > |
05-05-2009, 14:52
ED: I took out my 4 house batteries and replaced them with TWO TROJAN 6 VOLT T-105'S AND PUT IN A XANTREX CHARGER AND I have plenty of house power...just a comment. Regards, Hank 90SP36 In WanderlodgeForum@yahoogroups.com, "Ed Gardels" > > --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" > > > > Dumb question Ed, but do you have 110 volts to your chargers? > > Good question Chet, but yes I do but I havent mesured it. As a mater of fact I saw on the PDI(Power Dynamics)web page today(Ive been using their troublesooting chart), that if the input is low the output can be low. I might get to that tommorrow. This afternoon I took out the batteries to put on my other charger in the garage. > Thanks > Ed Gardels 89SP > Arlington TX > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Chet Geist > > 1981 FC33, Austin, Texas > > > > > > -----Original Message----- > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Ed Gardels > > Sent: Tuesday, May 05, 2009 1:03 AM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Batteries not charging-both engine and coach > > > > > > > > > > > > My batteries wont charge after I found them discharged.grand kids knocked > > shorepower plug out. I pluged it back in and a couple of days later they are > > still dead. I have the diagrams for the chargeing circuit. There are four > > bosch relays in the circuit to allow the current to the buss and then to the > > battery bay. One of the wires that goes to the coil of one of the relays > > goes to the front elec panel.What else is neccesary to charge the > > batterys.relay or whatever.I have been working on this for two weeks with no > > results. > > Anyone have ideas or knowledge of this circuit please advise? > > thanks in advance > > Ed Gardels 89SP > > Arlington Tx > > > |
05-05-2009, 14:57
wrote: >Ralph, Thanks for the input. Yes I put a meter on the contact of the bosch relay and read 4-5 volts. I then remove the + wire from the charger and get 13v, go figure.... Ed Gardels 89SP Arlington Tx > Hi Ed: > > Just a curious question to start; Have you checked the output dc voltage > from your chargers? they should be reading 14.1 or so dc volts at the > source. If only reading 12.3 vdc then the chargers have taken a hike on you. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 05:01 PM 5/5/2009 +0000, you wrote: > >--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > >Thanks for the response, Chuck. Actully i tried that a couple of weeks > > ago, but the chargers didnt keep up. Its the first time that the engine > > batteries went down too. I think that a clue to my problem, since it > > deals with both seperate banks of batteries. I have also tested the > > battery isolator. I have exausted my ideas. > > Thanks > > Ed Gardels 89SP > > Arlington Tx > > > Ed, > > > > |
