Jake Brake
05-12-2009, 12:25
Jake Brake
Hi group,
On our way here to Fla from Texas,I have noticed the jake brake quit working on the high position. That is the one I mainly use, very rarely the low position. Thing is, the low position sounds like it has the high setting. I changed out the switch figuring it's 25 years old and fried itself. Didn't help. My next thought is that there is a solinoid in the engine compartment that has bit the dust. Problem is, where do I look for it? I would think this part is pretty available, but I have to find it first. Any thoughts on where to look? Bob Lawrence 84 PT36 Tallahassee, Fla |
05-12-2009, 13:10
Jake Brake
Bob - A friend with a 6v92 powered County Coach was having a very similar
problem. Turns out the solenoids that respond to the electric signal are under the valve covers. The same local truck shop that does some work on our Bird fixed the problem right up. The situation with yours could be different of course. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" wrote: > > Hi group, > > On our way here to Fla from Texas,I have noticed the jake brake quit working on the high position. That is the one I mainly use, very rarely the low position. > Thing is, the low position sounds like it has the high setting. > I changed out the switch figuring it's 25 years old and fried itself. > Didn't help. > My next thought is that there is a solinoid in the engine compartment that has bit the dust. Problem is, where do I look for it? > I would think this part is pretty available, but I have to find it first. > Any thoughts on where to look? > > Bob Lawrence > 84 PT36 > Tallahassee, Fla > |
05-12-2009, 13:53
Jake Brake
Bob: I would bet that you just have a loose or corroded connection on a wire
controlling the Jake. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" wrote: > > Hi group, > > On our way here to Fla from Texas,I have noticed the jake brake quit working on the high position. That is the one I mainly use, very rarely the low position. > Thing is, the low position sounds like it has the high setting. > I changed out the switch figuring it's 25 years old and fried itself. > Didn't help. > My next thought is that there is a solinoid in the engine compartment that has bit the dust. Problem is, where do I look for it? > I would think this part is pretty available, but I have to find it first. > Any thoughts on where to look? > > Bob Lawrence > 84 PT36 > Tallahassee, Fla > |
05-12-2009, 23:47
Jake Brake
05-13-2009, 00:48
Jake Brake
Could be, Ron.....now if I can just find where it connects to the solenoids.
Also, thanks, Bob, as a last resort I will hit a truck repair place to look under valve covers. Bob 84 PT36 Tallahassee, Fla > Bob: I would bet that you just have a loose or corroded connection on a wire controlling the Jake. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > Hi group, > > > > On our way here to Fla from Texas,I have noticed the jake brake quit working on the high position. That is the one I mainly use, very rarely the low position. > > Thing is, the low position sounds like it has the high setting. > > I changed out the switch figuring it's 25 years old and fried itself. > > Didn't help. > > My next thought is that there is a solenoid in the engine compartment that has bit the dust. Problem is, where do I look for it? > > I would think this part is pretty available, but I have to find it first. > > Any thoughts on where to look? > > > > Bob Lawrence > > 84 PT36 > > Tallahassee, Fla > > > |
05-13-2009, 01:11
Jake Brake
I'd like to locate a Jake Brake unit for the mechanical 8V92...another project.
Curt Sprenger On Wed, May 13, 2009 at 4:47 AM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
06-16-2009, 06:47
Jake Brake
I'm toying with the thought/research to add a Jake Brake to our 8V92. Thoughts, experiences, complete system or parts available?
I uploaded a few Jake Brake PDFs to the forum. Click on Attachments. Curt Sprenger |
