starter
05-12-2009, 15:05
starter
Hi All
Had a great weekend by the beach . Monday I was ready to drive the bus to
storage . Would not start , after following some good advise I was able to start
the engine .Good size hammer a few shots to the starter while someone turns the
key, did it . Hi Tech !!
Now scheduling the proper replacement . Thanks for the help.
Mario 1985fc35 Safely in storage in Vista
05-13-2009, 02:54
starter
Mario,Sounds like you need a new starter solenoid.
Harold Prescott
1985 WLFC 35
Butte County Ca.
--- In WanderlodgeForum@yahoogroups.com, "mariopatti1" wrote:
> Hi All
05-13-2009, 15:44
starter
Harold , Thanks . Having the work done , looking to have my starter solenoid
reman .Do you still have the original starter ?
Mario 1985fc35 Socal
--- In WanderlodgeForum@yahoogroups.com, "Harold Prescott"
> Harold Prescott
> 1985 WLFC 35
> Butte County Ca.
> > Hi All
05-14-2009, 03:22
starter
Mario,
I don't know if the starter is original or not. Going by the miles on my coach,
I would say it's original. 160K
The solenoid can be R&R'ed without replacing the starter. NAPA will carry the
solenoid.
There is a electrical rebuild shop in Escondido. North County Rebuilders - (760)
746-2276. 445 No. Hale., Escondido, Ca.
I've used this shop in the past with good results. It's only a rebuild shop,
you will need to hand carry the starter into them.
Good Luck with all this
Harold
> > Harold Prescott
> > 1985 WLFC 35
> > Butte County Ca.
> > > Hi All
