Ride height valve & Air Dryer
06-08-2005, 22:48
GOOD IDEA ON REPLACING THE REAR END OIL,,, I HAD FORGOTTEN ABOUT
THAT,,, WHAT BRAND, AND WHERE DO YOU FIND YOUR SYNTHETIC REAR END OIL??? THANKS,,, DAY,,,, [Non-text portions of this message have been removed] |
06-09-2005, 01:30
Had a ride height valve linkage break on the coach. While working the
valve manually decided it was defective. Replaced the valve with a new one from truck store and ordered a new piece of linkage with new swivle ends from BB. total time to replace about 45 minutes and total cost $65.00. While under the coach and somewhat dirty decided it was time to replace the dryer filter. Took it completely out and put it on the bench cleaned it up and replaced filter and 0 rings. total time for this about 2 hours and total cost $37.00. All work's good now. Next project is to replace the rear-end fluid. My books says to replace it yearly given the miles I drive the coach, I believe it also says that if you drive under 6 thousand miles a year to replace it twice a year!!! I'll replace it with the 85-140 wt. synthetic again. Great day here in the heart land, good rain last night and crops are looking good this morning......Bob 93pt Bunker Hill, Illinois |
06-09-2005, 04:06
Bob. How many quarts does the diff take on a change?
dandarst86fc35rbhuntleyil. >From: "Bob & Carol Howald`" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Ride height valve & Air Dryer >Date: Thu, 09 Jun 2005 13:30:00 -0000 > > Had a ride height valve linkage break on the coach. While working the >valve manually decided it was defective. Replaced the valve with a new >one from truck store and ordered a new piece of linkage with new swivle >ends from BB. total time to replace about 45 minutes and total cost >$65.00. While under the coach and somewhat dirty decided it was time to >replace the dryer filter. Took it completely out and put it on the >bench cleaned it up and replaced filter and 0 rings. total time for >this about 2 hours and total cost $37.00. All work's good now. Next >project is to replace the rear-end fluid. My books says to replace it >yearly given the miles I drive the coach, I believe it also says that >if you drive under 6 thousand miles a year to replace it twice a >year!!! I'll replace it with the 85-140 wt. synthetic again. Great day >here in the heart land, good rain last night and crops are looking good >this morning......Bob 93pt Bunker Hill, Illinois > > > |
06-09-2005, 08:18
THANKS,,, I WILL TRY TO FIND AN AMSOIL SUPPLIER IN MY AREA,, SHOULD BE
SOMEONE LISTED IN THE YELLOW PAGES,,, HOW MUCH SHOULD I PLAN ON BUYING??? THANKS AGAIN,,,, DAY,JAX FLA,, 83 PT-40 [Non-text portions of this message have been removed] |
06-09-2005, 09:36
Dan: On my 93 it take's right at 16qts. I buy the 5gal. bucket and
then I have a pump that goes on it in place of the lid.. On my last post I said that they recommend changing fluid twice a year if driven under 6,000 miles. I meant to say twice a year if driven under 60,000 miles....Bob 93pt Illinois |
06-09-2005, 11:38
--- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote:
> GOOD IDEA ON REPLACING THE REAR END OIL,,, I HAD FORGOTTEN ABOUT > THAT,,, WHAT BRAND, AND WHERE DO YOU FIND YOUR SYNTHETIC REAR END OIL??? THANKS,,, > DAY,,,, > > Day: You can get the synthetic anywhere, Texaco,Mobil,Shell what ever you want. I use Amsoil. Check with you oil supplier... > [Non-text portions of this message have been removed] |
06-10-2005, 01:00
Thanks Bob. On another matter, my wife, Barb and I plan to go to S. Padre at
Christmas time for a week or two (we are still working), and will have some questions for you as we get closer. We have never been there but thought it would be an escape from winter without the crowd in Florida. Dan. >From: "Bob & Carol Howald`" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Ride height valve & Air Dryer >Date: Thu, 09 Jun 2005 21:36:09 -0000 > >Dan: On my 93 it take's right at 16qts. I buy the 5gal. bucket and >then I have a pump that goes on it in place of the lid.. On my last >post I said that they recommend changing fluid twice a year if driven >under 6,000 miles. I meant to say twice a year if driven under 60,000 >miles....Bob 93pt Illinois > > > |
