Locking Tag Axle Tire
06-08-2005, 23:45
I LOCKED UP A PASSENGER SIDE TAG BRAKE THE OTHER DAY. WILL BE INTERESTING
TO SEE WHAT YOU FIND OUT. I WAS TOLD THAT THE LOADING ON THE TAG MAY NOT BE PROPER, BUT I DON'T KNOW HOW TO ADJUST THAT. SOMETHING TO DO WITH "RAISING OR LOWERING" THE TAG AXLE, I WAS TOLD,,, MAYBE ADJUSTING THE DRIVE AXLE HEIGHT??? DAY, IN SUNNY JAX FL, 83 PT-40 [Non-text portions of this message have been removed] |
06-09-2005, 03:38
First post reading for years. Have had a tag axle, drivers side,
that locks on hard braking. Many corrective actions taken. Started by replacing leaking oil seal and brakes that wheel. Adjusted slack adjusters myself and also local truck shop. At Bennie??? recommendation at Bluebird hooked up guages to each line going to each tag axle wheel. Thought had found problem approximately 10# difference, BUT switched gauges and found that the guages had a 10# difference. Guages actually show air pressures to each side very close. Truck mechanic thinks it could be warped brake drum, but it has not been noticed when other repairs made. Before taking off wheel and drum again, I though that I would seek help from past experiences on forum. Rex Puckett 85PT36 |
06-09-2005, 03:54
Rex: It would not be real unusual for the tag brake's to lock up
during a HARD brake situation. WhatI would want to do next is to make sure that Iam getting full down pressure (bag inflation) on the left side. Have you weighed the coach to see how light the left side is (depends on inside configuration). What are you running for TAG pressure on you guage ?....Bob 93pt |
06-09-2005, 04:02
check to make sure that both air lines are the same length.if one has been
replaced it may be shorter or longer.it does matter..Tom? randydupree93wb ----- Original Message ----- From: Rex To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 11:38 AM Subject: [WanderlodgeForum] Locking Tag Axle Tire First post reading for years. Have had a tag axle, drivers side, that locks on hard braking. Many corrective actions taken. Started by replacing leaking oil seal and brakes that wheel. Adjusted slack adjusters myself and also local truck shop. At Bennie??? recommendation at Bluebird hooked up guages to each line going to each tag axle wheel. Thought had found problem approximately 10# difference, BUT switched gauges and found that the guages had a 10# difference. Guages actually show air pressures to each side very close. Truck mechanic thinks it could be warped brake drum, but it has not been noticed when other repairs made. Before taking off wheel and drum again, I though that I would seek help from past experiences on forum. Rex Puckett 85PT36 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 06:20
I'm surprised that only one locks on hard braking. The reason this
occurs is because you get a major weight shift to the front axle which unloads the tag. The fact that only one is locking simply means the two are not adjusted the same. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Rex" > First post reading for years. Have had a tag axle, drivers side, > that locks on hard braking. Many corrective actions taken. Started > by replacing leaking oil seal and brakes that wheel. Adjusted slack > adjusters myself and also local truck shop. At Bennie??? > recommendation at Bluebird hooked up guages to each line going to > each tag axle wheel. Thought had found problem approximately 10# > difference, BUT switched gauges and found that the guages had a 10# > difference. Guages actually show air pressures to each side very > close. Truck mechanic thinks it could be warped brake drum, but > it has not been noticed when other repairs made. Before taking off > wheel and drum again, I though that I would seek help from past > experiences on forum. > > Rex Puckett > 85PT36 |
06-09-2005, 06:24
I need to clarify my last post to you. I assumed you are talking
about an emergency stop. If not, then I would look at what Bob and Randy recommended. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Rex" > First post reading for years. Have had a tag axle, drivers side, > that locks on hard braking. Many corrective actions taken. Started > by replacing leaking oil seal and brakes that wheel. Adjusted slack > adjusters myself and also local truck shop. At Bennie??? > recommendation at Bluebird hooked up guages to each line going to > each tag axle wheel. Thought had found problem approximately 10# > difference, BUT switched gauges and found that the guages had a 10# > difference. Guages actually show air pressures to each side very > close. Truck mechanic thinks it could be warped brake drum, but > it has not been noticed when other repairs made. Before taking off > wheel and drum again, I though that I would seek help from past > experiences on forum. > > Rex Puckett > 85PT36 |
06-09-2005, 07:56
Randy unless the law of physics has changed since I retired 10 years ago a
difference in 1/4" air line lengths of a few feet will not make a difference in the force that the brake chamber applies to the slack adjuster.. I would suspect that if one tire is locking up then I would suspect contaminated brake shoes on that axel or a misadjusted slack adjuster. Tom 1982 FC35 Vernon Center,NY At 12:02 PM 6/9/2005 -0400, you wrote: >check to make sure that both air lines are the same length.if one has been >replaced it may be shorter or longer.it does matter..Tom? randydupree93wb > ----- Original Message ----- > From: Rex > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, June 09, 2005 11:38 AM > Subject: [WanderlodgeForum] Locking Tag Axle Tire > > > First post reading for years. Have had a tag axle, drivers side, > that locks on hard braking. Many corrective actions taken. Started > by replacing leaking oil seal and brakes that wheel. Adjusted slack > adjusters myself and also local truck shop. At Bennie??? > recommendation at Bluebird hooked up guages to each line going to > each tag axle wheel. Thought had found problem approximately 10# > difference, BUT switched gauges and found that the guages had a 10# > difference. Guages actually show air pressures to each side very > close. Truck mechanic thinks it could be warped brake drum, but > it has not been noticed when other repairs made. Before taking off > wheel and drum again, I though that I would seek help from past > experiences on forum. > > Rex Puckett > 85PT36 > > > > > >------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > >[Non-text portions of this message have been removed] > > > > > >Yahoo! Groups Links > > > > |
06-09-2005, 08:38
> that locks on hard braking. > > Rex Puckett > 85PT36 Hi Rex, I don't want to confuse your issue but want to relay an experience from an 86PT40 in about 1987-88 when a hard braking incident "blew" (exploded) the curbside drive and tag axle drums, tires etc. and separated the tag. Was fortunate to be towed "after hours" to a large International Truck/bus shop in Hickory, NC where current maint Chief was a retired (after 30+ yrs) maint Chief with Greyhound Bus. In spite of my protestations, the shop guard called Chief, at home, late Sat night. First thing Chief asked was, if I had previously experienced any unusual single tire lockups? I couldn't recall any. He came in early Sun morn, took one look, said he'd bet a weeks pay on defective drums produced from 82 thru 86 (or thereabouts). While we waited for BB to air freight lots of parts, he had my four "remaining" drums (the other two were somewhere along I-40's Black Mountain) pulled and inspected. Guess what??? Although I never understood the connection, he refused to believe I hadn't experienced lock up problems and claimed he'd seen hundreds in his years with Greyhound. This experience might not have any bearing on your situation, but sharing potentially helpful info is one purpose for this great Forum. John Suter 2000LXi (previous 86PT40, 91PT40) __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
06-09-2005, 09:09
From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 1:24 PM Subject: [WanderlodgeForum] Re: Locking Tag Axle Tire I would also look at the cams if they get overly worn they can lock your braks up.What happens is they rotate a little to far and not release Bob Loomas 85 PT 36 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-09-2005, 09:51
THE LENGTH ON THE INJECTOR LINES ARE PRECISE DUE TO THE TIMING FOR THE
FUEL TO BE INJECTED INTO THE CYLINDER AT A PRECISE TIME. (WHICH OF COURSE YOU KNEW) THE LENGTH OF THE AIR LINES ARE NOT PRECISE FOR "TIMING" BECAUSE AIR PRESSURE SHOULD BE EQUAL THROUGHOUT THE LENGTH OF THE LINES. ALL BRAKES ARE SUPPOSED TO APPLY AT THE SAME TIME. THE LEFT SIDE DOES NOT APPLY BEFORE THE RIGHT SIDE. THE AIR PRESSURE WILL BE THE SAME AT ALL POINTS THROUGHOUT THE LINE. IF A DIFFERENCE DOES OCCUR, IT WILL BE DUE TO OBSTRUCTIONS, RESTRICTIONS, OR SOME OTHER PROBLEM. DAY JAX FLA 83 PT-40. [Non-text portions of this message have been removed] |
