Windows
06-09-2005, 12:24
Windows
Hello Everyone,
I would like to replace the felt strips that are on the inside of the
sliding windows, but I am not sure how the windows come out of the
frames. Any help will be appreciated. If anyone knows where to buy
(felt?)please let me know.
Thanks,
Larry Holland
82FC35 3208T
Canandaigua, N.Y.
06-09-2005, 13:00
Windows
Hi Larry, I would tell you just how to do it, but I havent the
faintest clue!! Most of the windows on our 1973FC do not move, except
for the drivers unit. Perhaps the clue here is to slide them every
once in a while. I have tried WD40 on one with no success, and
graphite on another with no change except Wife yelling that I got my
shirt dirty.
I also await the solutition from the real pros.
Jack Smith
1973FC31
SoCal, 300 miles S/O the MJ Circus!!!
--- In WanderlodgeForum@yahoogroups.com, "Larry holland"
> Hello Everyone,
> the
> Thanks,
> Larry Holland
> 82FC35 3208T
> Canandaigua, N.Y.
06-09-2005, 13:07
Windows
silicone spray is the deal..randydupree93wb
Sent: Thursday, June 09, 2005 9:00 PM
Subject: [WanderlodgeForum] Re: Windows
shirt dirty.
Jack Smith
1973FC31
> Hello Everyone,
> the
> Thanks,
> Larry Holland
> 82FC35 3208T
> Canandaigua, N.Y.
Yahoo! Groups Links
a.. To visit your group on the web, go to:
06-09-2005, 13:30
Windows
I've bought it from BB, a while ago though.
The sliding window can be removed by pulling the black strip out of the
end-aluminum extrusion, removing the two screws (top and bottom),
remove the end aluminum extrusion, slide the glass out of the frame,
bend/spring the empty frame enough to remove from the window, replace
felt, reverse removal procedure. PITA at best. The last time I did
window work I removed the entire window assembly from the coach first
which IMO is easier:
Remove window retainer strip (salon and driver's windows) or pry open
the rubber strip at the seam (rear of the salon), remove inside trim,
push window out at the bottom frame into a waiting helper's hands,
disconnect alarm sensor wires, lower window away, disassemble.
With trying to serviced the window in the coach you risk having to
remove it anyway as re-installing the glass into the frame and hardened
plastic gasket/seal is not easy.
- Jeff Miller
> Hello Everyone,
> the
> Thanks,
> Larry Holland
> 82FC35 3208T
> Canandaigua, N.Y.
06-09-2005, 15:24
Windows
Bluebird has the felt and the cat fur for the windows in stock just
checked on line and it is priced very reasonable you can also got to
Spaenaur.com and order it from there also.
Stephen 77fc35
Niagara Falls for the DAY
> Hello Everyone,
> the
> Thanks,
> Larry Holland
> 82FC35 3208T
> Canandaigua, N.Y.
06-09-2005, 15:30
Windows
I also posted a how in the files of the old forum I dont kow if it got
migrated over but give me a call during the DAY and I can talk you
through it
Stephen 77fc35
> Stephen 77fc35
> > Hello Everyone,
> > the
> > Thanks,
> > Larry Holland
> > 82FC35 3208T
> > Canandaigua, N.Y.
01-03-2006, 07:28
Windows
I have seen a lot of mid 90's rigs for sale that the owner says that
the coach has Hehr windows. Were these better than the BB window? Were
they more efficeint in the sun? Someday when I upgrade out of my 95
BMC I will need to know. thanks marty
01-03-2006, 08:51
Windows
Hehr was the supplier when Bluebird got out of the window making
business there are a variety of suppliers for aftermarket windows the
2 highest quality in my opinion are Stormtite (Triple E and other
coaches ) and Beclewat (Marine and RV)
Hehr is known for producing windows for over the road coachs and there
also Peninsula no doubt there are others
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "martingregg598"
01-03-2006, 08:56
Windows
Having owned units with both kinds of windows, I wouldn't brag on Hehr windows,
NOT an upgrade.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Tuesday, January 03, 2006 1:28 PM
Subject: [WanderlodgeForum] windows
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
01-03-2006, 13:16
Windows
Marty,
Hehr is just another manufacturer of RV windows located in SOCAL. They
make a good window. I have also used Peninsula Windows. My '95 has Hehr
though they are only single pane.
George Lowry
'95 WBDA 4203
Spearfish, SD
>Yahoo! Groups Links
