GENERATOR INFO NEEDED PLEASE HELP
05-21-2009, 06:23
I HAVE A 1990 WB40 BIRD WITH A KOHLER YANMAR POWERED GENERATOR FOR SOME RESON IT
WILL NOT KEEP RUNNING IT PUTTING OUT BLACK SMOKE I DONT USE IT TO MUCH BUT I ALWAYS START IT HERE AND THER BUT THIS TIME NO GO I FIGURE IT COULD BE THE FUEL ANYWAY THE BOOK SAID IT SHOULD HAVE A FUEL FILTER # 252765 WHICH I CANT FIND DOSE ANYONE KNOW WHER I CAN GET THE RIGHT FILTER ALSO I NEED THE AIR FILTER #258646 ALSO LOOKING FOR REPAIR MANUAL THANKS FOR YOUR HELP JAMIE BRANDT 1990 WB40 PORT CHARLOTTE FLORIDA JAMIE@... |
05-21-2009, 06:38
Check you air filter to see that it is not Steve Quandt 1993 PT-40 Iron Mountain, MI From:
I HAVE A 1990 WB40 BIRD WITH A KOHLER YANMAR POWERED GENERATOR FOR SOME RESON IT WILL NOT KEEP RUNNING IT PUTTING OUT BLACK SMOKE I DONT USE IT TO MUCH BUT I ALWAYS START IT HERE AND THER BUT THIS TIME NO GO I FIGURE IT COULD BE THE FUEL ANYWAY THE BOOK SAID IT SHOULD HAVE A FUEL FILTER # 252765 WHICH I CANT FIND DOSE ANYONE KNOW WHER I CAN GET THE RIGHT FILTER ALSO I NEED THE AIR FILTER #258646 ALSO LOOKING FOR REPAIR MANUAL THANKS FOR YOUR HELP JAMIE BRANDT 1990 WB40 PORT "JAMIE%40GASPARILLAGLASS.COM" |
05-21-2009, 07:18
Hi Jamie, I have a 88XXV with the same gen set. Check
a few things. Go to the basement and turn off the breakers from the gen set. If there is a short the Gen won't run. On the gen it self, there is a solenoid to keep the fuel control throttle open. The wire can vibrate off or have grease on it. There are sensors to turn off the gen if you loose oil pressure or the gen gets to hot. If any are not working they would keep the gen from running. I have had the breaker, solenoid, and hot sensor have problems. Most were loose wires. For the Filters, mine has a Racor filter canister. It's located on the right side of the gen set conected to the coach. If this is what you have let me know and I'll send you the numbers for the filter. Paul Williams
seekingoz 88XXV
8V92
South Lake Tahoe, Ca
From: gasparillaglass To: WanderlodgeForum@yahoogroups.com Sent: Thu, 21 May 2009 11:23 am Subject: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP I HAVE A 1990 WB40 BIRD WITH A KOHLER YANMAR POWERED GENERATOR FOR SOME RESON IT WILL NOT KEEP RUNNING IT PUTTING OUT BLACK SMOKE I DONT USE IT TO MUCH BUT I ALWAYS START IT HERE AND THER BUT THIS TIME NO GO
I FIGURE IT COULD BE THE FUEL ANYWAY THE BOOK SAID IT SHOULD HAVE A FUEL FILTER # 252765 WHICH I CANT FIND DOSE ANYONE KNOW WHER I CAN GET THE RIGHT FILTER ALSO I NEED THE AIR FILTER #258646 ALSO LOOKING FOR REPAIR MANUAL THANKS FOR YOUR HELP JAMIE BRANDT 1990 WB40 PORT CHARLOTTE FLORIDA "JAMIE%40GASPARILLAGLASS.COM" |
05-21-2009, 10:10
Check the air filter. Black smoke is a sign that the engine isn't getting enough air.
NAPA Auto parts (and many other auto parts stores) will have cross reference lists for filters, if someone on this list doesn't have the right numbers. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On May 21, 2009, at 11:23 AM, gasparillaglass wrote:
05-21-2009, 10:30
Curt Sprenger On Thu, May 21, 2009 at 3:10 PM, Pete Masterson <"aeonix1@mac.com"> wrote:
05-21-2009, 11:06
im not sure what you mein by the basement
But I do get the idea
I will check all cenections
are you saying if i turn the breakers off that it will run??
From: "PRWillms@..." Sent: Thursday, May 21, 2009 3:18:25 PM Subject: Re: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP Hi Jamie, I have a 88XXV with the same gen set. Check a few things. Go to the basement and turn off the breakers from the gen set. If there is a short the Gen won't run. On the gen it self, there is a solenoid to keep the fuel control throttle open. The wire can vibrate off or have grease on it. There are sensors to turn off the gen if you loose oil pressure or the gen gets to hot. If any are not working they would keep the gen from running. I have had the breaker, solenoid, and hot sensor have problems. Most were loose wires. For the Filters, mine has a Racor filter canister. It's located on the right side of the gen set conected to the coach. If this is what you have let me know and I'll send you the numbers for the filter.
Paul Williams
seekingoz 88XXV
8V92
South Lake Tahoe, Ca From: gasparillaglass To: WanderlodgeForum@ yahoogroups. com Sent: Thu, 21 May 2009 11:23 am Subject: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP I HAVE A 1990 WB40 BIRD WITH A KOHLER YANMAR POWERED GENERATOR FOR SOME RESON IT WILL NOT KEEP RUNNING IT PUTTING OUT BLACK SMOKE I DONT USE IT TO MUCH BUT I ALWAYS START IT HERE AND THER BUT THIS TIME NO GO I FIGURE IT COULD BE THE FUEL ANYWAY THE BOOK SAID IT SHOULD HAVE A FUEL FILTER # 252765 WHICH I CANT FIND DOSE ANYONE KNOW WHER I CAN GET THE RIGHT FILTER ALSO I NEED THE AIR FILTER #258646 ALSO LOOKING FOR REPAIR MANUAL THANKS FOR YOUR HELP JAMIE BRANDT 1990 WB40 PORT CHARLOTTE FLORIDA "JAMIE%40GASPARILLAGLASS.COM" |
05-21-2009, 11:35
Hi I had some work done on the coach. In my storage area, front left is a breaker box. There are only 2 breakers that are 50 amp each. They are for each leg in the coach. If you have a short in the lines to the coach from the Gen, the gen engine will not run.
Paul Williams seekingoz 88XXV
8V92
South Lake Tahoe, Ca-----Original Message----- From: Jamie Brandt To: WanderlodgeForum@yahoogroups.com Sent: Thu, 21 May 2009 4:06 pm Subject: Re: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP im not sure what you mein by the basement
From: "PRWillms@aol. To: WanderlodgeForum@ Sent: Thursday, May 21, 2009 3:18:25 PM Subject: Re: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP Hi Jamie, I have a 88XXV with the same gen set. Check a few things. Go to the basement and turn off the breakers from the gen set. If there is a short the Gen won't run. On the gen it self, there is a solenoid to keep the fuel control throttle open. The wire can vibrate off or have grease on it. There are sensors to turn off the gen if you loose oil pressure or the gen gets to hot. If any are not working they would keep the gen from running. I have had the breaker, solenoid, and hot sensor have problems. Most were loose wires. For the Filters, mine has a Racor filter canister. It's located on the right side of the gen set conected to the coach. If this is what you have let me know and I'll send you the numbers for the filter.
Paul Williams
seekingoz 88XXV
8V92
05-21-2009, 12:35
05-21-2009, 13:37
Here is a Pic of our coach, "SeekingOz", in South Lake Tahoe, Ca
Paul WilliamsSeekingOz 88XXV
8V92
South Lake Tahoe, CaFrom: Ernie Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Thu, 21 May 2009 5:35 pm Subject: Re: [WanderlodgeForum] GENERATOR INFO NEEDED PLEASE HELP
05-22-2009, 08:14
