airbag air pressure
05-21-2009, 14:31
airbag air pressure
can anyone tell me if and or how can the air pressure in the air bags be
increased or decreased. seems that our ride has gotten somewhat harsh and have new shocks and am playing with the air pressure in the tires. trying to make the ride so as not to have the cabinets fall off the wall. well its not that bad but could be a lots better. ed and peggy mcstay 1983 fc 35 ft. rear bath lake charles,La. "lonesome dove" |
05-21-2009, 14:41
airbag air pressure
Hi Ed:
The air in the suspension in our years of Birds are all or none. The adjustment lays in the stiffness of the shocks. Even if there were a way to soften the air bags it would change the ride height, change the handling as well as other attributes. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma At 02:31 AM 5/22/2009 +0000, you wrote: >can anyone tell me if and or how can the air pressure in the air bags be >increased or decreased. seems that our ride has gotten somewhat harsh and >have new shocks and am playing with the air pressure in the tires. trying >to make the ride so as not to have the cabinets fall off the wall. well >its not that bad but could be a lots better. > >ed and peggy mcstay >1983 fc 35 ft. rear bath >lake charles,La. >"lonesome dove" > > > |
05-21-2009, 15:29
airbag air pressure
........trying to make the ride so as not to have the cabinets fall off the wall.....
> ed and peggy mcstay > 1983 fc 35 ft. rear bath r u sure the suspension isn't dumped? <!--[if gte mso 9]> \/\/\â¦Fred __________________ Fred & Wendy Bellows Queen Creek, AZ (so.east Phx) '90 SP36 "Maunder Maximum" photos of coach and upgrades current location |
05-21-2009, 17:37
airbag air pressure
You can check your blue file box for the info on your air suspension system, it will give the specs. on the proper height for the air bags for each axle.If they are out of the spec.there are 2 ajustment rods in the back at the drive axle, one is on the left side and controls how much all the air bags on that side of the coach are inflated and the one on the right how much all the air bags on the right are inflated. (These rods in the rear effect how level your coach sits side to side). There is one rod at the front (steering axle) this rod controlsthe proportion of the inflation of the front axle air bags to the rear axle or axles air bags. If you reajust this rod for more air in the front air bags the rear air bags will get proportionally less air pressure. You have
to check your suspension with your coach on a level surface and as allways take proper precautions blocking under the coach in case your suspension was to deflate unexpectedly, and moving or reajusting the positions ofthe rods will make the air bags deflate or inflate depending on which way you move them. You may want to call reputable dealer service dept. like Holland Motor Homes for additional tips. Wayne
1985 PT40
From: Peggy & Ed McStay To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 21, 2009 9:31:48 PM Subject: [WanderlodgeForum] airbag air pressure can anyone tell me if and or how can the air pressure in the air bags be increased or decreased. seems that our ride has gotten somewhat harsh and have new shocks and am playing with the air pressure in the tires. trying to make the ride so as not to have the cabinets fall off the wall. well its not that bad but could be a lots better. ed and peggy mcstay 1983 fc 35 ft. rear bath lake charles,La. "lonesome dove" |
05-22-2009, 08:19
airbag air pressure
