Explosive Post⦠Propane Grill
05-23-2009, 00:52
Explosive Post Propane Grill
I decided to get a grill for the coach and found a nice little 304 stainless infrared unit called the Stow- N- Go on sale at West Marine on sale for just under $100 < http://tinyurl.com/qndj25 >. It works great and is small enough to fit in front basement of our FC, gets real hot fast and cools off fast too and temp is easy to control and cleans up nicely. Although its not heavy duty, its beefy enough (pun intended). The grill is set up to run on small propane bottles and this works fine. Like many off the shelf grills, this unit comes equipped with a high-pressure regulator and in this case the control is on the regulator itself. I wanted to get a hose and fittings to use with the coach's dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. I went to the hardware store and told the hardware man what I wanted to do and he said "Son, I got hose and fittings, but I don't want assist you in making a bomb. You best go talk with a propane man. I started doing some reading and spoke with a couple of seasoned propane specialists and the both sources stated to go with low pressure. This is the safe way and the right to do it. Therefore, one needs to MODIFY the GRILL to accommodate the factory RV system NOT the other way around. More than once I have heard some members talk about modifying the coach's propane system to accommodate the grill because they were not getting sufficient pressure from the on board outlet. This is a real concern to me. Perhaps I'm making a big deal out of something that is no big deal, but I ain't taking chances with propane gas NO SIR! With that, I started investigating what I need to do to use the Bar-B-Q outlet from the coach and learned that the coach is set up with a low-pressure regulator (6 ounces -10.5 inches water column). Apparently this is an industry standard for large RV systems and the safest way to run a grill off a large tank. This is similar to residential installations. "Another often asked question is "I have a low pressure regulator but it does not seem to supply enough gas for my appliance." Unfortunately, many of the preset low pressure regulators available in the marketplace use 1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT (normal pipe thread) outlet on the propane regulator. There is a limit to the volume of gas that can be delivered through this small ID hose at a fixed low propane pressure of 6 ounces . What can you do? Use a low pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The amount of propane that can be delivered to the appliance is increased by a factor of 2.26 so the chances of starving your appliance for propane are greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet low pressure gas regulators and 3/8"ID low pressure hoses for this very reason. Our grey hose carries UL , CSA, and American Gas Association approvals and is designed to supply up to about 100,000 btu/hr of propane gas." http://www.gashosesandregulators.com/pro...facts.html So, from this I conclude the best way to set up my grill is to ⢠Eliminate the high pressure regulator at the grill ⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID ⢠Low pressure hose 3/8" ID ⢠Install control valve between regulator and grill If I am wrong about this please let me know. Your comments and constructive criticism are always welcome. Wishing you all a happy and safe Memorial Day! NH Bill 1983 FC 35 "Casa Billisa" |
05-23-2009, 01:26
Thanks, Bill. I have one of the weak electric pullout grills in my coach..and I was thinking about doing something different. If and when I do, your post will come in very handy.
Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@yahoogroups.com From: billgaramella@... Date: Sat, 23 May 2009 12:52:15 +0000 Subject: [WanderlodgeForum] Explosive Post⦠Propane Grill Explosive Post⦠Propane Grill I decided to get a grill for the coach and found a nice little 304 stainless infrared unit called the Stow- N- Go on sale at West Marine on sale for just under $100 < http://tinyurl. The grill is set up to run on small propane bottles and this works fine. Like many off the shelf grills, this unit comes equipped with a high-pressure regulator and in this case the control is on the regulator itself. I wanted to get a hose and fittings to use with the coach's dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. I went to the hardware store and told the hardware man what I wanted to do and he said "Son, I got hose and fittings, but I don't want assist you in making a bomb. You best go talk with a propane man. I started doing some reading and spoke with a couple of seasoned propane specialists and the both sources stated to go with low pressure. This is the safe way and the right to do it. Therefore, one needs to MODIFY the GRILL to accommodate the factory RV system NOT the other way around. More than once I have heard some members talk about modifying the coach's propane system to accommodate the grill because they were not getting sufficient pressure from the on board outlet. This is a real concern to me. Perhaps I'm making a big deal out of something that is no big deal, but I ain't taking chances with propane gas NO SIR! With that, I started investigating what I need to do to use the Bar-B-Q outlet from the coach and learned that the coach is set up with a low-pressure regulator (6 ounces -10.5 inches water column). Apparently this is an industry standard for large RV systems and the safest way to run a grill off a large tank. This is similar to residential installations. "Another often asked question is "I have a low pressure regulator but it does not seem to supply enough gas for my appliance." Unfortunately, many of the preset low pressure regulators available in the marketplace use 1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT (normal pipe thread) outlet on the propane regulator. There is a limit to the volume of gas that can be delivered through this small ID hose at a fixed low propane pressure of 6 ounces . What can you do? Use a low pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The amount of propane that can be delivered to the appliance is increased by a factor of 2.26 so the chances of starving your appliance for propane are greatly diminished. GasHosesandRegulato http://www.gashoses So, from this I conclude the best way to set up my grill is to ⢠Eliminate the high pressure regulator at the grill ⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID ⢠Low pressure hose 3/8" ID ⢠Install control valve between regulator and grill If I am wrong about this please let me know. Your comments and constructive criticism are always welcome. Wishing you all a happy and safe Memorial Day! NH Bill 1983 FC 35 "Casa Billisa" Hotmail® has ever-growing storage! Donât worry about storage limits. Check it out. |
05-23-2009, 05:40
Bill - If your '83 propane system is set up the same as our 84, then the
regulator at the tank has an output pressure of 1 or 2 PSI. There is a second regulator behind the fridge with 10.5" output. The system is plumbed that way in order to flow enough propane (higher pressure = higher volume for a given pipe size) to supply the 5 branch lines after the 10.5" regulator. The BB setup is just like any other two-stage regulator except the two stages are many feet apart instead of all being in the same casting. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Bill Garamella" wrote: > > Explosive Post Propane Grill > > I decided to get a grill for the coach and found a nice little 304 stainless infrared unit called the Stow- N- Go on sale at West Marine on sale for just under $100 < http://tinyurl.com/qndj25 >. It works great and is small enough to fit in front basement of our FC, gets real hot fast and cools off fast too and temp is easy to control and cleans up nicely. Although its not heavy duty, its beefy enough (pun intended). > > The grill is set up to run on small propane bottles and this works fine. Like many off the shelf grills, this unit comes equipped with a high-pressure regulator and in this case the control is on the regulator itself. I wanted to get a hose and fittings to use with the coach's dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > > I went to the hardware store and told the hardware man what I wanted to do and he said "Son, I got hose and fittings, but I don't want assist you in making a bomb. You best go talk with a propane man. > > I started doing some reading and spoke with a couple of seasoned propane specialists and the both sources stated to go with low pressure. This is the safe way and the right to do it. Therefore, one needs to MODIFY the GRILL to accommodate the factory RV system NOT the other way around. > > More than once I have heard some members talk about modifying the coach's propane system to accommodate the grill because they were not getting sufficient pressure from the on board outlet. This is a real concern to me. Perhaps I'm making a big deal out of something that is no big deal, but I ain't taking chances with propane gas NO SIR! > > With that, I started investigating what I need to do to use the Bar-B-Q outlet from the coach and learned that the coach is set up with a low-pressure regulator (6 ounces -10.5 inches water column). Apparently this is an industry standard for large RV systems and the safest way to run a grill off a large tank. This is similar to residential installations. > > "Another often asked question is "I have a low pressure regulator but it does not seem to supply enough gas for my appliance." Unfortunately, many of the preset low pressure regulators available in the marketplace use 1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT (normal pipe thread) outlet on the propane regulator. There is a limit to the volume of gas that can be delivered through this small ID hose at a fixed low propane pressure of 6 ounces . What can you do? Use a low pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The amount of propane that can be delivered to the appliance is increased by a factor of 2.26 so the chances of starving your appliance for propane are greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet low pressure gas regulators and 3/8"ID low pressure hoses for this very reason. Our grey hose carries UL , CSA, and American Gas Association approvals and is designed to supply up to about 100,000 btu/hr of propane gas." > > http://www.gashosesandregulators.com/pro...facts.html > > So, from this I conclude the best way to set up my grill is to > > ⢠Eliminate the high pressure regulator at the grill > ⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID > ⢠Low pressure hose 3/8" ID > ⢠Install control valve between regulator and grill > > If I am wrong about this please let me know. Your comments and constructive criticism are always welcome. > > Wishing you all a happy and safe Memorial Day! > > NH Bill 1983 FC 35 "Casa Billisa" > |
05-23-2009, 17:13
Bill that's the grill I use or a close China reproduction of it I got at Lowes.
I had an industrial hose shop (the Hoseman Riverside,CA) build the hose long enough to move the grill to a bench 8 feet away from the bus. I got the fitting to match the bus outlet from http://www.mbsturgis.com/ I am not sure your configuration is the same. I use the regulator that came with the appliance which I can continue to run off of a bottle if I want to place the grill more remote to the bus. I can shut off the gas at the fitting outlet prior to the appliance regulator and the grill will burn for another 10 min at full tilt. if I dont burn it off gas pressure, there is a big freeze as I let the pressure out during disconnect. My problem with leaving the hooked up grill in the bay is there is no vent in the floor for falling gas. Greg ofTim&Greg --- In WanderlodgeForum@yahoogroups.com, "Bill Garamella" wrote: > > Explosive Post Propane Grill > > I decided to get a grill for the coach and found a nice little 304 stainless infrared unit called the Stow- N- Go on sale at West Marine on sale for just under $100 < http://tinyurl.com/qndj25 >. It works great and is small enough to fit in front basement of our FC, gets real hot fast and cools off fast too and temp is easy to control and cleans up nicely. Although its not heavy duty, its beefy enough (pun intended). > > The grill is set up to run on small propane bottles and this works fine. Like many off the shelf grills, this unit comes equipped with a high-pressure regulator and in this case the control is on the regulator itself. I wanted to get a hose and fittings to use with the coach's dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > > I went to the hardware store and told the hardware man what I wanted to do and he said "Son, I got hose and fittings, but I don't want assist you in making a bomb. You best go talk with a propane man. > > I started doing some reading and spoke with a couple of seasoned propane specialists and the both sources stated to go with low pressure. This is the safe way and the right to do it. Therefore, one needs to MODIFY the GRILL to accommodate the factory RV system NOT the other way around. > > More than once I have heard some members talk about modifying the coach's propane system to accommodate the grill because they were not getting sufficient pressure from the on board outlet. This is a real concern to me. Perhaps I'm making a big deal out of something that is no big deal, but I ain't taking chances with propane gas NO SIR! > > With that, I started investigating what I need to do to use the Bar-B-Q outlet from the coach and learned that the coach is set up with a low-pressure regulator (6 ounces -10.5 inches water column). Apparently this is an industry standard for large RV systems and the safest way to run a grill off a large tank. This is similar to residential installations. > > "Another often asked question is "I have a low pressure regulator but it does not seem to supply enough gas for my appliance." Unfortunately, many of the preset low pressure regulators available in the marketplace use 1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT (normal pipe thread) outlet on the propane regulator. There is a limit to the volume of gas that can be delivered through this small ID hose at a fixed low propane pressure of 6 ounces . What can you do? Use a low pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The amount of propane that can be delivered to the appliance is increased by a factor of 2.26 so the chances of starving your appliance for propane are greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet low pressure gas regulators and 3/8"ID low pressure hoses for this very reason. Our grey hose carries UL , CSA, and American Gas Association approvals and is designed to supply up to about 100,000 btu/hr of propane gas." > > http://www.gashosesandregulators.com/pro...facts.html > > So, from this I conclude the best way to set up my grill is to > > ⢠Eliminate the high pressure regulator at the grill > ⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID > ⢠Low pressure hose 3/8" ID > ⢠Install control valve between regulator and grill > > If I am wrong about this please let me know. Your comments and constructive criticism are always welcome. > > Wishing you all a happy and safe Memorial Day! > > NH Bill 1983 FC 35 "Casa Billisa" > |
05-24-2009, 03:08
Greg,
Based on my understanding of your description, it sounds like you have high pressure coming off the coach to the high pressure regulator on the grill. Is this so? Or, did you install a low pressure regulator with a by pass and control unit to accommodate low pressure line off the coach? Again, my understanding about safety is that the line feeding the grill from the propane system on the coach needs to be low pressure. I really want to be clear about this before I start connecting a grill to my coach's propane system. The small bottles work great and provide another redundancy but take up a little more room and cost per gallon of propane is much higher. I have no idea how long one of those little bottles will burn. Do you? Thanks Bill > > Bill that's the grill I use or a close China reproduction of it I got at Lowes. I had an industrial hose shop (the Hoseman Riverside,CA) build the hose long enough to move the grill to a bench 8 feet away from the bus. I got the fitting to match the bus outlet from http://www.mbsturgis.com/ I am not sure your configuration is the same. I use the regulator that came with the appliance which I can continue to run off of a bottle if I want to place the grill more remote to the bus. > I can shut off the gas at the fitting outlet prior to the appliance regulator and the grill will burn for another 10 min at full tilt. if I dont burn it off gas pressure, there is a big freeze as I let the pressure out during disconnect. > My problem with leaving the hooked up grill in the bay is there is no vent in the floor for falling gas. > Greg > ofTim&Greg > --- In WanderlodgeForum@yahoogroups.com, "Bill Garamella" wrote: > > > > Explosive Post Propane Grill > > > > I decided to get a grill for the coach and found a nice little 304 stainless infrared unit called the Stow- N- Go on sale at West Marine on sale for just under $100 < http://tinyurl.com/qndj25 >. It works great and is small enough to fit in front basement of our FC, gets real hot fast and cools off fast too and temp is easy to control and cleans up nicely. Although its not heavy duty, its beefy enough (pun intended). > > > > The grill is set up to run on small propane bottles and this works fine. Like many off the shelf grills, this unit comes equipped with a high-pressure regulator and in this case the control is on the regulator itself. I wanted to get a hose and fittings to use with the coach's dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > > > > I went to the hardware store and told the hardware man what I wanted to do and he said "Son, I got hose and fittings, but I don't want assist you in making a bomb. You best go talk with a propane man. > > > > I started doing some reading and spoke with a couple of seasoned propane specialists and the both sources stated to go with low pressure. This is the safe way and the right to do it. Therefore, one needs to MODIFY the GRILL to accommodate the factory RV system NOT the other way around. > > > > More than once I have heard some members talk about modifying the coach's propane system to accommodate the grill because they were not getting sufficient pressure from the on board outlet. This is a real concern to me. Perhaps I'm making a big deal out of something that is no big deal, but I ain't taking chances with propane gas NO SIR! > > > > With that, I started investigating what I need to do to use the Bar-B-Q outlet from the coach and learned that the coach is set up with a low-pressure regulator (6 ounces -10.5 inches water column). Apparently this is an industry standard for large RV systems and the safest way to run a grill off a large tank. This is similar to residential installations. > > > > "Another often asked question is "I have a low pressure regulator but it does not seem to supply enough gas for my appliance." Unfortunately, many of the preset low pressure regulators available in the marketplace use 1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT (normal pipe thread) outlet on the propane regulator. There is a limit to the volume of gas that can be delivered through this small ID hose at a fixed low propane pressure of 6 ounces . What can you do? Use a low pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The amount of propane that can be delivered to the appliance is increased by a factor of 2.26 so the chances of starving your appliance for propane are greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet low pressure gas regulators and 3/8"ID low pressure hoses for this very reason. Our grey hose carries UL , CSA, and American Gas Association approvals and is designed to supply up to about 100,000 btu/hr of propane gas." > > > > http://www.gashosesandregulators.com/pro...facts.html > > > > So, from this I conclude the best way to set up my grill is to > > > > ⢠Eliminate the high pressure regulator at the grill > > ⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID > > ⢠Low pressure hose 3/8" ID > > ⢠Install control valve between regulator and grill > > > > If I am wrong about this please let me know. Your comments and constructive criticism are always welcome. > > > > Wishing you all a happy and safe Memorial Day! > > > > NH Bill 1983 FC 35 "Casa Billisa" > > > |
05-24-2009, 04:48
Bill it sounds like I do have high pressure to the outlet???? I am using the
same regulator at the grill that I screw onto a bottle. I found a fitting that mimics a bottle and had that put on one end of a 8 foot hose and at the other end I had a m/t pressed on the screwed on a sturgis fitting over that. when you couple the sturgis (like an airline shop coupling) you must then throw a ball valve lever to gate the gas and at the same time also lock the fitting/coupling/connection secure. The more I think about the high pressure and gas line safety, the better Jack in the box hamburgers taste. Greg ofTim&Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, "Bill Garamella" wrote: > > Greg, > > Based on my understanding of your description, it sounds like you have high pressure coming off the coach to the high pressure regulator on the grill. Is this so? > > Or, did you install a low pressure regulator with a by pass and control unit to accommodate low pressure line off the coach? > > Again, my understanding about safety is that the line feeding the grill from the propane system on the coach needs to be low pressure. > > I really want to be clear about this before I start connecting a grill to my coach's propane system. > > The small bottles work great and provide another redundancy but take up a little more room and cost per gallon of propane is much higher. I have no idea how long one of those little bottles will burn. Do you? > > Thanks Bill > > > > > > Bill that's the grill I use or a close China reproduction of it I got at Lowes. I had an industrial hose shop (the Hoseman Riverside,CA) build the hose long enough to move the grill to a bench 8 feet away from the bus. I got the fitting to match the bus outlet from http://www.mbsturgis.com/ I am not sure your configuration is the same. I use the regulator that came with the appliance which I can continue to run off of a bottle if I want to place the grill more remote to the bus. > > I can shut off the gas at the fitting outlet prior to the appliance regulator and the grill will burn for another 10 min at full tilt. if I dont burn it off gas pressure, there is a big freeze as I let the pressure out during disconnect. > > My problem with leaving the hooked up grill in the bay is there is no vent in the floor for falling gas. > > Greg > > ofTim&Greg > > --- In WanderlodgeForum@yahoogroups.com, "Bill Garamella" wrote: > > > > > > Explosive Post Propane Grill > > > > > > I decided to get a grill for the coach and found a nice little 304 stainless infrared unit called the Stow- N- Go on sale at West Marine on sale for just under $100 < http://tinyurl.com/qndj25 >. It works great and is small enough to fit in front basement of our FC, gets real hot fast and cools off fast too and temp is easy to control and cleans up nicely. Although its not heavy duty, its beefy enough (pun intended). > > > > > > The grill is set up to run on small propane bottles and this works fine. Like many off the shelf grills, this unit comes equipped with a high-pressure regulator and in this case the control is on the regulator itself. I wanted to get a hose and fittings to use with the coach's dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > > > > > > I went to the hardware store and told the hardware man what I wanted to do and he said "Son, I got hose and fittings, but I don't want assist you in making a bomb. You best go talk with a propane man. > > > > > > I started doing some reading and spoke with a couple of seasoned propane specialists and the both sources stated to go with low pressure. This is the safe way and the right to do it. Therefore, one needs to MODIFY the GRILL to accommodate the factory RV system NOT the other way around. > > > > > > More than once I have heard some members talk about modifying the coach's propane system to accommodate the grill because they were not getting sufficient pressure from the on board outlet. This is a real concern to me. Perhaps I'm making a big deal out of something that is no big deal, but I ain't taking chances with propane gas NO SIR! > > > > > > With that, I started investigating what I need to do to use the Bar-B-Q outlet from the coach and learned that the coach is set up with a low-pressure regulator (6 ounces -10.5 inches water column). Apparently this is an industry standard for large RV systems and the safest way to run a grill off a large tank. This is similar to residential installations. > > > > > > "Another often asked question is "I have a low pressure regulator but it does not seem to supply enough gas for my appliance." Unfortunately, many of the preset low pressure regulators available in the marketplace use 1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT (normal pipe thread) outlet on the propane regulator. There is a limit to the volume of gas that can be delivered through this small ID hose at a fixed low propane pressure of 6 ounces . What can you do? Use a low pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The amount of propane that can be delivered to the appliance is increased by a factor of 2.26 so the chances of starving your appliance for propane are greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet low pressure gas regulators and 3/8"ID low pressure hoses for this very reason. Our grey hose carries UL , CSA, and American Gas Association approvals and is designed to supply up to about 100,000 btu/hr of propane gas." > > > > > > http://www.gashosesandregulators.com/pro...facts.html > > > > > > So, from this I conclude the best way to set up my grill is to > > > > > > ⢠Eliminate the high pressure regulator at the grill > > > ⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID > > > ⢠Low pressure hose 3/8" ID > > > ⢠Install control valve between regulator and grill > > > > > > If I am wrong about this please let me know. Your comments and constructive criticism are always welcome. > > > > > > Wishing you all a happy and safe Memorial Day! > > > > > > NH Bill 1983 FC 35 "Casa Billisa" > > > > > > |
05-24-2009, 06:55
Hi All:
The regulator is responsible for reducing the containerâs variable high pressure that is created by the âboilingâ of propane liquid to a low pressure usable by the individual appliances. To ensure that the propane system has the correct working pressure, regulators are required. The primary system regulator, located at the container(s), is required to be a two-stage regulator. This two-stage regulator can be an individual device that incorpo-rates both regulators, or two separate components. The first-stage regulator reduces container pressure to about 10 psig. The second-stage regulator reduces the 10 psig to a little over 6 ounces of pressure (10 to 14 inches water column). Off the ASME tank there is the Primary regulator and each end point, such as, BBQ Grill, Appliances, has a separate secondary regulator on Birds. So the BBQ grill line, unless modified, is set with the secondary regulator and should be ready for use. A manometer will check the proper inches of water column, which is 11 inches of WC with 1/2 to 3/4 of LP appliances being in use. If a new line is added or an old one plugged be sure to use the approved "yellow" teflon tape for LP. And always be sure to do a leak check after. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 12:52 PM 5/23/2009 +0000, you wrote: >Explosive Post Propane Grill > >I decided to get a grill for the coach and found a nice little 304 >stainless infrared unit called the Stow- N- Go on sale at West Marine on >sale for just under $100 < http://tinyurl.com/qndj25 >. It works great >and is small enough to fit in front basement of our FC, gets real hot fast >and cools off fast too and temp is easy to control and cleans up >nicely. Although its not heavy duty, its beefy enough (pun intended). > >The grill is set up to run on small propane bottles and this works fine. >Like many off the shelf grills, this unit comes equipped with a >high-pressure regulator and in this case the control is on the regulator >itself. I wanted to get a hose and fittings to use with the coach's >dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > >I went to the hardware store and told the hardware man what I wanted to do >and he said "Son, I got hose and fittings, but I don't want assist you in >making a bomb. You best go talk with a propane man. > >I started doing some reading and spoke with a couple of seasoned propane >specialists and the both sources stated to go with low pressure. This is >the safe way and the right to do it. Therefore, one needs to MODIFY the >GRILL to accommodate the factory RV system NOT the other way around. > >More than once I have heard some members talk about modifying the coach's >propane system to accommodate the grill because they were not getting >sufficient pressure from the on board outlet. This is a real concern to >me. Perhaps I'm making a big deal out of something that is no big deal, >but I ain't taking chances with propane gas NO SIR! > >With that, I started investigating what I need to do to use the Bar-B-Q >outlet from the coach and learned that the coach is set up with a >low-pressure regulator (6 ounces -10.5 inches water column). Apparently >this is an industry standard for large RV systems and the safest way to >run a grill off a large tank. This is similar to residential installations. > >"Another often asked question is "I have a low pressure regulator but it >does not seem to supply enough gas for my appliance." Unfortunately, many >of the preset low pressure regulators available in the marketplace use >1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT >(normal pipe thread) outlet on the propane regulator. There is a limit to >the volume of gas that can be delivered through this small ID hose at a >fixed low propane pressure of 6 ounces . What can you do? Use a low >pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The >amount of propane that can be delivered to the appliance is increased by a >factor of 2.26 so the chances of starving your appliance for propane are >greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet >low pressure gas regulators and 3/8"ID low pressure hoses for this very >reason. Our grey hose carries UL , CSA, and American Gas Association >approvals and is designed to supply up to about 100,000 btu/hr of propane gas." > >http://www.gashosesandregulators.com/pro...facts.html > >So, from this I conclude the best way to set up my grill is to > >⢠Eliminate the high pressure regulator at the grill >⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID >⢠Low pressure hose 3/8" ID >⢠Install control valve between regulator and grill > >If I am wrong about this please let me know. Your comments and >constructive criticism are always welcome. > >Wishing you all a happy and safe Memorial Day! > >NH Bill 1983 FC 35 "Casa Billisa" > > > |
05-25-2009, 14:20
Hi Ralph,
You said, Off the ASME tank there is the Primary regulator and each end point, such as, BBQ Grill, Appliances, has a separate secondary regulator on Birds. So the BBQ grill line, unless modified, is set with the secondary regulator and should be ready for use. This all makes sense. I think where I ran into problems and got confused is this. It seems to me that all the small portable BBQ's that you buy are designed to work off the portable propane bottles. It also seems that have the built into them the Primary and Secondary regulator. If you try to work them off the the stock BBQ line from the bus, I could never get a good flame. So I think NH Bill's original question is how do we modify the new BBQ's that they will be safe and still work off of the OEM BBQ grill line? Tom Sorrentino 1987 PT 38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" wrote: > > Hi All: > > The regulator is responsible for reducing the container's variable high > pressure that > is created by the "boiling" of propane liquid to a low pressure usable by > the individual > appliances. > To ensure that the propane system has the correct working pressure, > regulators are > required. The primary system regulator, located at the container(s), is > required to be a > two-stage regulator. This two-stage regulator can be an individual device > that incorpo-rates > both regulators, or two separate components. > The first-stage regulator reduces container pressure to about 10 psig. The > second-stage > regulator reduces the 10 psig to a little over 6 ounces of pressure (10 to > 14 inches > water column). > > Off the ASME tank there is the Primary regulator and each end point, such > as, BBQ Grill, Appliances, has a separate secondary regulator on Birds. So > the BBQ grill line, unless modified, is set with the secondary regulator > and should be ready for use. A manometer will check the proper inches of > water column, which is 11 inches of WC with 1/2 to 3/4 of LP appliances > being in use. > > If a new line is added or an old one plugged be sure to use the approved > "yellow" teflon tape for LP. And always be sure to do a leak check after. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 12:52 PM 5/23/2009 +0000, you wrote: > >Explosive Post Propane Grill > > > >I decided to get a grill for the coach and found a nice little 304 > >stainless infrared unit called the Stow- N- Go on sale at West Marine on > >sale for just under $100 < http://tinyurl.com/qndj25 >. It works great > >and is small enough to fit in front basement of our FC, gets real hot fast > >and cools off fast too and temp is easy to control and cleans up > >nicely. Although its not heavy duty, its beefy enough (pun intended). > > > >The grill is set up to run on small propane bottles and this works fine. > >Like many off the shelf grills, this unit comes equipped with a > >high-pressure regulator and in this case the control is on the regulator > >itself. I wanted to get a hose and fittings to use with the coach's > >dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > > > >I went to the hardware store and told the hardware man what I wanted to do > >and he said "Son, I got hose and fittings, but I don't want assist you in > >making a bomb. You best go talk with a propane man. > > > >I started doing some reading and spoke with a couple of seasoned propane > >specialists and the both sources stated to go with low pressure. This is > >the safe way and the right to do it. Therefore, one needs to MODIFY the > >GRILL to accommodate the factory RV system NOT the other way around. > > > >More than once I have heard some members talk about modifying the coach's > >propane system to accommodate the grill because they were not getting > >sufficient pressure from the on board outlet. This is a real concern to > >me. Perhaps I'm making a big deal out of something that is no big deal, > >but I ain't taking chances with propane gas NO SIR! > > > >With that, I started investigating what I need to do to use the Bar-B-Q > >outlet from the coach and learned that the coach is set up with a > >low-pressure regulator (6 ounces -10.5 inches water column). Apparently > >this is an industry standard for large RV systems and the safest way to > >run a grill off a large tank. This is similar to residential installations. > > > >"Another often asked question is "I have a low pressure regulator but it > >does not seem to supply enough gas for my appliance." Unfortunately, many > >of the preset low pressure regulators available in the marketplace use > >1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT > >(normal pipe thread) outlet on the propane regulator. There is a limit to > >the volume of gas that can be delivered through this small ID hose at a > >fixed low propane pressure of 6 ounces . What can you do? Use a low > >pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The > >amount of propane that can be delivered to the appliance is increased by a > >factor of 2.26 so the chances of starving your appliance for propane are > >greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet > >low pressure gas regulators and 3/8"ID low pressure hoses for this very > >reason. Our grey hose carries UL , CSA, and American Gas Association > >approvals and is designed to supply up to about 100,000 btu/hr of propane gas." > > > >http://www.gashosesandregulators.com/pro...facts.html > > > >So, from this I conclude the best way to set up my grill is to > > > >⢠Eliminate the high pressure regulator at the grill > >⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID > >⢠Low pressure hose 3/8" ID > >⢠Install control valve between regulator and grill > > > >If I am wrong about this please let me know. Your comments and > >constructive criticism are always welcome. > > > >Wishing you all a happy and safe Memorial Day! > > > >NH Bill 1983 FC 35 "Casa Billisa" > > > > > > > > > > |
05-25-2009, 17:12
Get a low pressure regulator for the bbq
--- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" wrote: > > Hi Ralph, > > You said, > > Off the ASME tank there is the Primary regulator and each end point, such > as, BBQ Grill, Appliances, has a separate secondary regulator on Birds. So > the BBQ grill line, unless modified, is set with the secondary regulator > and should be ready for use. > > This all makes sense. I think where I ran into problems and got confused is this. It seems to me that all the small portable BBQ's that you buy are designed to work off the portable propane bottles. It also seems that have the built into them the Primary and Secondary regulator. If you try to work them off the the stock BBQ line from the bus, I could never get a good flame. So I think NH Bill's original question is how do we modify the new BBQ's that they will be safe and still work off of the OEM BBQ grill line? > > Tom Sorrentino > 1987 PT 38 > Bedford Hills, NY > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" wrote: > > > > Hi All: > > > > The regulator is responsible for reducing the container's variable high > > pressure that > > is created by the "boiling" of propane liquid to a low pressure usable by > > the individual > > appliances. > > To ensure that the propane system has the correct working pressure, > > regulators are > > required. The primary system regulator, located at the container(s), is > > required to be a > > two-stage regulator. This two-stage regulator can be an individual device > > that incorpo-rates > > both regulators, or two separate components. > > The first-stage regulator reduces container pressure to about 10 psig. The > > second-stage > > regulator reduces the 10 psig to a little over 6 ounces of pressure (10 to > > 14 inches > > water column). > > > > Off the ASME tank there is the Primary regulator and each end point, such > > as, BBQ Grill, Appliances, has a separate secondary regulator on Birds. So > > the BBQ grill line, unless modified, is set with the secondary regulator > > and should be ready for use. A manometer will check the proper inches of > > water column, which is 11 inches of WC with 1/2 to 3/4 of LP appliances > > being in use. > > > > If a new line is added or an old one plugged be sure to use the approved > > "yellow" teflon tape for LP. And always be sure to do a leak check after. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 12:52 PM 5/23/2009 +0000, you wrote: > > >Explosive Post Propane Grill > > > > > >I decided to get a grill for the coach and found a nice little 304 > > >stainless infrared unit called the Stow- N- Go on sale at West Marine on > > >sale for just under $100 < http://tinyurl.com/qndj25 >. It works great > > >and is small enough to fit in front basement of our FC, gets real hot fast > > >and cools off fast too and temp is easy to control and cleans up > > >nicely. Although its not heavy duty, its beefy enough (pun intended). > > > > > >The grill is set up to run on small propane bottles and this works fine. > > >Like many off the shelf grills, this unit comes equipped with a > > >high-pressure regulator and in this case the control is on the regulator > > >itself. I wanted to get a hose and fittings to use with the coach's > > >dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > > > > > >I went to the hardware store and told the hardware man what I wanted to do > > >and he said "Son, I got hose and fittings, but I don't want assist you in > > >making a bomb. You best go talk with a propane man. > > > > > >I started doing some reading and spoke with a couple of seasoned propane > > >specialists and the both sources stated to go with low pressure. This is > > >the safe way and the right to do it. Therefore, one needs to MODIFY the > > >GRILL to accommodate the factory RV system NOT the other way around. > > > > > >More than once I have heard some members talk about modifying the coach's > > >propane system to accommodate the grill because they were not getting > > >sufficient pressure from the on board outlet. This is a real concern to > > >me. Perhaps I'm making a big deal out of something that is no big deal, > > >but I ain't taking chances with propane gas NO SIR! > > > > > >With that, I started investigating what I need to do to use the Bar-B-Q > > >outlet from the coach and learned that the coach is set up with a > > >low-pressure regulator (6 ounces -10.5 inches water column). Apparently > > >this is an industry standard for large RV systems and the safest way to > > >run a grill off a large tank. This is similar to residential installations. > > > > > >"Another often asked question is "I have a low pressure regulator but it > > >does not seem to supply enough gas for my appliance." Unfortunately, many > > >of the preset low pressure regulators available in the marketplace use > > >1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT > > >(normal pipe thread) outlet on the propane regulator. There is a limit to > > >the volume of gas that can be delivered through this small ID hose at a > > >fixed low propane pressure of 6 ounces . What can you do? Use a low > > >pressure regulator with a 3/8"ID gas outlet and a gas hose of 3/8"ID. The > > >amount of propane that can be delivered to the appliance is increased by a > > >factor of 2.26 so the chances of starving your appliance for propane are > > >greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet > > >low pressure gas regulators and 3/8"ID low pressure hoses for this very > > >reason. Our grey hose carries UL , CSA, and American Gas Association > > >approvals and is designed to supply up to about 100,000 btu/hr of propane gas." > > > > > >http://www.gashosesandregulators.com/pro...facts.html > > > > > >So, from this I conclude the best way to set up my grill is to > > > > > >⢠Eliminate the high pressure regulator at the grill > > >⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID > > >⢠Low pressure hose 3/8" ID > > >⢠Install control valve between regulator and grill > > > > > >If I am wrong about this please let me know. Your comments and > > >constructive criticism are always welcome. > > > > > >Wishing you all a happy and safe Memorial Day! > > > > > >NH Bill 1983 FC 35 "Casa Billisa" > > > > > > > > > > > > > > > > > > |
05-26-2009, 02:34
Hi Tom:
I have had to have LP hoses made up to connect the Coach quick connect to a grill. I change the grill in put piping by removing the "bottle" regulator, installing a valve, (simple T handle shut off type,) I use the new T handle valve to regulate the flame in the grill, Low/Medium/High. The other end of the hose is connected to the male end of the quick connect. Easy enough to do and can be done safely. Remember to check the LP at the grill for leaks with the T handle valve in the off position. Oh there is also a huge shut off valve on most Birds for the grill regulator that may need to be opened. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 02:20 AM 5/26/2009 +0000, you wrote: >Hi Ralph, > >You said, > >Off the ASME tank there is the Primary regulator and each end point, such >as, BBQ Grill, Appliances, has a separate secondary regulator on Birds. So >the BBQ grill line, unless modified, is set with the secondary regulator >and should be ready for use. > >This all makes sense. I think where I ran into problems and got confused >is this. It seems to me that all the small portable BBQ's that you buy are >designed to work off the portable propane bottles. It also seems that have >the built into them the Primary and Secondary regulator. If you try to >work them off the the stock BBQ line from the bus, I could never get a >good flame. So I think NH Bill's original question is how do we modify the >new BBQ's that they will be safe and still work off of the OEM BBQ grill line? > >Tom Sorrentino >1987 PT 38 >Bedford Hills, NY > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hi All: > > > > The regulator is responsible for reducing the container's variable high > > pressure that > > is created by the "boiling" of propane liquid to a low pressure usable by > > the individual > > appliances. > > To ensure that the propane system has the correct working pressure, > > regulators are > > required. The primary system regulator, located at the container(s), is > > required to be a > > two-stage regulator. This two-stage regulator can be an individual device > > that incorpo-rates > > both regulators, or two separate components. > > The first-stage regulator reduces container pressure to about 10 psig. The > > second-stage > > regulator reduces the 10 psig to a little over 6 ounces of pressure (10 to > > 14 inches > > water column). > > > > Off the ASME tank there is the Primary regulator and each end point, such > > as, BBQ Grill, Appliances, has a separate secondary regulator on Birds. So > > the BBQ grill line, unless modified, is set with the secondary regulator > > and should be ready for use. A manometer will check the proper inches of > > water column, which is 11 inches of WC with 1/2 to 3/4 of LP appliances > > being in use. > > > > If a new line is added or an old one plugged be sure to use the approved > > "yellow" teflon tape for LP. And always be sure to do a leak check after. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 12:52 PM 5/23/2009 +0000, you wrote: > > >Explosive Post Propane Grill > > > > > >I decided to get a grill for the coach and found a nice little 304 > > >stainless infrared unit called the Stow- N- Go on sale at West Marine on > > >sale for just under $100 < http://tinyurl.com/qndj25 >. It works great > > >and is small enough to fit in front basement of our FC, gets real hot > fast > > >and cools off fast too and temp is easy to control and cleans up > > >nicely. Although its not heavy duty, its beefy enough (pun intended). > > > > > >The grill is set up to run on small propane bottles and this works fine. > > >Like many off the shelf grills, this unit comes equipped with a > > >high-pressure regulator and in this case the control is on the regulator > > >itself. I wanted to get a hose and fittings to use with the coach's > > >dedicated Bar-B-Q valve. I just thought it would be a simple thing to do. > > > > > >I went to the hardware store and told the hardware man what I wanted > to do > > >and he said "Son, I got hose and fittings, but I don't want assist you in > > >making a bomb. You best go talk with a propane man. > > > > > >I started doing some reading and spoke with a couple of seasoned propane > > >specialists and the both sources stated to go with low pressure. This is > > >the safe way and the right to do it. Therefore, one needs to MODIFY the > > >GRILL to accommodate the factory RV system NOT the other way around. > > > > > >More than once I have heard some members talk about modifying the coach's > > >propane system to accommodate the grill because they were not getting > > >sufficient pressure from the on board outlet. This is a real concern to > > >me. Perhaps I'm making a big deal out of something that is no big deal, > > >but I ain't taking chances with propane gas NO SIR! > > > > > >With that, I started investigating what I need to do to use the Bar-B-Q > > >outlet from the coach and learned that the coach is set up with a > > >low-pressure regulator (6 ounces -10.5 inches water column). Apparently > > >this is an industry standard for large RV systems and the safest way to > > >run a grill off a large tank. This is similar to residential > installations. > > > > > >"Another often asked question is "I have a low pressure regulator but it > > >does not seem to supply enough gas for my appliance." Unfortunately, > many > > >of the preset low pressure regulators available in the marketplace use > > >1/4"ID hose and some are attached to a propane regulator with a 1/4" NPT > > >(normal pipe thread) outlet on the propane regulator. There is a > limit to > > >the volume of gas that can be delivered through this small ID hose at a > > >fixed low propane pressure of 6 ounces . What can you do? Use a low > > >pressure regulator with a 3/8"ID gas outlet and a gas hose of > 3/8"ID. The > > >amount of propane that can be delivered to the appliance is increased > by a > > >factor of 2.26 so the chances of starving your appliance for propane are > > >greatly diminished. GasHosesandRegulators.com sells only 3/8" NPT outlet > > >low pressure gas regulators and 3/8"ID low pressure hoses for this very > > >reason. Our grey hose carries UL , CSA, and American Gas Association > > >approvals and is designed to supply up to about 100,000 btu/hr of > propane gas." > > > > > >http://www.gashosesandregulators.com/pro...facts.html > > > > > >So, from this I conclude the best way to set up my grill is to > > > > > >⢠Eliminate the high pressure regulator at the grill > > >⢠Use low pressure regulator from coach Bar-B-Q outlet 3/8" ID > > >⢠Low pressure hose 3/8" ID > > >⢠Install control valve between regulator and grill > > > > > >If I am wrong about this please let me know. Your comments and > > >constructive criticism are always welcome. > > > > > >Wishing you all a happy and safe Memorial Day! > > > > > >NH Bill 1983 FC 35 "Casa Billisa" > > > > > > > > > > > > > > > > > > > > > >------------------------------------ > >Yahoo! Groups Links > > > Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma |
