Thinlite
06-17-2009, 03:58
Thinlite
This is the replacement I bought for my 91 - thin-lite IB-116.
Thin-Lite IB-116 Ballast
Thin-Lite Replacement Ballast IB-116
Item# TL-IB-116
Roger Webb
91WL
Cedar Rapids, IA
In a message dated 6/17/2009 1:13:02 P.M. Central Daylight Time, rlf47@... writes:
Mike:
I used a ballast I mean inverter from Steve B to repair the one on a '95.
Though a little modification is needed, but doable. Or you can go to thin
lite to see if they have the board.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 05:40 PM 6/17/2009 +0000, you wrote:
>My 96 42' has a two bulb flourescent fixture oner the dining table. It
>stopped working. I replaced the bulbs and did not cure the problem. The
>light s will flicker when you install the bulbs. I took the center cover
>off of the fixture expecting to see a starter or ballast. There is only
>something that looks like the inards of a tranistor radio mounted in the
>light. Anyone have an idea how to repair. Thanks, Mike McMahan 96 42'
>Wanderlodge
06-17-2009, 05:40
Thinlite
My 96 42' has a two bulb flourescent fixture oner the dining table. It stopped
working. I replaced the bulbs and did not cure the problem. The light s will
flicker when you install the bulbs. I took the center cover off of the fixture
expecting to see a starter or ballast. There is only something that looks like
the inards of a tranistor radio mounted in the light. Anyone have an idea how
to repair. Thanks, Mike McMahan 96 42' Wanderlodge
06-17-2009, 06:10
Thinlite
Mike:
Safe travels,
Duncan, Oklahoma
>Wanderlodge
06-17-2009, 08:48
Thinlite
At the recommendation of a BB owner 2 years back, I went to the thinlite
website, and sent them my inoperable light fixture, which they repaired and
returned it for under $25, in about 10 days time. Check website at
http://www.thinlite.com/faqs.htm#whatw , and look at the warranty topic.
Gary
SOB
> (http://ep.yimg.com/ip/I/wind-sun_2058_1377211)
> Item# TL-IB-116
> _http://store.solar-electric.com/tl-ib-116.html_
> (http://store.solar-electric.com/tl-ib-116.html)
> Roger Webb
> 91WL
> Cedar Rapids, IA
> rlf47@... writes:
> Mike:
> Safe travels,
> Duncan, Oklahoma
> >Wanderlodge
> **************Dell Days of Deals! June 15-24 - A New Deal Everyday!
(http://pr.atwola.com/promoclk/100126575x...tp:%2\
F%2F
> ad.doubleclick.net%2Fclk%3B215692145%3B38015538%3Bh)
