Intertherm A/C shroud
06-12-2005, 07:35
In message #2583 Jeff Miller mentioned that parts are no longer
available for the Intertherm and that shrouds should be salvaged from failed units. The Intertherm on my 89SP works fine but the shroud is coming apart. I am about to strap it together with 100 MPH duct tape but what do I do for a replacement shroud? |
06-12-2005, 14:40
Someone posted a while ago that they were able to get a universal
shroud to work, don't know who or from where, hopefully will read this and re-post. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "fred89sp" wrote: > In message #2583 Jeff Miller mentioned that parts are no longer > available for the Intertherm and that shrouds should be salvaged from > failed units. > > The Intertherm on my 89SP works fine but the shroud is coming apart. > I am about to strap it together with 100 MPH duct tape but what do I > do for a replacement shroud? |
06-12-2005, 16:28
Fred,
I made an AC shroud for our '74 bird when one AC cover went south. The AC was original and worked great....I could not see replacing a good unit. I made the cover of aluminum...it had no rounded corners but did have angles...and looked fine. The home made cover wasn't the prettiest but it was cheap...cost me about $30.00...I have the tools to make it. I called a tin shop and they would make a cover for around $240.00. You might check in your area. Curt Sprenger â87PT38, Anaheim, Calif. fred89sp wrote: > In message #2583 Jeff Miller mentioned that parts are no longer > available for the Intertherm and that shrouds should be salvaged from > failed units. > > The Intertherm on my 89SP works fine but the shroud is coming apart. > I am about to strap it together with 100 MPH duct tape but what do I > do for a replacement shroud? > |
06-12-2005, 22:52
Fred, I am replacing my condensor with a bolt on unit, so the shroud
I took off is available. My coach is a 85FC, and I am not sure that they are the same...look at photo gallery in 85FC33 at my bird, and let me know if they are. My recollection is that the later models were "more square". You can send me your e-mail and I will send you some detailed photos and measurements. Frank Woodbridge, VA. --- In WanderlodgeForum@yahoogroups.com, "fred89sp" wrote: > In message #2583 Jeff Miller mentioned that parts are no longer > available for the Intertherm and that shrouds should be salvaged from > failed units. > > The Intertherm on my 89SP works fine but the shroud is coming apart. > I am about to strap it together with 100 MPH duct tape but what do I > do for a replacement shroud? |
06-12-2005, 23:31
curt,can you even see the differance from the ground? the sheep fence helps
hide all that stuff so well.....randy ----- Original Message ----- From: "Curt Sprenger" To: Sent: Monday, June 13, 2005 12:28 AM Subject: Re: [WanderlodgeForum] Intertherm A/C shroud > Fred, > I made an AC shroud for our '74 bird when one AC cover went south. The > AC was original and worked great....I could not see replacing a good > unit. I made the cover of aluminum...it had no rounded corners but did > have angles...and looked fine. The home made cover wasn't the prettiest > but it was cheap...cost me about $30.00...I have the tools to make it. I > called a tin shop and they would make a cover for around $240.00. You > might check in your area. > > Curt Sprenger â87PT38, Anaheim, Calif. > > > > fred89sp wrote: > >> In message #2583 Jeff Miller mentioned that parts are no longer >> available for the Intertherm and that shrouds should be salvaged from >> failed units. >> >> The Intertherm on my 89SP works fine but the shroud is coming apart. >> I am about to strap it together with 100 MPH duct tape but what do I >> do for a replacement shroud? >> > > > > > > Yahoo! Groups Links > > > > > > > |
06-13-2005, 00:15
That's right. Hardly noticeable. I never painted the cover. If I had one
would not know the difference at all. Curt Sprenger â87PT38, Anaheim, Calif. randydupree wrote: >curt,can you even see the differance from the ground? the sheep fence helps >hide all that stuff so well.....randy >----- Original Message ----- >From: "Curt Sprenger" >To: >Sent: Monday, June 13, 2005 12:28 AM >Subject: Re: [WanderlodgeForum] Intertherm A/C shroud > > > > >>Fred, >>I made an AC shroud for our '74 bird when one AC cover went south. The >>AC was original and worked great....I could not see replacing a good >>unit. I made the cover of aluminum...it had no rounded corners but did >>have angles...and looked fine. The home made cover wasn't the prettiest >>but it was cheap...cost me about $30.00...I have the tools to make it. I >>called a tin shop and they would make a cover for around $240.00. You >>might check in your area. >> >>Curt Sprenger â87PT38, Anaheim, Calif. >> >> >> >>fred89sp wrote: >> >> >> >>>In message #2583 Jeff Miller mentioned that parts are no longer >>>available for the Intertherm and that shrouds should be salvaged from >>>failed units. >>> >>>The Intertherm on my 89SP works fine but the shroud is coming apart. >>>I am about to strap it together with 100 MPH duct tape but what do I >>>do for a replacement shroud? >>> >>> >>> >> >> >> >>Yahoo! Groups Links >> >> >> >> >> >> >> >> >> > > > > > > >Yahoo! Groups Links > > > > > > > > > > -- |
06-13-2005, 00:23
and the one you made will last forever..randy
----- Original Message ----- From: "Curt Sprenger" To: Sent: Monday, June 13, 2005 8:15 AM Subject: Re: [WanderlodgeForum] Intertherm A/C shroud > That's right. Hardly noticeable. I never painted the cover. If I had one > would not know the difference at all. > > Curt Sprenger â87PT38, Anaheim, Calif. > > > randydupree wrote: > >>curt,can you even see the differance from the ground? the sheep fence >>helps >>hide all that stuff so well.....randy >>----- Original Message ----- >>From: "Curt Sprenger" >>To: >>Sent: Monday, June 13, 2005 12:28 AM >>Subject: Re: [WanderlodgeForum] Intertherm A/C shroud >> >> >> >> >>>Fred, >>>I made an AC shroud for our '74 bird when one AC cover went south. The >>>AC was original and worked great....I could not see replacing a good >>>unit. I made the cover of aluminum...it had no rounded corners but did >>>have angles...and looked fine. The home made cover wasn't the prettiest >>>but it was cheap...cost me about $30.00...I have the tools to make it. I >>>called a tin shop and they would make a cover for around $240.00. You >>>might check in your area. >>> >>>Curt Sprenger â87PT38, Anaheim, Calif. >>> >>> >>> >>>fred89sp wrote: >>> >>> >>> >>>>In message #2583 Jeff Miller mentioned that parts are no longer >>>>available for the Intertherm and that shrouds should be salvaged from >>>>failed units. >>>> >>>>The Intertherm on my 89SP works fine but the shroud is coming apart. >>>>I am about to strap it together with 100 MPH duct tape but what do I >>>>do for a replacement shroud? >>>> >>>> >>>> >>> >>> >>> >>>Yahoo! Groups Links >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >>Yahoo! Groups Links >> >> >> >> >> >> >> >> >> >> > > -- > > > > > > > > Yahoo! Groups Links > > > > > > > > |
06-13-2005, 01:19
'85 would not be the intertherm unit.
I do need a couple of parts from the '85, okay if I contact you? - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "fwernlein" wrote: > Fred, I am replacing my condensor with a bolt on unit, so the shroud > I took off is available. My coach is a 85FC, and I am not sure that > they are the same...look at photo gallery in 85FC33 at my bird, and > let me know if they are. My recollection is that the later models > were "more square". You can send me your e-mail and I will send you > some detailed photos and measurements. > > Frank > Woodbridge, VA. > > > > --- In WanderlodgeForum@yahoogroups.com, "fred89sp" > wrote: > > In message #2583 Jeff Miller mentioned that parts are no longer > > available for the Intertherm and that shrouds should be salvaged > from > > failed units. > > > > The Intertherm on my 89SP works fine but the shroud is coming > apart. > > I am about to strap it together with 100 MPH duct tape but what do I > > do for a replacement shroud? |
06-13-2005, 03:17
II believe if I had a shroud that was falling apart and a replacement was
not available I would remove it, fiberglass the inside and then a skim coat to the outside and paint it. Has anyone tried it? I had the same problem with my chassis A/C condensor which is mounted on the roof of older Bluebirds. I made a pattern from the old shroud and made it out of galvanized 14GA metal. Primed it with acid etching primer and painted it. Cant tell the difference between the old or the new except the new has no dents and bangs. tom 1982 FC35 Vernon Center,NY At 05:15 AM 6/13/2005 -0700, you wrote: >That's right. Hardly noticeable. I never painted the cover. If I had one >would not know the difference at all. > >Curt Sprenger '87PT38, Anaheim, Calif. > > >randydupree wrote: > > >curt,can you even see the differance from the ground? the sheep fence helps > >hide all that stuff so well.....randy > >----- Original Message ----- > >From: "Curt Sprenger" > >To: > >Sent: Monday, June 13, 2005 12:28 AM > >Subject: Re: [WanderlodgeForum] Intertherm A/C shroud > > > > > > > > > >>Fred, > >>I made an AC shroud for our '74 bird when one AC cover went south. The > >>AC was original and worked great....I could not see replacing a good > >>unit. I made the cover of aluminum...it had no rounded corners but did > >>have angles...and looked fine. The home made cover wasn't the prettiest > >>but it was cheap...cost me about $30.00...I have the tools to make it. I > >>called a tin shop and they would make a cover for around $240.00. You > >>might check in your area. > >> > >>Curt Sprenger '87PT38, Anaheim, Calif. > >> > >> > >> > >>fred89sp wrote: > >> |
06-13-2005, 12:31
I tried this with some Bondo Home Solutions All Purpose Fiberglass
Resin on a test area that I had scuffed well. The resin did not adhere to the shroud. Is it possible that the resin will not adhere to the plastic used in the shroud? --- In WanderlodgeForum@yahoogroups.com, Tom Warner > II believe if I had a shroud that was falling apart and a replacement was > not available I would remove it, fiberglass the inside and then a skim > coat to the outside and paint it. Has anyone tried it? I had the same > problem with my chassis A/C condensor which is mounted on the roof of older > Bluebirds. I made a pattern from the old shroud and made it out of > galvanized 14GA metal. Primed it with acid etching primer and painted it. > Cant tell the difference between the old or the new except the new has no > dents and bangs. > > tom > 1982 FC35 > Vernon Center,NY > > At 05:15 AM 6/13/2005 -0700, you wrote: > >That's right. Hardly noticeable. I never painted the cover. If I had one > >would not know the difference at all. > > > >Curt Sprenger '87PT38, Anaheim, Calif. > > > > > >randydupree wrote: > > > > >curt,can you even see the differance from the ground? the sheep fence helps > > >hide all that stuff so well.....randy > > >----- Original Message ----- > > >From: "Curt Sprenger" > > >To: > > >Sent: Monday, June 13, 2005 12:28 AM > > >Subject: Re: [WanderlodgeForum] Intertherm A/C shroud > > > > > > > > > > > > > > >>Fred, > > >>I made an AC shroud for our '74 bird when one AC cover went south. The > > >>AC was original and worked great....I could not see replacing a good > > >>unit. I made the cover of aluminum...it had no rounded corners but did > > >>have angles...and looked fine. The home made cover wasn't the prettiest > > >>but it was cheap...cost me about $30.00...I have the tools to make it. I > > >>called a tin shop and they would make a cover for around $240.00. You > > >>might check in your area. > > >> > > >>Curt Sprenger '87PT38, Anaheim, Calif. > > >> > > >> > > >> > > >>fred89sp wrote: > > >> |
