AC compressor bracket
07-04-2009, 03:46
I am having a problem with my Engine A/C compressor bracket the holes became ege
shape and throwing belts. Does anyone have a fix or is the replacement bracket available anywhere? Hisham Amaral 97 Wanderlodge 43' Detroit 60 series engine West Bloomfield, MI 248-935-5390 |
07-04-2009, 05:20
Hisham
I took a look at the A/C bracket on my engine and it seems to be an OE bracket that would be used on most if not all DD series 60 engines.
My first thoughts are a Prevost Factory service center or a Detroit Diesel service facility.Holland MHis another source,if you haven't tried them yet.
Fred & Jeanne Hulse
07-04-2009, 06:44
weld the holes up and redrill. Replace the bolts with ones with no thread near
the wrench end (no thread thru bracket). Bolt shoulder has larger dia. the thread is what is cutting the bracket during vibration. It was probably removed prior and the tec did not replace the lockwasher or use loctight Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" wrote: > > I am having a problem with my Engine A/C compressor bracket the holes became ege shape and throwing belts. Does anyone have a fix or is the replacement bracket available anywhere? > > Hisham Amaral > 97 Wanderlodge 43' > Detroit 60 series engine > West Bloomfield, MI > 248-935-5390 > |
07-04-2009, 07:27
Hish- are you talking about the L-shaped bracket that is used for tensioning? If
so, I would consider welding the egg-shaped area partially closed and re-drilling the hole. You may also be able to drill out the hole and use a bronze bushing to re-size the opening correctly. You may also be able to re-drill the upper bracket and install bushings to correct the problem. I helped Bill Tarrier work on his last week and can see where it's tough to properly tension/tighten the compressor. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" > > I am having a problem with my Engine A/C compressor bracket the holes became ege shape and throwing belts. Does anyone have a fix or is the replacement bracket available anywhere? > > Hisham Amaral > 97 Wanderlodge 43' > Detroit 60 series engine > West Bloomfield, MI > 248-935-5390 > |
07-04-2009, 11:31
--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote:
>Shane I agree with you that the bracket can be welded but There are two parts to weld and the engine bracket and the AC compressor bracket also the bushing must replaced due to extensive wear. With that, welding will be very time consuming, it maybe more time effective just to buy the brackets and end the problem. And maybe not for long the current bracket lasted 55K mile not bad for planned obsolescence. See you at OSH and again thank you for the help. Hish > Hish- are you talking about the L-shaped bracket that is used for tensioning? If so, I would consider welding the egg-shaped area partially closed and re-drilling the hole. You may also be able to drill out the hole and use a bronze bushing to re-size the opening correctly. You may also be able to re-drill the upper bracket and install bushings to correct the problem. I helped Bill Tarrier work on his last week and can see where it's tough to properly tension/tighten the compressor. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" > > > > I am having a problem with my Engine A/C compressor bracket the holes became ege shape and throwing belts. Does anyone have a fix or is the replacement bracket available anywhere? > > > > Hisham Amaral > > 97 Wanderlodge 43' > > Detroit 60 series engine > > West Bloomfield, MI > > 248-935-5390 > > > |
07-04-2009, 11:37
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse"
>Fred Thank you I will try Holland MH in MI they may carry that part in stock. This part is failing too soon the should keep a large inventory on hand. Hisham and Sue Amaral 97 Wanderlodge W. Bloomfield MI > Hisham > I took a look at the A/C bracket on my engine and it seems to be an OE bracket that would be used on most if not all DD series 60 engines. > My first thoughts are a Prevost Factory service center or a Detroit Diesel service facility.Holland MH is another source,if you haven't tried them yet. > > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > |
07-04-2009, 11:47
>Greg The bracket is badly grooved due the vibration from the engine and the overtensioning of the belts by the so call tecks. It would take a good deal of welding and machineing to correct the condition I have. I would be much better off to replace the part and have the assembly done correctly the first time, like you said use shoulder belt, lock washer and lock tite. Thank you and happy 4th of July. Hisham Amaral > 97 Wanderlodge 43' > Detroit 60 series engine > West Bloomfield, MI > 248-935-5390 > weld the holes up and redrill. Replace the bolts with ones with no thread near the wrench end (no thread thru bracket). Bolt shoulder has larger dia. the thread is what is cutting the bracket during vibration. It was probably removed prior and the tec did not replace the lockwasher or use loctight > Greg ofTim&Greg > 94ptca > > --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" > > > > I am having a problem with my Engine A/C compressor bracket the holes became ege shape and throwing belts. Does anyone have a fix or is the replacement bracket available anywhere? > > > > Hisham Amaral > > 97 Wanderlodge 43' > > Detroit 60 series engine > > West Bloomfield, MI > > 248-935-5390 > > > |
07-04-2009, 14:18
For a quick fix you could
;remove a bolt ,one at a time then ;put in a snug washer beween bolt and bracket then ;weld the washer to the bracket. may require a (washer girth) longer bolt? Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > >Greg > The bracket is badly grooved due the vibration from the engine and the overtensioning of the belts by the so call tecks. It would take a good deal of welding and machineing to correct the condition I have. I would be much better off to replace the part and have the assembly done correctly the first time, like you said use shoulder belt, lock washer and lock tite. > > Thank you and happy 4th of July. > Hisham Amaral > > 97 Wanderlodge 43' > > Detroit 60 series engine > > West Bloomfield, MI > > 248-935-5390 > > > > > > weld the holes up and redrill. Replace the bolts with ones with no thread near the wrench end (no thread thru bracket). Bolt shoulder has larger dia. the thread is what is cutting the bracket during vibration. It was probably removed prior and the tec did not replace the lockwasher or use loctight > > Greg ofTim&Greg > > 94ptca > > > > --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" wrote: > > > > > > I am having a problem with my Engine A/C compressor bracket the holes became ege shape and throwing belts. Does anyone have a fix or is the replacement bracket available anywhere? > > > > > > Hisham Amaral > > > 97 Wanderlodge 43' > > > Detroit 60 series engine > > > West Bloomfield, MI > > > 248-935-5390 > > > > > > |
07-09-2009, 16:44
To fix my a/c bracket I took it to a machine shop that bored the engine bracket
holes and the a/c bracket holes to a size that would clean up the hole (so they were round once again.) They then built a new center shaft to fit the new, over sized holes. They also made two thick washers for the end of the shaft. If I remember right it cost me $120 a couple of years ago. Some discussion about the design of the bracket. I believe BB designed this massive bracket and expected the massive size of the shaft to withstand the vibration wear of the engine. It did not work on my rig. After less than 40k miles the bearings were out on the compressor. At 50k I did the repair. I too found all the holes and shaft egg shaped. I believe that the an improvement would be to tighten the "ears" on the bracket by tightening the bolts at the end of the shaft. (Maybe that was the intention of the design???) In any case when I reassembled my repaired bracket I tighten the ear as firmly as I could so that the clamping action of the ears on the engine bracket would minimize the wear on the shaft. If it could be tightened enough, after adjusting the belt tension, there would be no relative motion between the two brackets and the shaft, eliminating wear. One comment: I wish I had removed the gusset from under the two "ears". That way I could have more easily tighten the bolts at the end of the shaft that would have clamp the "ears" on the bracket to the engine side bracket. I didn't remove that (approx. 5/16" x 3/4") gusset. I had to stand on a wrench to tighten the ears after I got the a/c bracket adjusted. I imagine a significant portion of the clamping force is going into bending the ears around the gusset rather than clamping the ears to the engine bracket. Now, I believe the bracket is tightened as if it were one piece, rather than one support and one pivot. Sorry for the long soliloquy. It's a complicated issue relating to what I think was either a design problem or an incorrect BB fabrication/installation on my bus. Eric Perplies 96' 42' WBWL currently in Lolo, MT |
07-12-2009, 00:52
--- In WanderlodgeForum@yahoogroups.com, "Eric Perplies"
>Eric Did you have the machine shop make a new bushing and increase the bolt dia. to next size? If so please advise, my plans are to machine the brackets and remake the bushing to mate with the overisze brackets thus removeing the side play and also to add a stiffer washer at each end to eleminate the axial inboard rotation and eleminate the ege shop that we end up with. The design intent is to allow rotation but they did not understand the amount of vibration diesels can input on loose bushing. Hisham Amaral 97 Wanderlodge W. Bloomfield MI. dukeflyer@... > To fix my a/c bracket I took it to a machine shop that bored the engine bracket holes and the a/c bracket holes to a size that would clean up the hole (so they were round once again.) They then built a new center shaft to fit the new, over sized holes. They also made two thick washers for the end of the shaft. If I remember right it cost me $120 a couple of years ago. > > Some discussion about the design of the bracket. I believe BB designed this massive bracket and expected the massive size of the shaft to withstand the vibration wear of the engine. It did not work on my rig. After less than 40k miles the bearings were out on the compressor. At 50k I did the repair. I too found all the holes and shaft egg shaped. > > I believe that the an improvement would be to tighten the "ears" on the bracket by tightening the bolts at the end of the shaft. (Maybe that was the intention of the design???) In any case when I reassembled my repaired bracket I tighten the ear as firmly as I could so that the clamping action of the ears on the engine bracket would minimize the wear on the shaft. If it could be tightened enough, after adjusting the belt tension, there would be no relative motion between the two brackets and the shaft, eliminating wear. > > One comment: I wish I had removed the gusset from under the two "ears". That way I could have more easily tighten the bolts at the end of the shaft that would have clamp the "ears" on the bracket to the engine side bracket. I didn't remove that (approx. 5/16" x 3/4") gusset. I had to stand on a wrench to tighten the ears after I got the a/c bracket adjusted. I imagine a significant portion of the clamping force is going into bending the ears around the gusset rather than clamping the ears to the engine bracket. Now, I believe the bracket is tightened as if it were one piece, rather than one support and one pivot. > > Sorry for the long soliloquy. It's a complicated issue relating to what I think was either a design problem or an incorrect BB fabrication/installation on my bus. > > Eric Perplies > 96' 42' WBWL > currently in Lolo, MT > |
