Help with 3 roof airs not working
06-12-2005, 09:34
Hello,
I would appreciate some help with my roof air units. None of the units will turn on. No fans or signs of any life. I checked the output voltage at the three AC circuit breakers and they are outputing 115 VAC. I checked the input voltage at the center roof AC unit and it has no AC input. I purchase a complete set of drawings from BB but there is no AC wiring diagram of any kind. Thank you, Andy 88 WB40 Silver edition |
06-12-2005, 09:39
there are 3 switchs in the drivers area that control the power to the ac
units,somewhere to the left of the driver,maybe on the bottom of the upper cabinets. have you checked those?randydupree93wb ----- Original Message ----- From: awojteczko To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 12, 2005 5:34 PM Subject: [WanderlodgeForum] Help with 3 roof airs not working Hello, I would appreciate some help with my roof air units. None of the units will turn on. No fans or signs of any life. I checked the output voltage at the three AC circuit breakers and they are outputing 115 VAC. I checked the input voltage at the center roof AC unit and it has no AC input. I purchase a complete set of drawings from BB but there is no AC wiring diagram of any kind. Thank you, Andy 88 WB40 Silver edition ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-12-2005, 14:35
The A/Cs need the three switches turned on as Randy mentioned, and
the units should be controlled by the wall thermostats (individually). - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > there are 3 switchs in the drivers area that control the power to the ac units,somewhere to the left of the driver,maybe on the bottom of the upper cabinets. have you checked those?randydupree93wb > ----- Original Message ----- > From: awojteczko > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, June 12, 2005 5:34 PM > Subject: [WanderlodgeForum] Help with 3 roof airs not working > > > Hello, > I would appreciate some help with my roof air units. None of the units > will turn on. No fans or signs of any life. I checked the output > voltage at the three AC circuit breakers and they are outputing 115 > VAC. I checked the input voltage at the center roof AC unit and it has > no AC input. I purchase a complete set of drawings from BB but there is > no AC wiring diagram of any kind. > > Thank you, > > Andy > 88 WB40 Silver edition > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
