Aquahot leaked, How would you repair bay floor?
07-19-2009, 07:55
Need suggestions.
My Aquahot has leaked in the past, both fuel & coolant. Now that it's fixed it leaves me with another chore, what to do with the carpet lining in the bay, it's permanently wet and emits a nice fuel odor, especially this time of year. I'm not sure of the condition of the sub floor. You can see that it to has gotten a good soaking. It may also need replacement. The front bay didn't get any fluids on it so it just bay 2&3 on the road side. The Aquahot will have to come out to remove old carpet and install whatever material I need to line the floor with. One thought was to fabricate a tray with a drain similar to what you would place under a washing machine or a water heater to catch and evacuate any fluids in case of an accidental leak. I'd like hear any suggestion you might have. Thanks, Kurt Horvath 95 PT 42 10AC |
07-19-2009, 08:11
As far as I can tell, the floor of the bays are sheet steel, with a felt-like material used to carpet them. In my poking around (and drilling pilot holes for some screws to hold dividers in my bays) I did not encounter any plywood. The sheet steel has a foam insulation sprayed up from below (on the outside).
You may simply be able to pull up the damaged carpet (the felt stuff) and then install something similar. It's probably just glued down. The mixture of diesel and coolant (water + anti freeze) that's spilled/leaked onto the bay floor has probably turned into a slightly sticky mess beyond anything that shampooing techniques are likely to remedy. While the drain idea is interesting, considering the actual construction of the bay floor, it might be better to simply cut a hole (and install a screen to keep vermin out) through the bottom of the A-H burner compartment (where I presume the leak, etc. took place). I'm told that newer A-Hs were installed with a vent to the bottom to allow air to enter for the burner, etc. -- what I propose would be to 'update' your coach to match the later installation method. The frame and case of the A-H should be sufficient to keep future spillage contained sufficiently to allow it to find its way out the bottom vent. I also note that there is always a slight diesel odor in the bays that gets stronger near the AquaHot is apparently common. (I once lived in a home with an oil furnace that always had a slight diesel fuel smell in the basement.) I suspect that the diesel odor is an artifact of how fuel oil/diesel burners operate, and may not be specifically related to the previous spills. Over the past 3 years, nothing I've stored in the storage bays has picked up a significant odor that lingers once the items are removed from the bays. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jul 19, 2009, at 12:55 PM, Kurt Horvath wrote:
07-19-2009, 08:37
07-19-2009, 08:59
That's right Ernie, on mine there's a sheet pf aluminum under the AH.
David Brady '02 LXi, NC Sent from my Verizon Wireless BlackBerry From: Ernie Ekberg Date: Sun, 19 Jul 2009 13:37:21 -0700 (PDT) To: Subject: Re: [WanderlodgeForum] Aquahot leaked, How would you repair bay floor?
07-19-2009, 15:18
rip out the carpet and install the commercial rubber garage flooring. ????--- In
WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Need suggestions. > > My Aquahot has leaked in the past, both fuel & coolant. > > Now that it's fixed it leaves me with another chore, what to do with the carpet lining in the bay, it's permanently wet and emits a nice fuel odor, especially this time of year. I'm not sure of the condition of the sub floor. You can see that it to has gotten a good soaking. It may also need replacement. > > The front bay didn't get any fluids on it so it just bay 2&3 on the road side. > > The Aquahot will have to come out to remove old carpet and install whatever material I need to line the floor with. > > One thought was to fabricate a tray with a drain similar to what you would place under a washing machine or a water heater to catch and evacuate any fluids in case of an accidental leak. > > I'd like hear any suggestion you might have. > > Thanks, > > Kurt Horvath > 95 PT 42 > 10AC > |
07-20-2009, 15:18
Kurt,
When I bought my coach I too had a fuel leak in the AquaHot unit. (The fuel pump was faulty in many of the 96-97 models.) I had diesel on my compartment carpeting. I planned to change the carpeting that winter, 6 months later. Before I had an opportunity to change the carpet, a pita job, the smell was utterly gone. The carpeting is stained around the unit. I dreaded pulling the unit just to change the carpeting with a material that probably wouldn't match anyway. I never changed it. I have no plans to change it unless I have another reason to pull the AquaHot unit. Happy trails, Eric Perplies 96 42' WBWL currently in Lolo, MT |
07-20-2009, 16:38
Thanks Eric,
Have fun in MT I love that state. Fuel pump was my problem as well. Unfortunately the carpet, "Ozite"' has come off the floor and it just slides around, If I don't take out the Aquahot I still have to tear out the carpet and replace it with something. Fuel has saturated the underlayment and I'll have to decide what to do with it as well. Anyway have a great time in Big Sky Country! Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "Eric Perplies" > > Kurt, > > When I bought my coach I too had a fuel leak in the AquaHot unit. (The fuel pump was faulty in many of the 96-97 models.) I had diesel on my compartment carpeting. I planned to change the carpeting that winter, 6 months later. Before I had an opportunity to change the carpet, a pita job, the smell was utterly gone. The carpeting is stained around the unit. I dreaded pulling the unit just to change the carpeting with a material that probably wouldn't match anyway. I never changed it. I have no plans to change it unless I have another reason to pull the AquaHot unit. > > Happy trails, > > Eric Perplies > 96 42' WBWL > currently in Lolo, MT > |
07-21-2009, 02:36
Kurt, a year or two ago I made a holder for my chair's in the storage
compartments and wanted it to look the same so I called Holland Motors in Michigan and they had a piece of that gray stuff, I would call around to some of the old BB dealers and you might find the right stuff. Also when my A/H leaked I had to pull all the sheet metal and replace the duct liner insulation around the tank, it was soaked with diesel too. Marty Gregg 95 BMC 37 Kennewick WA |
07-21-2009, 13:39
Hi guys,
I got the old OZITE Carpet out of the bay today. Fortunately the fluids did not creep up the side walls and what didn't come out I'll just have to live with. I'm not going to take the Aquahot out until I have to. Too much trouble for whatever advantage will be gained. I'll say one thing this stuff is tough. The glue backing of course has been turned to slime but the carpet itself is still very much intact. It would not tear at all; I had to cut it out. A little elbow grease and some Acetone and the slimed glue is off the sheet metal floor and is ready for a new covering, I'll get over to Home Depot and by some more Ozite in the morning, "Kurt, I believe underneath your carpet is metal. The carpet used is Ozite unitary backed. You will have to scrape it off. Home Depot, actually, has this material in stock. Ernie Ekberg", exactly as described Ernie, thanks! Some paint did come off with the cleaning operation and there is some minimal rusting, just some coin sized spots, I'll clean those up and shoot some paint on the bare sports before installing the new Ozite. Thanks for all the suggestions. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "martingregg598" wrote: > > Kurt, a year or two ago I made a holder for my chair's in the storage compartments and wanted it to look the same so I called Holland Motors in Michigan and they had a piece of that gray stuff, I would call around to some of the old BB dealers and you might find the right stuff. Also when my A/H leaked I had to pull all the sheet metal and replace the duct liner insulation around the tank, it was soaked with diesel too. > Marty Gregg > 95 BMC 37 > Kennewick WA > |
07-22-2009, 02:17
Kurt,
Did the carpet go under the AquaHot or just around it? On my '99 they didn't use carpet in that bay but went with a thick, black vinyl tile/linoleum. They did the same in the bay forward of that with the waterpumps, filter, etc. and to the rear in the water hookup bay. All others have the carpet. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Hi guys, > > I got the old OZITE Carpet out of the bay today. Fortunately the fluids did not creep up the side walls and what didn't come out I'll just have to live with. I'm not going to take the Aquahot out until I have to. Too much trouble for whatever advantage will be gained. > > I'll say one thing this stuff is tough. The glue backing of course has been turned to slime but the carpet itself is still very much intact. It would not tear at all; I had to cut it out. A little elbow grease and some Acetone and the slimed glue is off the sheet metal floor and is ready for a new covering, I'll get over to Home Depot and by some more Ozite in the morning, > > "Kurt, I believe underneath your carpet is metal. The carpet used is Ozite unitary backed. You will have to scrape it off. Home Depot, actually, has this material in stock. Ernie Ekberg", exactly as described Ernie, thanks! > > Some paint did come off with the cleaning operation and there is some minimal rusting, just some coin sized spots, I'll clean those up and shoot some paint on the bare sports before installing the new Ozite. > Thanks for all the suggestions. > > Kurt Horvath > 95 PT 42 > 10AC > > > > > --- In WanderlodgeForum@yahoogroups.com, "martingregg598" wrote: > > > > Kurt, a year or two ago I made a holder for my chair's in the storage compartments and wanted it to look the same so I called Holland Motors in Michigan and they had a piece of that gray stuff, I would call around to some of the old BB dealers and you might find the right stuff. Also when my A/H leaked I had to pull all the sheet metal and replace the duct liner insulation around the tank, it was soaked with diesel too. > > Marty Gregg > > 95 BMC 37 > > Kennewick WA > > > |
