Heading to California
07-26-2009, 09:34
I leave here Aug 2nd and head to Tom McCarthy's coach in Ca to do an extreme
makeover with new wood and carpet. There is some ceramic tile that will have to
be air chisled- messy, but worth it. You can follow the progress by going to my
remodeling forum.
83PT40- coach stays home
http:/groups.yahoo.com/group/erniesremodelingandrepair
07-26-2009, 10:49
Ernie,
Just so you know, in a '95 the tile is attached to 'wonder board' (or equivalent) with epoxy thin set. The wonder board is both screwed and thin-setted to the plywood underlayment. (The sub-floor is steel sheet.)
Air chisel would do a good job. I used pry bars and a hammer. It tore up the plywood underlayment so thoroughly, that I then cut it out and pieced in new wood. Patched the seam and some torn-up spots along the edges with a cement-like floor leveling stuff.
El Sobrante CA
"aeonix1@mac.com"
On Jul 26, 2009, at 2:34 PM, Ernest Ekberg wrote:
I leave here Aug 2nd and head to Tom McCarthy's coach in Ca to do an extreme makeover with new wood and carpet. There is some ceramic tile that will have to be air chisled- messy, but worth it. You can follow the progress by going to my remodeling forum.
07-26-2009, 11:16
Pete, we took up some clay ceramic tile in Wallace craigs 95 and that had the epoxy thinset but no backerboard. Perhaps you had some porcelain tile that required the backerboard.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Sun, 7/26/09, Pete Masterson wrote:
Subject: Re: [WanderlodgeForum] Heading to California
Date: Sunday, July 26, 2009, 5:49 PM
Ernie,
El Sobrante CA
07-26-2009, 14:37
Well, each of the coaches are "custom" ... the tiles were large 12 x 12 ceramic, but were nothing that special. Not porcelain, anyway. Just ordinary floor tiles that I've seen (similar ones) in home centers, etc.
El Sobrante CA
"aeonix1@mac.com"
83PT40
Wanderlodge
