120/240 wiring diagram
08-11-2009, 12:44
Still looking for a copy of the wiring diagram 120/240. gfi from breaker box to
the bathroom gfi.are there any relays in between. wire No# is 14 . this is for a
1989 bluebird wonder lodge 38'
thanks Denny
08-11-2009, 18:09
Denny,
I have a 1908 FC so can't help, but have you checked the files section to see if
what you need is there? Also the W.O.G. forum has a lot of files and manual
that might help.
I can tell you if yours is anything like the older FC's any outside outlets
(mine is in the propane tank bay) are also on the G.F.I. breaker.
Good Luck,
Dave Ward
1980 FC 31
Mesa, AZ
to the bathroom gfi.are there any relays in between. wire No# is 14 . this is
for a 1989 bluebird wonder lodge 38'
> thanks Denny
