New battery time
08-19-2009, 10:29
New battery time
6 volters
--- On Wed, 8/19/09, jburgessx2@... wrote:
Subject: Re: [WanderlodgeForum] Re: New battery time
Date: Wednesday, August 19, 2009, 6:26 PM
Gary,
Are you using 6 or 12 volt? And, what Ah?
Jerry
85 PT40
Sent via BlackBerry from T-Mobile
Date: Wed, 19 Aug 2009 15:12:07 -0700 (PDT)
To:
look here for battery types
http://www.sonnensc hein.org/
Date: Thursday, August 13, 2009, 10:01 AM
Thanks for the info. I'll check that link out.
Jerry
85 PT40
Date: Thu, 13 Aug 2009 13:40:44 -0000
To:
Subject: [WanderlodgeForum] Re: New battery time
Hi Jerry,
Don't waste your $$ on the IOTA's. They are not capable of a full bulk charge or equalization (despite what the literature says). You need a
charger that is temperature- compensating and capable of at least 15.5 volts when equalizing. I'd spend the extra $$ and get a Truecharge2 or even a remanned ProSine 2.0. Wherever you mount it, make sure that it's dry and cool. Mine's been working great for 4 years. Check out this link- [http://www.xantrex. com/web/id/ 256/p/1/pt/ 7/product. asp].
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@ yahoogroups. com, "jburgessx2" wrote:
> We full time but rarely dry camp. So, I'm thinking 12v deep cycle should be okay. Also, I'm replacing the boilers with Iota DLS-45 chargers. Thoughts? Jerry 85 PT40
> should be fine. Also, I'm replacing my boilers with Iota DLS-45 chargers.
> A
08-20-2009, 07:03
New battery time
Gary,
The problem with 13.7 volt chargers is that your batteries will not ever get a full charge. That will cause them to fail prematurely. Shane is correct.
Sent: Wednesday, August 19, 2009 3:09 PM
After years of debate, I got rid of all chargers and went to fixed highly regulated switching converters at 13.7 VDC. I let the engine float/equalize the batteries. The Sonnenschein AGM's love it and I have no problems. I have 120 amps of converters that never boil a battery and at 13.7 the charge is good.
Date: Thursday, August 13, 2009, 9:40 AM
Hi Jerry,
Don't waste your $$ on the IOTA's. They are not capable of a full bulk charge or equalization (despite what the literature says). You need a charger that is temperature- compensating and capable of at least 15.5 volts when equalizing. I'd spend the extra $$ and get a Truecharge2 or even a remanned ProSine 2.0. Wherever you mount it, make sure that it's dry and cool. Mine's been working great for 4 years. Check out this link- [http://www.xantrex. com/web/id/ 256/p/1/pt/ 7/product. asp].
Shane Fedeli
85PT40
Hershey, PA
> A
08-20-2009, 16:50
New battery time
Hi there Richard.
About the batteries. this is not so. each type of battery has it's own charge rate.
The lead acid ones are in the 14.4 volt range, but he AGM's I believe are in 13.7 range.
Not quite sure, but I know they are not the same
Terrace, B.C. Canada
All new Yahoo! Mail - Get a sneak peak at messages with a handy reading pane.
08-21-2009, 01:10
New battery time
Good point Bill. I forgot to make that distinction. The better choice would be
to get a charger that can be programmed for various types, rather than a static
voltage power supply. Especially with AGM's, the unit will need to shut down
automatically when the batteries are full, or he'll ruin them.
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> Hi there Richard.
rate.
13.7 range.
> __________________________________________________________________
> Looking for the perfect gift? Give the gift of Flickr!
> http://www.flickr.com/gift/
08-21-2009, 01:48
New battery time
Hi,
AGM and wet have the same charge characteristics. Only Gel is different.
Obviously you can't mix any - really should have same brand and age in battery
banks.
See:http://www.windsun.com/Batteries/Battery_FAQ.htm#AGM, or Absorbed Glass Mat
Batteries
> Shane Fedeli
> 85PT40
> Hershey, PA
> > Hi there Richard.
charge rate.
13.7 range.
08-27-2009, 01:05
New battery time
Driving is the equalizing charge. If you drive once a month, you equalize the batteries. Every battery is slightly different by a few tenths of a volt. If you call 5 years short life, then you would be right but I am ballanced out and get 5 or more years out of the batteries with this trick. And actually at the battery terminals it is 13.9 volts.
Date: Thursday, August 20, 2009, 3:03 PM
Gary,
Hi Jerry,
Shane Fedeli
85PT40
Hershey, PA
> A
08-27-2009, 02:07
New battery time
Great battery site:
http://www.eastpenn-deka.com/assets/base/0139.pdf
Flooded/gel/AGM
> From: Joyce and Richard Hayden
> Gary,
> is correct.
> From: GARY
> MINKER
> PM
> battery time
> --- On
> From:
> Subject:
> To:
> 13, 2009, 9:40 AM
> Hi Jerry,
compensating
> 7/product. asp].
> Shane Fedeli
> 85PT40
> Hershey,
> PA
> A
