Water leak under fresh water tank. 1990 SP-36
08-29-2009, 10:54
I can't figure out how to get to the tank outlet fittings. It seems that the
skirt under the closet sliding doors is removeable but I can't see any
fasteners. Has anyone here ever removed a SP water tank? Sure would appreciate
some advice.
Paul Cunningham
Virginia
1990 SP-36
08-31-2009, 13:08
Paul
I took out my water tank on my 91 SP36.Although it was long, long ago.
I do recall the floor of the closet came out first and then you can remove the lower portion of the closet base,completely exposing the tank and making it accessable.The fasteners are there butI have no recall of their location. Just be patient with your procedure.
Good luck.
Fred Hulse
Morristown,Arizona
1997 Wanderlodge WB41
