Shop air compressor wont put out more than 110 PSI
09-21-2009, 08:52
My Porter Cable 135PSI 3HP/4GAL wont put out more than 110psi with 50'rubber
hose or 30' coiled yellow vinal(I think). It has always been this way since new. No leaks or problems...My new Michlens need 120 psi so now I have to do something. What psi compressor does everybody use? Is there a compressor expert here? Does the length and composition of the hose matter? If so what length and material hose do I need for my 135 psi compressor?The output gauge on the compressor reads 130psi but wont pump up tires past 110psi... Ant help would be appreciated. Ed Gardels 89SP Arlington Tx |
09-21-2009, 08:54
hose length and size can affect how much flow (CFM) a given compressor can deliver at a given pressure (PSI), but not the maximum pressure when the compressor cuts off. You might check the pressure switch and regulator and see if you can set the pressure back higher.
Â
Dorn Hetzel
77FC35
Hogansville, GA
On Mon, Sep 21, 2009 at 4:52 PM, wl89spman <"egardata@tx.rr.com"> wrote:
09-21-2009, 09:04
--- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel
> Thanks Dorn- I have the knob maxed out all the way open..My air hoses are all 3/8", should I use a bigger hose? Thanks Ed Gardels 89SP Arlington Texas > hose length and size can affect how much flow (CFM) a given compressor can > deliver at a given pressure (PSI), but not the maximum pressure when the > compressor cuts off. You might check the pressure switch and regulator and > see if you can set the pressure back higher. > > Dorn Hetzel > 77FC35 > Hogansville, GA > > On Mon, Sep 21, 2009 at 4:52 PM, wl89spman > > > > > > > My Porter Cable 135PSI 3HP/4GAL wont put out more than 110psi with > > 50'rubber hose or 30' coiled yellow vinal(I think). It has always been this > > way since new. No leaks or problems...My new Michlens need 120 psi so now I > > have to do something. What psi compressor does everybody use? > > Is there a compressor expert here? Does the length and composition of the > > hose matter? If so what length and material hose do I need for my 135 psi > > compressor?The output gauge on the compressor reads 130psi but wont pump up > > tires past 110psi... > > Ant help would be appreciated. > > > > Ed Gardels 89SP > > Arlington Tx > > > > > > > |
09-21-2009, 09:13
In my experience you do not get the 'rated' PSI at the end of the hose from any compressor. They all are slightly below the rated max PSI. You'll need to get one rated at 150 PSI to get the 120 in your tire.
You could change out your pressure switch to a higher PSI (e.g., 150),if the tank was approved to that pressure. The max PSI for the tank should be stamped on the bottom. The tank ratings (max pressure) will be higher than the operating setup for safety purposes.
Roger Webb
91 WL
Cedar Rapids, IA -----Original Message----- From: Dorn Hetzel To: WanderlodgeForum@yahoogroups.com Sent: Mon, Sep 21, 2009 3:54 pm Subject: Re: [WanderlodgeForum] Shop air compressor wont put out more than 110 PSI hose length and size can affect how much flow (CFM) a given compressor can deliver at a given pressure (PSI), but not the maximum pressure when the compressor cuts off. You might check the pressure switch and regulator and see if you can set the pressure back higher.
Dorn Hetzel
77FC35
Hogansville, GA
09-21-2009, 09:33
When the compressor is running and then cuts off, what does the pressure gauge right at the compressor say the pressure is then? If it isn't 120+ at the tank when it cuts off then as someone else said you will need a new pressure switch (if the tank and motor can handle that pressure) or a new compressor if not.Â
Â
 On Mon, Sep 21, 2009 at 5:04 PM, wl89spman <"egardata@tx.rr.com"> wrote:
09-21-2009, 09:44
09-21-2009, 09:59
I gave up on my home compressor.. I have a 20# CO2 tank with a fixed 150PSI
regulator..The tank is easy to carry around, and works well. You only need a short hose, since you can take the tank to the tire. You need a regulator set a bit higher than the desired tire pressure, or else those last few #s take forever. I also have a small 5# tank i take in my Jeep to air up the tires after a days Off-Roadin..The small tank has lasted me over 2 years... Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "wl89spman" > > My Porter Cable 135PSI 3HP/4GAL wont put out more than 110psi with 50'rubber hose or 30' coiled yellow vinal(I think). It has always been this way since new. No leaks or problems...My new Michlens need 120 psi so now I have to do something. What psi compressor does everybody use? > Is there a compressor expert here? Does the length and composition of the hose matter? If so what length and material hose do I need for my 135 psi compressor?The output gauge on the compressor reads 130psi but wont pump up tires past 110psi... > Ant help would be appreciated. > > Ed Gardels 89SP > Arlington Tx > |
09-21-2009, 10:03
09-21-2009, 10:53
--- In WanderlodgeForum@yahoogroups.com, GARY MINKER
> Thanks for all the help.. You have convinced me..I have heard of nitrogen being used but you say CO2.What size tank do I need and where can I buy one and whats the approx cost? Thanks Ed Gardels 89SP Arlington Texas home of COWBOY STADIUM > Hi CO2 is a wet dirty gas that does not necessarilly do well in tires. Welding CO2 is nasty. Food grade CO2 is better but hard to find. Even shop grade nitrogen is 99.99% pure. Hospital "zero" grade is even cleaner but who needs it? > > --- On Mon, 9/21/09, jackcj7 > > From: jackcj7 > Subject: [WanderlodgeForum] Re: Shop air compressor wont put out more than 110 PSI > To: WanderlodgeForum@yahoogroups.com > Date: Monday, September 21, 2009, 5:59 PM > > > > > > > > > > > > > I gave up on my home compressor.. I have a 20# CO2 tank with a fixed 150PSI regulator..The tank is easy to carry around, and works well. You only need a short hose, since you can take the tank to the tire. > > You need a regulator set a bit higher than the desired tire pressure, or else those last few #s take forever. I also have a small 5# tank i take in my Jeep to air up the tires after a days Off-Roadin.. The small tank has lasted me over 2 years... > > Jack Smith > > 1973FC31 > > SoCal > > > > --- In WanderlodgeForum@ yahoogroups. com, "wl89spman" > > > > > > My Porter Cable 135PSI 3HP/4GAL wont put out more than 110psi with 50'rubber hose or 30' coiled yellow vinal(I think). It has always been this way since new. No leaks or problems...My new Michlens need 120 psi so now I have to do something. What psi compressor does everybody use? > > > Is there a compressor expert here? Does the length and composition of the hose matter? If so what length and material hose do I need for my 135 psi compressor?The output gauge on the compressor reads 130psi but wont pump up tires past 110psi... > > > Ant help would be appreciated. > > > > > > Ed Gardels 89SP > > > Arlington Tx > > > > |
09-21-2009, 11:02
