Water fill switch
09-29-2009, 05:29
Water fill switch
We are having trouble with the water fill switch. I have the water hooked to our
coach and i came home the other day and the water was running out of the overflow. The switch was on off and still filling the coach. I turned the water off and now the pump in the coach will not pump water out of the holding tank. Hope someone can tell how to fix this problem. Rick and Terri Mcintire 86Pt38 Patillo, Tx. |
09-29-2009, 05:41
Water fill switch
If like our '87 PT38, the Fill Switch operates a Sporlan Valve. That valve needs to be cleaned or rebuilt. Most likely a careful cleaning will do it. Many of us have taken the valve apart and cleaned the diaphragm. The Sprolan Valve in our coach is located under the curb side of the bed box close to the water pump.
Turn off all water workings...use a small rag to stuff into the hole in the valve when removing the electromagnet. Carefully remove and clean the diaphragm. Re-assemble the parts in the same order as removed. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Tue, Sep 29, 2009 at 10:29 AM, trautoranch <"rmcintire@sewell.com"> wrote:
09-29-2009, 05:44
Water fill switch
Try cleaning the Sporlan Valve...and install a Sporlan Kit if you have one.
Dick Gideon '89 FC35 Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "trautoranch" > > We are having trouble with the water fill switch. I have the water hooked to our coach and i came home the other day and the water was running out of the overflow. The switch was on off and still filling the coach. I turned the water off and now the pump in the coach will not pump water out of the holding tank. Hope someone can tell how to fix this problem. > > Rick and Terri Mcintire > 86Pt38 > Patillo, Tx. > |
09-29-2009, 05:54
Water fill switch
Cleaning the Sporlan valve worked for us. But what is a Sporlan Kit?
Greg Young
86 PT40 "Bluefire"
Currently in WilliamstownVT Each time you judge yourself you break your heart. -Kirpal Venanji From: richardgideon To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, September 29, 2009 1:44:20 PM Subject: [WanderlodgeForum] Re: Water fill switch Try cleaning the Sporlan Valve...and install a Sporlan Kit if you have one. Dick Gideon '89 FC35 Rolla, MO --- In "WanderlodgeForum%40yahoogroups.com", "trautoranch" > > We are having trouble with the water fill switch. I have the water hooked to our coach and i came home the other day and the water was running out of the overflow. The switch was on off and still filling the coach. I turned the water off and now the pump in the coach will not pump water out of the holding tank. Hope someone can tell how to fix this problem. > > Rick and Terri Mcintire > 86Pt38 > Patillo, Tx. > |
09-29-2009, 06:10
Water fill switch
Greg, the kit consists of o-rings, a new spring and plunger and
diaphragm. They are available form Steven Birtles at Dupree products. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 10:54 AM 9/29/2009 -0700, you wrote: Cleaning the Sporlan valve worked |
09-29-2009, 06:53
Water fill switch
-Thanks for the information. I will check it tonight and see what happens. If i
need to i will call Steven and get a new kit. Rick Mcintire Patillo Tx 86PT38 > > > |
09-29-2009, 15:21
Water fill switch
Sounds like your Sporlan valve has failed.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "trautoranch" > > We are having trouble with the water fill switch. I have the water hooked to our coach and i came home the other day and the water was running out of the overflow. The switch was on off and still filling the coach. I turned the water off and now the pump in the coach will not pump water out of the holding tank. Hope someone can tell how to fix this problem. > > Rick and Terri Mcintire > 86Pt38 > Patillo, Tx. > |
10-01-2009, 16:12
Water fill switch
Your challenge will likely be to find your Sporlan Valve. I think BB must of
had a special department whose job it was to conceal the location of the Sporland tank fill valve. They did a pretty good job on my bird. I finally found it buried deep in the water pump area of my bus. Eric Perplies 96' 42' WBWL |
10-02-2009, 01:57
Water fill switch
