our water leak
10-03-2009, 13:55
our water leak
Well, we think we have it licked! Â Jim and Barbara came through yesterday on their way to Gillette. Â Jim's hearing is better than ours, and he was able to find the water pump that we couldn't find hiding under a drawer -- and the leak was coming from a broken filter to the water pump. Â So today, Mike got that fixed!--yes! Â What a good feeling to believe we have the water under control now. Â Bluebird sure liked to hide stuff. . . .
A great big thanks to Jim out of Ft. Pierre SD! Mike and Jana Ewart 89 pt40wb "The Bird House"Â
-- Blessed are the people whose God is the Lord. (Psalm 144:15) |
10-03-2009, 15:29
our water leak
10-05-2009, 08:36
our water leak
10-05-2009, 08:52
our water leak
Gary - I had the same leak on mine. The inlet on my 85 PT40 just didn't seem to fit right and it leaked. It took me a couple of tries to get it fixed properly. So far, so good. Jerry 85 PT40 Sent via BlackBerry from T-Mobile From: GARY MINKER Date: Mon, 5 Oct 2009 13:36:24 -0700 (PDT) To: Subject: Re: [WanderlodgeForum] our water leak
10-05-2009, 13:37
our water leak
Gary, I had the same problem with a drip and it ran down the slot where the lock fits. I corrected this using a half gallon milk jug, I cut it so I could run the hose through the top and the bottom extended past the end of the water connection box. If it drips it goes outside. Just roll it up with the hose. Bryan Altier 88 WLWB 40 Green ville SC Sent from my BlackBerry® smartphone with Nextel Direct Connect From: GARY MINKER Date: Mon, 5 Oct 2009 13:36:24 -0700 (PDT) To: Subject: Re: [WanderlodgeForum] our water leak
