97 Blueprints
10-12-2009, 13:02
97 Blueprints
Recently I made a set of over 25 hard copy blueprints for my 97 bird, thanks
to Fred Hulse and John Mace. I made an extra set if anyone would like it, cost
$100....quality is excellent, most are 24x36 inches.
Rick Archie
85 PT 40 - For Sale http://1985bluebirdpt40.shutterfly.com/
97 WL 43 "Fort R #4"
10-12-2009, 14:06
97 Blueprints
Hi Rich,
A couple of ideas...
One, you can reduce the documents pretty cheap, then copy the 11x17 reductions
easily.
Two, ask how much to scan to PDF. For a while kinko's was charging only $1 to
scan any size. Its really easy to copy CD's and sent them out... And cheaper
than the copies.
HTH, Joe
thanks to Fred Hulse and John Mace. I made an extra set if anyone would like it,
cost $100....quality is excellent, most are 24x36 inches.
> Rick Archie
10-13-2009, 13:53
97 Blueprints
Rick, I maybe interesed in your prints. I have some that came with mine
I'm not sure how many or witch ones, it would be interesting to compare. Are you
going to Quartzsite this year? If you still have them
bring them along or send me a list of what you have. Ernie said you would
probably take 3 boxes of wine and a knob for your pointy potty flusher for all
25 prints. Actually, I will pull out my box I see what I have and let you know.
Thanks for making an extra set, I will take them if mine are different. Jim
Marsh 97 WL (only a small 41)
> Rick Archie
10-14-2009, 00:43
97 Blueprints
Jim, I have a list of the exact print numbers I have...I will make a copy of the
list for you...Yes we will be at Quartzsite, wouldn't miss it for anything!
Rick Archie
85 PT 40 For Sale http://1985bluebirdpt40.shutterfly.com/
Fort Worth
you going to Quartzsite this year? If you still have them
> > Rick Archie
10-14-2009, 04:10
97 Blueprints
Rick, do you know what the approximate capacity of the coolant system is in a late 90s wanderlodge with the 60 series engine?
Wayne
1996 PT42
Sent: Wed, October 14, 2009 7:43:13 AM
Subject: [WanderlodgeForum] Re: 97 Blueprints
Jim, I have a list of the exact print numbers I have...I will make a copy of the list for you...Yes we will be at Quartzsite, wouldn't miss it for anything!
Rick Archie
85 PT 40 For Sale http://1985bluebird pt40.shutterfly. com/
Fort Worth
> I'm not sure how many or witch ones, it would be interesting to compare. Are you going to Quartzsite this year? If you still have them
> bring them along or send me a list of what you have. Ernie said you would probably take 3 boxes of wine and a knob for your pointy potty
flusher for all 25 prints. Actually, I will pull out my box I see what I have and let you know. Thanks for making an extra set, I will take them if mine are different. Jim Marsh 97 WL (only a small 41)
> --- In "WanderlodgeForum%40yahoogroups.com", "Rick" wrote:
> > Recently I made a set of over 25 hard copy blueprints for my 97 bird, thanks to Fred Hulse and John Mace. I made an extra set if anyone would like it, cost $100....quality is excellent, most are 24x36 inches.
> > Rick Archie
> > 85 PT 40 - For Sale http://1985bluebird pt40.shutterfly. com/
10-14-2009, 08:17
97 Blueprints
Hi Wayne
This is Fred Hulse
The dry capacity of the cooling systen is 100 quarts or 25 gallons.
It would be rare for you to completely drain the system because of the front cab heater system and the Aqua Hot loop.but you could make an effort I am sure.
The factory said 50% coolant would take you to minus 30 degrees.
Fred & Jeanne Hulse
Morristown,Arizona
1997 Wanderlodge WB41
10-14-2009, 08:48
97 Blueprints
Hi Fred:
Thanks for the info, my wanderlodge owners manuals didn't list the coolant system capacity. I did a strip test of my coolant and it shows the nitrate and molybdate levels a little low and in order to add the correct amount of Nalcool 2000 I needed to know the total amount of antifreeze/water mix in the system.
Wayne Kotila
97 PT42
Sent: Wed, October 14, 2009 3:17:07 PM
Subject: Re: [WanderlodgeForum] Re: 97 Blueprints
Hi Wayne
This is Fred Hulse
Fred & Jeanne Hulse
Morristown,Arizona
