roof mounted spotlight gears stripped?
10-30-2009, 07:10
Going through my to-do list to get my newly-acquired coach as close to 100% as I
can.....Is there a rebuild kit or anything of that nature available to repair the directional control of the roof spotlight?? Thanks in advance for the info. Steve '95 WBDA42 Phx, AZ |
10-30-2009, 07:16
Take it apart like I did. Make sure the lines are not broken. Fill the nylon gears with some good grease. Clean contacts and you might be surprised. Oh ya seal it back up so moisture isn't a problem.
2009/10/30 Steve <"ezf16@yahoo.com">
-- Rob, Sue and Joey Robinson 94 WLWB |
10-30-2009, 07:54
Wilco, I'll give it a try this weekend, works like a chhamp now forya aye?
Thanks a bunch. Steve --- In WanderlodgeForum@yahoogroups.com, Rob Robinson > > Take it apart like I did. Make sure the lines are not broken. Fill the nylon > gears with some good grease. Clean contacts and you might be surprised. Oh > ya seal it back up so moisture isn't a problem. > > 2009/10/30 Steve > > > > > > > Going through my to-do list to get my newly-acquired coach as close to 100% > > as I can.....Is there a rebuild kit or anything of that nature available to > > repair the directional control of the roof spotlight?? Thanks in advance for > > the info. > > Steve > > '95 WBDA42 > > Phx, AZ > > > > > > > > > > -- > Rob, Sue and Joey Robinson > 94 WLWB > |
10-30-2009, 08:05
Steve it works as it did new except I broke the limiting switch system and I haven't bothered to re manufacture and broken arm. I could but instead I just turn the light a max of 180 one way and 180 the other. I note which way I went last because mine won't rotate 360 more than onceÂ
