electrical issue
11-10-2009, 13:45
electrical issue
While driving my coach from Santa Barbra, I noticed that my engine volt meter
was at 12. Stopped the coach and just as I suspected, no belts on the
alternators. No problem, I started the generator and all is well.
The question I have is, my generator volt meter is still at 12. I am currently
"camped" on the side of the interstate as I don't drive at nite and I didn't
think the charger could handle all the lites.
Does the main engine alternator charge the generator battery?
If the house charger does not do that I might have to add a charger for the
generator battery.
I have cell phone, internet, and tv. Life is good. and I'm in the coach, which
is even better.
Ernie- 83PT40 Newberry Springs, Ca- beside the tracks
11-10-2009, 14:26
electrical issue
Ernie,
I was a supervisor our there on the
railroad many years ago. HQ at Barstow
territory ran from Cajon and Mojave on the west to Needles on the East side.
Sorry about your electrical problems.
I have run our WB on the generator for days to get home after an alternator
failure, but I only have one set of batteries. Do you chargers just
charge both sets or just the house batteries? I would expect that there
is an isolator to prevent the “house” side from discharging the
starting batteries.
- Chuck
Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ernie E
Sent: Tuesday, November 10, 2009
7:45 PM
Subject: [WanderlodgeForum]
electrical issue
that my engine volt meter was at 12. Stopped the coach and just as I suspected,
no belts on the alternators. No problem, I started the generator and all is
well.
didn't think the charger could handle all the lites.
generator battery.
is even better.
11-10-2009, 15:06
electrical issue
Hi Ernie,
Sorry for the belt loss.
If your rig is like mine, on the passenger side at the rear,there is a isolator
bar. It is down low on the side that you open up. Mine had given up the ghost
and wasn't charging the gen bat.
I ran a seperate wire from the rear batts to the gen bat, with a fuse inline.
This makes sure that the gen bat always gets juice.
My gen set is probably like yours and doesn't have an alternator.
I also carry a battery charger in my pod in the event the alt. gives out and I
need to charge any batts.
If seems from what you are saying the gen bat isn't getting a charge.
Hope it starts for you tomorrow.
Do you carry a set of jumper cables with you? If so, and the gen doesn't start,
if you have the tools, remove a engine bat and jump the gen bat to get it
started.
Bob Lawrence
84 PT36
Elko, Ga
generator battery.
is even better.
11-10-2009, 15:07
electrical issue
Hi Chuck, I have a total of 4 house/starter batteries. After being parked with generator running, i now have 13 volts on generator battery. So somewhere along the line, after the initial start of the generator, that battery has come up.
Ernie- hearing trains every 20 minutes
will have to turn on all fans to drown out the noise.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Tue, 11/10/09, Chuck Wheeler wrote:
Subject: RE: [WanderlodgeForum] electrical issue
Date: Tuesday, November 10, 2009, 8:26 PM
Ernie,
I was a supervisor our there on the railroad many years ago. HQ at Barstow territory ran from Cajon and Mojave on the west to Needles on the East side.
Sorry about your electrical problems. I have run our WB on the generator for days to get home after an alternator failure, but I only have one set of batteries. Do you chargers just charge both sets or just the house batteries? I would expect that there is an isolator to prevent the “house” side from discharging the starting batteries.
- Chuck Wheeler-
From: WanderlodgeForum@ yahoogroups. com [mailto: WanderlodgeForum@ yahoogroups. com ] On Behalf Of Ernie E
Sent: Tuesday, November 10, 2009 7:45 PM
Subject: [WanderlodgeForum] electrical issue
While driving my coach from Santa Barbra, I noticed that my engine volt meter was at 12. Stopped the coach and just as I suspected, no belts on the alternators. No problem, I started the generator and all is well.
The question I have is, my generator volt meter is still at 12. I am currently "camped" on the side of the interstate as I don't drive at nite and I didn't think the charger could handle all the lites.
If the house charger does not do that I might have to add a charger for the generator battery.
I have cell phone, internet, and tv. Life is good. and I'm in the coach, which is even better.
11-10-2009, 15:10
electrical issue
Hi Bob, I do carry a set of jumper cables. looks like things are ok for now. Man, we are a lomg distance from each other-- 2200+ miles and a whole bunch of fuel away
83PT40
Wanderlodge
--- On Tue, 11/10/09, Bluebird Bob wrote:
Subject: [WanderlodgeForum] Re: electrical issue
Date: Tuesday, November 10, 2009, 9:06 PM
Hi Ernie,
If your rig is like mine, on the passenger side at the rear,there is a isolator bar. It is down low on the side that you open up. Mine had given up the ghost and wasn't charging the gen bat.
I ran a seperate wire from the rear batts to the gen bat, with a fuse inline. This makes sure that the gen bat always gets juice.
I also carry a battery charger in my pod in the event the alt. gives out and I need to charge any batts.
Do you carry a set of jumper cables with you? If so, and the gen doesn't start, if you have the tools, remove a engine bat and jump the gen bat to get it started.
Bob Lawrence
84 PT36
Elko, Ga
tracks
11-10-2009, 15:15
electrical issue
Ernie
Sounds like you have a handle on the situation for the evening anyhow.
The trains will let you sleep for a few minutes at a time,but you might get used to it.
I am sure you will be ok until you get to Rods and put new belts on the alt. and maybe pick up a little 25 amp.battery charger for back up.
Keep us up to date.
Fred Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
11-10-2009, 15:40
electrical issue
Ernie,
Unless you have a very small charger you
should be able to run on the generator/charger during the daytime. I did
an all nighter trying to stay ahead of a blizzard and every thing kept
running. On our coach there is something about where the voltmeter is
connected that doesn’t give an accurate reading when all the lights are
on and it is running off the charger. I think it may be a ground issue
because reading right at the batteries the voltage was 13.7vdc but the gauge
only showed 12 and a hair. (Scientific term) I have been thinking about
taking the voltmeter leads all the way to the battery so I would have an accurate
reading of what is going on. Remember, if your batteries are in good
shape and they have been run down they will come up to voltage slowly as they
accept a charge.
- Chuck
Wheeler-
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ernie Ekberg
9:08 PM
electrical issue
batteries. After being parked with generatorrunning, I now have 13
83PT40
Wanderlodge
--- On Tue, 11/10/09, Chuck Wheeler <cwheeler@kathleenwheeler.com>
Ernie,
ago. HQ at Barstow
- Chuck Wheeler-
TX
7:45 PM
yahoogroups. com
electrical issue
and all is well.
generator battery.
11-10-2009, 15:53
electrical issue
Ernie,
With generator running all batteries should get charged. PTs and most likely FC were all wired to do so. Even the SOBs that I have owned worked the same.
I'm waiting to hear from Stephen Birtles regarding his Ontario arrival time...I might get over to the river Friday.
Good luck.
Curt Sprenger
Anaheim Hills, CA
On Tue, Nov 10, 2009 at 7:40 PM, Chuck Wheeler <"cwheeler@kathleenwheeler.com"> wrote:
Ernie,
accept a charge.
- Chuck
Wheeler-
From: "WanderlodgeForum@yahoogroups.com" [mailto:"WanderlodgeForum@yahoogroups.com"] On Behalf Of Ernie Ekberg
9:08 PM
electrical issue
batteries. After being parked with generator running, I now have 13
83PT40
Wanderlodge
--- On Tue, 11/10/09, Chuck Wheeler <"cwheeler@kathleenwheeler.com">
From: Chuck Wheeler <"cwheeler@kathleenwheeler.com">
Ernie,
ago.  HQ at Barstow
- Chuck Wheeler-
TX
7:45 PM
yahoogroups. com
electrical issue
and all is well.
generator battery.
11-11-2009, 02:49
electrical issue
Hi fred, thats what I plan on doing. But I already have an extra charger. volts on gen gauge have come up a littel. Ernie
83PT40
Wanderlodge
--- On Tue, 11/10/09, Fred Hulse wrote:
Subject: Re: [WanderlodgeForum] electrical issue
Date: Tuesday, November 10, 2009, 9:15 PM
Ernie
Keep us up to date.
Fred Hulse
Morristown Arizona
11-11-2009, 02:52
electrical issue
Chuck, my engine volts are now up to close to 14. Looks like it's all downhill to the Colorado River from here. Ernie- not getting use to the trains
83PT40
Wanderlodge
Date: Tuesday, November 10, 2009, 9:40 PM
Ernie,
Unless you have a very small charger you should be able to run on the generator/charger during the daytime. I did an all nighter trying to stay ahead of a blizzard and every thing kept running. On our coach there is something about where the voltmeter is connected that doesn’t give an accurate reading when all the lights are on and it is running off the charger. I think it may be a ground issue because reading right at the batteries the voltage was 13.7vdc but the gauge only showed 12 and a hair. (Scientific term) I have been thinking about taking the voltmeter leads all the way to the battery so I would have an accurate reading of what is going on. Remember, if your batteries are in good shape and they have been run down they will come up to voltage slowly as they accept a charge.
- Chuck Wheeler-
From: WanderlodgeForum@ yahoogroups. com [mailto: WanderlodgeForum@ yahoogroups. com ] On Behalf Of Ernie Ekberg
Sent: Tuesday, November 10, 2009 9:08 PM
Hi Chuck, I have a total of 4 house/starter batteries. After being parked with generatorrunning, I now have 13 volts on generator battery. So somewhere along the line, after the initial start of the generator, that battery has come up.
83PT40
Wanderlodge
--- On Tue, 11/10/09, Chuck Wheeler < cwheeler@kathleenwh eeler.com > wrote:
From: Chuck Wheeler < cwheeler@kathleenwh eeler.com >
Ernie,
- Chuck Wheeler-
