Surging house water pumps
11-12-2009, 03:18
Rick,
I see your in Iowa and were commenting on the cold weather. This is 'Indian Summer' and we feel very grateful here. If you stick around a few more weeks you can experience the beginning of our normal weather ... which is brutal and has taught me that I would have died my first winter if I had been a pioneer.
Roger Webb
91 WL
Cedar Rapids, IA
-----Original Message-----
Sent: Thu, Nov 12, 2009 6:55 am
Subject: Re: [WanderlodgeForum] Re: Surging house water pumps
Wow, so many responses already! Thanks all.
Bob, the pumps I put on are the same ones that came off; Shurflos. Soif the wiring worked for the old ones would that meanit wouldbe adequate for the new ones?
Pete and Wayne, regarding addingan accumulator tank. That sounds complicated to me. I had previously had one pump that always worked good and didn't surge. Maybe with two working such is needed?
Greg, regarding the back flow valve; instead of removing and plugging lines, would simply shutting a pumps incoming and outgoing valves off suffice?
Ralph, newby question. Where is the Sporlan located?
Rick
1993 WLSA
in Iowa (wherethe water at least works, andit's too cold to putz with it quite yet this morning.)
Sent: Thu, November 12, 2009 1:53:38 AM
Subject: [WanderlodgeForum] Re: Surging house water pumps
it sounds like one of the new pumps has a bad backflow valve. remove the lines from one pumpat a time and plug the ends with a bolts and hose clamps.
--- In "WanderlodgeForum%40yahoogroups.com", "davisgr" wrote:
> What can I do stop my house water pumps from "surging"; runs for a couple of seconds, hesitates a moment, runs for a couple of seconds, etc.? Both pumps are new. One does it worse than the other, depending on the load being put on it. I have tried running all faucets at once for a while. I have tried opening the faucet valve located in the same compartment and draining water from there.
> Rick Davis
> 1993 WLSA
> Loudon, TN
> (at HWH in Iowa tonight-getting colder!)
11-12-2009, 06:56
Rick - I'll answer what I can.
> Bob, the pumps I put on are the same ones that came off; Shurflos. So if the
wiring worked for the old ones would that mean it would be adequate for the new
ones?
Do you know the new and old pump model names/numbers?
If the pumps are the same model then the wiring should be fine. In our case the
new Shurflo "Extreme" model draws twice as much current as the old one. There
are a lot of Shurflo models. Expect 5-8 amps for the smaller Shurflos, 10-14
for the the high output types.
Regarding an accumulator, if the old pumps worked without one and the new pumps
don't, then the new pumps may have more output (which, BTW, means they probably
draw more current). Adding an accumulator is easy because it only requires a
'T' fitting after the pump. Closer to the pump is good, but house systems often
have long distances between the pump and accumulator. In any case, the
accumulator T should be between the pump and the first faucet.
Food for thought: In 1993 Shurflo pumps did not have much output and did not
draw much current. This probably explains why BB used two. A single
high-output Shurflo Extreme model would easily supply the whole rig. I can wash
the car from our tank and Shurflo Extreme while there is still enough pressure
and volume at the inside faucets.
Bob Griesel '84 FC31 WLII WA
> Pete and Wayne, regarding adding an accumulator tank. That sounds
> Rick
> 1993 WLSA
> in Iowa (where the water at least works, and it's too cold to putz with it
> Â
> ________________________________
> From: gregory O
> Â
> > Rick Davis
> > 1993 WLSA
> > Loudon, TN
11-12-2009, 08:25
You probably have an accumulator tank already. It might be short of air or the bladder has leaked (rendering the tank useless), etc.
The link shows the before and after of the pump replacement job I did on my coach. The accumulator tank is mis-labeled as "expansion tank"... you probably have one already. The sporlan valve is also labeled in one of these shots.
(former) '95 Blue Bird Wanderlodge WBDA 42
El Sobrante CA
"aeonix1@mac.com"
Rick
1993 WLSA
To:"WanderlodgeForum@yahoogroups.com"
Sent:Thu, November 12, 2009 1:53:38 AM
Subject:[WanderlodgeForum] Re: Surging house water pumps
> Rick Davis
> 1993 WLSA
> Loudon, TN
11-12-2009, 18:06
Yes Rick. that would be the way to go. turn of the water to one pump at a time
but you may need to also disable the electric on that pump because it may start
up when the pressures equal out past a bad check/backflow valve.
Greg
94ptca
> Rick
> 1993 WLSA
> Â
> From: gregory O
> Â
> > Rick Davis
> > 1993 WLSA
> > Loudon, TN
11-14-2009, 04:20
Thanks again to all that responded. We are finally in one spot for a few days so will attack your various suggestions soon. I see an eventualchange-out to a single higher pressure pump in the making. Thanks for the pic Pete.
Rick and Marilyn Davis
1993 "freeNeasy"
Loudon, TN
(in Jonesboro, AR)
Sent: Thu, November 12, 2009 3:25:18 PM
El Sobrante CA
"aeonix1@mac.com"
Rick
1993 WLSA
> Rick Davis
> 1993
WLSA
> Loudon, TN
11-15-2009, 02:38
I admit I haven't read all the posts but Camping World and others sell these cute little bladder air charged tanks. Placing several of these in the coach allow for almost a half gallon of water charge before the pump kicks in, allows it to run longer and with a more smooth pressure curve
Gary
86pt40
Date: Thursday, November 12, 2009, 1:53 AM
> Rick Davis
> 1993 WLSA
> Loudon, TN
