XXV water regulator
11-24-2009, 12:24
XXV water regulator
This is my second XXV to put flooring in and also the second coach to have the
water regulator break and flood the coach. I don't know if this is a coincidence
or a bad batch of regulators, but I would inspect those that have the XXVs for
potential problems.
You have to remove the vertical panel, with the speaker on the street side
bedroom run to access this regulator.
Ernie -83PT40
New River, Az
11-24-2009, 15:52
XXV water regulator
Well, That's what happen to my XXV also. 2 regulators in 2 years. the second drowned my floors. Thanks Ernie, the floor and carpet is great. I made a change to my water regulator. I put in a filler then a looped hose then the regulator, (all Brass). Here are 3 pic's of what I did. The looped hose is so I can pull the line out from the outside and reach in behind built-in bed stand.
Paul WIlliams
40 XXV 8V92
South Lake Tahoe, CA
-----Original Message-----
Sent: Tue, Nov 24, 2009 3:24 pm
Subject: [WanderlodgeForum] XXV water regulator
This is my second XXV to put flooring in and also the second coach to have the water regulator break and flood the coach. I don't know if this is a coincidence or a bad batch of regulators, but I would inspect those that have the XXVs for potential problems.
You have to remove the vertical panel, with the speaker on the street side bedroom run to access this regulator.
Ernie -83PT40
New River, Az
11-25-2009, 02:35
XXV water regulator
Yes, both of those failed.
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Wed, 11/25/09, pattypape wrote:
Subject: [WanderlodgeForum] Re: XXV water regulator
Date: Wednesday, November 25, 2009, 8:23 AM
Is this to replace the plastic Jabsco pressure reducer at the city input hose connection?? ??
Bill 88 FC Michigan
--- In WanderlodgeForum@ yahoogroups. com, Ernie Ekberg wrote:
> Paul, can you tell us the brand name of that brass regulator?
> Thanks, Ernie
> Ernie Ekberg
> 83PT40
> Wanderlodge
> http://autos. groups.yahoo. com/group/ erniesremodeling andrepair
> --- On Tue, 11/24/09, PRWillms@... wrote:
> From: PRWillms@... > Subject: Re:
[WanderlodgeForum] XXV water regulator [3 Attachments]
> To: WanderlodgeForum@ yahoogroups. com
> Date: Tuesday, November 24, 2009, 9:52 PM
> Â
> [Attachment( s) from PRWillms@... included below]
> Paul WIlliams
> 40 XXV 8V92
> From: Ernie E
> Â
> Ernie -83PT40
> New River, Az
11-25-2009, 03:00
XXV water regulator
Thanks Ernie
another one for the repair list
Waiting for the part number
Bill 88 FC
> Ernie Ekberg
> 83PT40
> Wanderlodge
> From: pattypape
> Â
connection?? ??
> Bill 88 FC Michigan
> > Thanks, Ernie
> > Ernie Ekberg
> > 83PT40
> > Wanderlodge
> > --- On Tue, 11/24/09, PRWillms@ wrote:
> > From: PRWillms@ > > Subject: Re: [WanderlodgeForum] XXV water regulator [3 Attachments]
> > ÂÂ
> > [Attachment( s) from PRWillms@ included below]
> > Paul WIlliams
> > 40 XXV 8V92
> > From: Ernie E
> > ÂÂ
> > Ernie -83PT40
> > New River, Az
11-25-2009, 04:57
XXV water regulator
Hi All. I am in Alaska working my month on but I sure can. Wilkins Regulator 70 1/2in or a Wilkins 600 1/2in. I have enclosed a spec sheet for both. I had to go with the 70 because I needed it NOW and the plumbing store had it the next day. Go to a good plumbing store and get quality. The 70 and 600 are the same in the regulator part. There is a inlet screen on the 600. Both units can be repaired with kits.
I took my Jabsco regulator to a metal shop and had a blank plate made that has a hole in the middle for the filler. This link is the filler I used to screw into the blank plate after I painted the plate.
http://www.idealtruevalue.com/servlet/the-60473/Detail
I hope the info is usable to you. g/l
Paul Williams
88XXV 8V92
South Lake Tahoe.
Sent: Wed, Nov 25, 2009 4:53 am
Thanks, Ernie
83PT40
Wanderlodge
Paul WIlliams
40 XXV 8V92
Ernie -83PT40
New River, Az
