Jake brake and High Idle
11-27-2009, 12:22
After having 2 different mechanics work on my coach a couple years ago, I had no
jake or high idle. Today, that changed. John Rud has a fella that is a 2 stroke guy and he came out to look at my old bus. He checked, proded, used various electrical instruments and got my jake to work! Although, the only way it will work is when I manually turn it on, but that is better then the nothing I have been putting up with. The high idle has lost the small air line, he said probably melted on the exhaust and he would have to look under the bed. I told him, I can do that and if I find that line I can connect it and reroute it away from exhaust heat. So, I am a happy camper. So- bring on those mountains, I can feel better about them now. Ernie- 83PT40 in New River, Az-- where it is flat |
11-27-2009, 13:30
Glad that John knew someone Ernie. This is good news. I have some plastic
air line here unless you find some on the road. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 12:22 AM 11/28/2009 +0000, you wrote: >After having 2 different mechanics work on my coach a couple years ago, I >had no jake or high idle. Today, that changed. John Rud has a fella that >is a 2 stroke guy and he came out to look at my old bus. >He checked, proded, used various electrical instruments and got my >jake to work! Although, the only way it will work is when I manually turn >it on, but that is better then the nothing I have been putting up with. >The high idle has lost the small air line, he said probably melted on the >exhaust and he would have to look under the bed. I told him, I can do that >and if I find that line I can connect it and reroute it away from exhaust heat. >So, I am a happy camper. >So- bring on those mountains, I can feel better about them now. >Ernie- 83PT40 in New River, Az-- where it is flat > > |
11-27-2009, 13:47
