Leaking fluid
12-02-2009, 14:15
Leaking fluid
It seems I've developed a leak. It appears the piston that pushes the generator
our is leaking. I haven't made an attempt to pull it yet and I thought I would
ask here first so I don't mess something up. Is this something easy to fix,
i.e. replacing an O-ring? Or, is it something that I have to replace
completely?
Thanks for the help.
Jerry
85 PT40
12-02-2009, 15:21
Leaking fluid
Easy fix. Two seals as I recall. Pull the piston, unscrew the cap on the piston
body, go to hydraulic shop to match the seals and replace. Do not even unhook
the lines.
1991 WB40 "Texas Minivan"
Sent from my iPhone
12-02-2009, 15:40
Leaking fluid
Mike - Thanks! That sounds pretty easy. Appreciate the tip.
Jerry
85 PT40
Sent: Wed, December 2, 2009 7:21:26 PM
Subject: [WanderlodgeForum] Leaking fluid
Easy fix. Two seals as I recall. Pull the piston, unscrew the cap on the piston body, go to hydraulic shop to match the seals and replace. Do not even unhook the lines.
Sent from my iPhone
12-02-2009, 15:43
Leaking fluid
Jerry,
Do a search on "gen slide" on this site and the WOG site. You should get several hits.
John Finn, member of the 'Bird forums, will be camped at Pt.. Mugu in the near future. If you don't mind, I'll forward your contact information to John. Maybe you folks can meet up. Let me know if it's okay to send John your contact information. Thanks.
Curt Sprenger
Anaheim Hills, CA
On Wed, Dec 2, 2009 at 6:15 PM, jburgessx2 <"jburgessx2@yahoo.com"> wrote:
It seems I've developed a leak. It appears the piston that pushes the generator our is leaking. I haven't made an attempt to pull it yet and I thought I would ask here first so I don't mess something up. Is this something easy to fix, i.e. replacing an O-ring? Or, is it something that I have to replace completely?
Jerry
85 PT40
