Leaking fluid
12-02-2009, 14:15
Leaking fluid
It seems I've developed a leak. It appears the piston that pushes the generator
our is leaking. I haven't made an attempt to pull it yet and I thought I would ask here first so I don't mess something up. Is this something easy to fix, i.e. replacing an O-ring? Or, is it something that I have to replace completely? Thanks for the help. Jerry 85 PT40 |
12-02-2009, 15:21
Leaking fluid
Easy fix. Two seals as I recall. Pull the piston, unscrew the cap on the piston
body, go to hydraulic shop to match the seals and replace. Do not even unhook the lines. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX Sent from my iPhone |
12-02-2009, 15:40
Leaking fluid
Mike - Thanks! That sounds pretty easy. Appreciate the tip.
Jerry
85 PT40
From: Michael Bulriss <mbulriss@...> To: "WanderlodgeForum@yahoogroups.com" Sent: Wed, December 2, 2009 7:21:26 PM Subject: [WanderlodgeForum] Leaking fluid Easy fix. Two seals as I recall. Pull the piston, unscrew the cap on the piston body, go to hydraulic shop to match the seals and replace. Do not even unhook the lines. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX Sent from my iPhone |
12-02-2009, 15:43
Leaking fluid
Jerry,
Do a search on "gen slide" on this site and the WOG site. You should get several hits. John Finn, member of the 'Bird forums, will be camped at Pt.. Mugu in the near future. If you don't mind, I'll forward your contact information to John. Maybe you folks can meet up. Let me know if it's okay to send John your contact information. Thanks. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Wed, Dec 2, 2009 at 6:15 PM, jburgessx2 <"jburgessx2@yahoo.com"> wrote:
