Primus heat
12-03-2009, 05:04
Primus heat
I want to convert my primus system to a diesel fired system, I understand there
two different systems ava, anyone have a recomendation? Lee Brown 94WB40 |
12-03-2009, 09:56
Primus heat
Why are you Changing systems
Stephen 97 bmc 37 --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@...> wrote: > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > Lee Brown 94WB40 > |
12-03-2009, 11:35
Primus heat
lee,
Hydro hot is available from BB sale
john redden
91PT-40
NC
In a message dated 12/3/2009 11:23:08 P.M. Eastern Standard Time, marvwheeler@... writes:
12-03-2009, 12:01
Primus heat
Lee.
I have decided to stick with Primus. Are you going to sell your old primus parts? John Redden
91PT-40
NC
In a message dated 12/3/2009 4:59:57 P.M. Eastern Standard Time, cape0001@... writes:
12-03-2009, 14:49
Primus heat
Steven, availability of parts, can't get tech advice, always running low on
propane, noisy boilers. other then that it's ok Lee Brown 94WB40 --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > Why are you Changing systems > > Stephen 97 bmc 37 > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > Lee Brown 94WB40 > > > |
12-03-2009, 14:59
Primus heat
Lee
Have a look into a system called Hurricane, I think that is what it was that I saw. It is a wabasto fired system like a mini aqua hot and on a '93 that I did a PDI on, the system replaced the Primus and was installed in the same space. It was an excellent install and looked great besides working great. It was also diesel fired instead of LP. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "dreamcatcher7300" <bat73@...> Date: Fri, 04 Dec 2009 02:49:38 To: Subject: [WanderlodgeForum] Re: Primus heat Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > Why are you Changing systems > > Stephen 97 bmc 37 > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > Lee Brown 94WB40 > > > ------------------------------------ Yahoo! Groups Links |
12-03-2009, 15:24
Primus heat
we have the parts and we will offer tech advise
if they are noisy I would clean the boiler and check the burner grate if you change to webasto be prepared to pay around 2600.00 plus labour for the install around 5,000 grand complete for a lot less I can replace all the electronic Gas solenoid, pumps, electrode, burner plate feel free to give me a call Stephen 77fc35 with a webasto 97 bmc 37 with an aquahot (its half a Webasto) --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@...> wrote: > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > Why are you Changing systems > > > > Stephen 97 bmc 37 > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > Lee Brown 94WB40 > > > > > > |
12-03-2009, 15:28
Primus heat
The hurricane is produced by ITR in Canada and is not webasto fired
they have their own Burner Stephen 97 BMC 37 dupreeproducts.com Quality Bluebird parts --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > Lee > Have a look into a system called Hurricane, I think that is what it was that I saw. It is a wabasto fired system like a mini aqua hot and on a '93 that I did a PDI on, the system replaced the Primus and was installed in the same space. It was an excellent install and looked great besides working great. It was also diesel fired instead of LP. > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "dreamcatcher7300" <bat73@...> > Date: Fri, 04 Dec 2009 02:49:38 > To: > Subject: [WanderlodgeForum] Re: Primus heat > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > Why are you Changing systems > > > > Stephen 97 bmc 37 > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > Lee Brown 94WB40 > > > > > > > > > > ------------------------------------ > > Yahoo! Groups Links > |
12-03-2009, 15:33
Primus heat
Steve I meant webasto type system. Sorry not to be very exacting!
Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "cape0001" Date: Fri, 04 Dec 2009 03:28:54 To: Subject: [WanderlodgeForum] Re: Primus heat The hurricane is produced by ITR in Canada and is not webasto fired they have their own Burner Stephen 97 BMC 37 dupreeproducts.com Quality Bluebird parts --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > Lee > Have a look into a system called Hurricane, I think that is what it was that I saw. It is a wabasto fired system like a mini aqua hot and on a '93 that I did a PDI on, the system replaced the Primus and was installed in the same space. It was an excellent install and looked great besides working great. It was also diesel fired instead of LP. > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "dreamcatcher7300" <bat73@...> > Date: Fri, 04 Dec 2009 02:49:38 > To: > Subject: [WanderlodgeForum] Re: Primus heat > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > Why are you Changing systems > > > > Stephen 97 bmc 37 > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > Lee Brown 94WB40 > > > > > > > > > > ------------------------------------ > > Yahoo! Groups Links > ------------------------------------ Yahoo! Groups Links |
12-03-2009, 16:22
Primus heat
Ralph:
The Hurricane system is what is in the M380. It works very well. The only draw back is that it is a little noisier than I would like but I guess that is the nature of the beast. It is good to see you posting. Marv Wheeler 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > Steve I meant webasto type system. Sorry not to be very exacting! > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "cape0001" > Date: Fri, 04 Dec 2009 03:28:54 > To: > Subject: [WanderlodgeForum] Re: Primus heat > > The hurricane is produced by ITR in Canada and is not webasto fired > they have their own Burner > Stephen 97 BMC 37 > dupreeproducts.com > Quality Bluebird parts > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > > > Lee > > Have a look into a system called Hurricane, I think that is what it was that I saw. It is a wabasto fired system like a mini aqua hot and on a '93 that I did a PDI on, the system replaced the Primus and was installed in the same space. It was an excellent install and looked great besides working great. It was also diesel fired instead of LP. > > Safe travels, Ralph & Charolette Fullenwider > > '84 FC35 "Ruff Diamond" > > Duncan, Oklahoma > > Sent via BlackBerry by AT&T > > > > -----Original Message----- > > From: "dreamcatcher7300" <bat73@> > > Date: Fri, 04 Dec 2009 02:49:38 > > To: > > Subject: [WanderlodgeForum] Re: Primus heat > > > > Steven, availability of parts, can't get tech advice, always running low on propane, noisy boilers. other then that it's ok Lee Brown 94WB40 > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > > > > > Why are you Changing systems > > > > > > Stephen 97 bmc 37 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@> wrote: > > > > > > > > I want to convert my primus system to a diesel fired system, I understand there two different systems ava, anyone have a recomendation? > > > > Lee Brown 94WB40 > > > > > > > > > > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > ------------------------------------ > > Yahoo! Groups Links > |
