%0 amp connector part#
12-05-2009, 16:13
I want to make up a new 50 am cord for our - Chuck 1982 FC 31SB |
12-05-2009, 17:05
Chuck - Try 947B. That is the listing number on mine.
Bob Griesel '83 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > I want to make up a new 50 am cord for our 82FC. Does any one know the NEMA > number for the female plug? The current one is so worn that the numbers > cannot be read. > > > > - Chuck Wheeler- > > 1982 FC 31SB Fort Worth TX > |
12-05-2009, 18:45
Thanks, I’ll give it a look. - Chuck 1982 FC 31SB From: Chuck - Try 947B. That is the listing number on mine. Bob Griesel '83 FC31 WLII WA --- In "WanderlodgeForum%40yahoogroups.com", "Chuck Wheeler" > > I want to make up a new 50 am cord for our 82FC. Does any one know the NEMA > number for the female plug? The current one is so worn that the numbers > cannot be read. > > > > - Chuck Wheeler- > > 1982 FC 31SB > |
12-05-2009, 18:45
12-06-2009, 08:39
Chuck, I thought it was NEMA L6-50, but when I just looked it up, the L6 configuration now lacks neutral. Instead, of the three pins being hot-hot-neutral, with the ground connection made via contacts in the case, the L6 now contains one pin dedicated to ground. Apparently 'code' now does not like the older version grounding via the case. If we want 240 and 120 vac (2 hot legs, neutral and ground), apparently we are supposed to use a NEMA L14 4-pole connector that has four pins, hot, hot, neutral and ground. I just replaced my original 1976 50 amp male connector on the bus to make it compatible with the 50 amp 240/120 volt cables I already use around marinas (3-poles plus case ground). When I spoke to a licensed electrician recently about installing a 50 amp receptacle outside the garage, he told me that code required this new four pin connector that I see associated with home generator connectors. Perhaps someone who knows more can elaborate. Regards, Donn 76 33FC South Kingstown, RI http://en.wikipedia.org/wiki/NEMA_connector#NEMA_L6 https://www.hubbellnet.com/max_htm/PDF_L.../h4636.pdf From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Chuck Wheeler Sent: Saturday, December 05, 2009 11:13 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] %0 amp connector part# I want to make up a new 50 am cord for our 82FC. Does any one know the NEMA number for the female plug? The current one is so worn that the numbers cannot be read. - Chuck Wheeler- 1982 FC 31SB Fort Worth TX |
12-06-2009, 08:56
I agree with Don. If you are rebuilding the shore cable anyway, replace the
male connecter and go with the 4-pin system. If they still make the old style connector, here is the complete information (now that it is daylight and NOT snowing!) off my 50 connectors: Arrow-Harting Hart-Lock Made in USA U/L Listed 947B Connector 50A 250VAC Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Donald Watson" > > Chuck, > > I thought it was NEMA L6-50, but when I just looked it up, the L6 > configuration now lacks neutral. Instead, of the three pins being > hot-hot-neutral, with the ground connection made via contacts in the case, > the L6 now contains one pin dedicated to ground. > > Apparently 'code' now does not like the older version grounding via the > case. If we want 240 and 120 vac (2 hot legs, neutral and ground), > apparently we are supposed to use a NEMA L14 4-pole connector that has four > pins, hot, hot, neutral and ground. > > I just replaced my original 1976 50 amp male connector on the bus to make it > compatible with the 50 amp 240/120 volt cables I already use around marinas > (3-poles plus case ground). When I spoke to a licensed electrician recently > about installing a 50 amp receptacle outside the garage, he told me that > code required this new four pin connector that I see associated with home > generator connectors. > > Perhaps someone who knows more can elaborate. > > Regards, > > Donn > 76 33FC > South Kingstown, RI > > http://en.wikipedia.org/wiki/NEMA_connector#NEMA_L6 > > https://www.hubbellnet.com/max_htm/PDF_L.../h4636.pdf > > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Chuck Wheeler > Sent: Saturday, December 05, 2009 11:13 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] %0 amp connector part# > > I want to make up a new 50 am cord for our 82FC. Does any one know the NEMA > number for the female plug? The current one is so worn that the numbers > cannot be read. > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX > |
12-06-2009, 10:08
Thanks Bob! Your information allow me to - Chuck 1982 FC 31SB From: I agree with Don. If you are rebuilding the shore cable anyway, replace the male connecter and go with the 4-pin system. If they still make the old style connector, here is the complete information (now that it is daylight and NOT snowing!) off my 50 connectors: Arrow-Harting Hart-Lock Made in U/L Listed 947B Connector 50A 250VAC Bob Griesel '84 FC31 WLII WA --- In "WanderlodgeForum%40yahoogroups.com", "Donald Watson" > > Chuck, > > I thought it was NEMA L6-50, but when I just looked it up, the L6 > configuration now lacks neutral. Instead, of the three pins being > hot-hot-neutral, with the ground connection made via contacts in the case, > the L6 now contains one pin dedicated to ground. > > Apparently 'code' now does not like the older version grounding via the > case. If we want 240 and 120 vac (2 hot legs, neutral and ground), > apparently we are supposed to use a NEMA L14 4-pole connector that has four > pins, hot, hot, neutral and ground. > > I just replaced my original 1976 50 amp male connector on the bus to make it > compatible with the 50 amp 240/120 volt cables I already use around marinas > (3-poles plus case ground). When I spoke to a licensed electrician recently > about installing a 50 amp receptacle outside the garage, he told me that > code required this new four pin connector that I see associated with home > generator connectors. > > Perhaps someone who knows more can elaborate. > > Regards, > > Donn > 76 33FC > > > http://en.wikipedia > > https://www. > > > From: "WanderlodgeForum%40yahoogroups.com" > [mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of Chuck Wheeler > Sent: Saturday, December 05, 2009 11:13 PM > To: "WanderlodgeForum%40yahoogroups.com" > Subject: [WanderlodgeForum] %0 amp connector part# > > I want to make up a new 50 am cord for our 82FC. Does any one know the NEMA > number for the female plug? The current one is so worn that the numbers > cannot be read. > - Chuck Wheeler- > 1982 FC 31SB > |
