Water pressure regulator - repaired : )
12-17-2009, 17:20
Hello,
Thanks for the replies and advice. We found the part at a local boat place and
did have to pull back some carpet, but got the repair done and put back
together. It looks great and works perfectly!
Does anyone know where to find a new door handle for the bathroom? It is like a
brushed chrome in the hallway with a flat handle similar to the bus entry style
but inside the bathroom it is a lever?? style (not round) and polished brass.
Has no writing on it what so ever.
Thanks again for all your help!
Robert & Teri Rahn
1988 PT40
12-18-2009, 02:17
Robert,
That, too, sounds just like the one we had in the '90. What is wrong with yours?
When mine broke internally, I was able to take it apart and fix it. I beleive
there was a broken spring.
Rich D. '99LXi43' CT
--- In WanderlodgeForum@yahoogroups.com, "chaunceyboyblu"
> Hello,
and did have to pull back some carpet, but got the repair done and put back
a brushed chrome in the hallway with a flat handle similar to the bus entry
style but inside the bathroom it is a lever?? style (not round) and polished
brass. Has no writing on it what so ever.
> Robert & Teri Rahn
> 1988 PT40
12-18-2009, 08:01
It has been missing pieces for years. Has never had the locking mechanism since
we purchased it. Now the handle has gotten to the point where it will keep
changing position and sometimes fall off. Yesterday it turned too far and
locked us out of the bathroom because the handle was catching on the door trim
inside the bathroom. The polished brass finish is also coming off pretty badly,
so it really is just time for replacement but I cannot seem to find any writing
on it anywhere to see who makes it. Anyone have any ideas?
Thanks so much!
--- In WanderlodgeForum@yahoogroups.com, "g_man1146" wrote:
> Robert,
yours? When mine broke internally, I was able to take it apart and fix it. I
beleive there was a broken spring.
> > Hello,
like a brushed chrome in the hallway with a flat handle similar to the bus entry
> > Robert & Teri Rahn
> > 1988 PT40
12-18-2009, 09:21
I have Rich's old '90 - learning about things he has done from these posts Smile
I agree it sounds like the same lock, although this one is brushed nickel. I'm
guessing your shower was gold/brass?
I suspect this one could be hard to track down. I don't know if that is the sort
of part that would be in the build list for your coach that Parliament has, but
it might be.
Don Bradner
90 PT40 "Blue Thunder"
>mechanism since we purchased it. Now the handle has gotten to the point
>where it will keep changing position and sometimes fall off. Yesterday it
>turned too far and locked us out of the bathroom because the handle was
>catching on the door trim inside the bathroom. The polished brass finish
>is also coming off pretty badly, so it really is just time for replacement
>but I cannot seem to find any writing on it anywhere to see who makes it.
>Thanks so much!
>> Robert,
>with yours? When mine broke internally, I was able to take it apart and
>fix it. I beleive there was a broken spring.
>> > Hello,
>place and did have to pull back some carpet, but got the repair done and
>put back together. It looks great and works perfectly!
>is like a brushed chrome in the hallway with a flat handle similar to the
>bus entry style but inside the bathroom it is a lever?? style (not round)
>and polished brass. Has no writing on it what so ever.
>> > Robert & Teri Rahn
>> > 1988 PT40
>Yahoo! Groups Links
