Dometci 7030 help
06-17-2005, 11:27
Dometci 7030 help
I have a dometic 7030 in my offset isle pt-42. Refer seems to work most
of the time. I suspect the board needs replacing. I have done this before where I can access the back refer from outside the coach. In this coach the refer does not backup to the outside wall and vents under the coach. I am not sure how to access the board to replace it.I need to replace it before a upcoming 7000 mile trip. Its a 3 way refer. Thanks. Jamie pt 42 1995 |
06-17-2005, 12:27
Dometci 7030 help
Replace with a Dinosaur Board made in Oregon. Best replacement you can
get.... Blair At 04:27 PM 6/17/2005, you wrote: >I have a dometic 7030 in my offset isle pt-42. Refer seems to work most >of the time. I suspect the board needs replacing. I have done this >before where I can access the back refer from outside the coach. In >this coach the refer does not backup to the outside wall and vents >under the coach. I am not sure how to access the board to replace it.I >need to replace it before a upcoming 7000 mile trip. Its a 3 way >refer. Thanks. > >Jamie >pt 42 1995 > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-17-2005, 14:00
Dometci 7030 help
I know what to replace it with I just dont know where to find it. I
usually go to the outside of the coach and find the refer hatch. I dont have one with this coach because it vents under the coach. The refer board must be somewhere I can access. I just dont see where. HELP. Jamie 1995 pt -42 --- In WanderlodgeForum@yahoogroups.com, Blair > Replace with a Dinosaur Board made in Oregon. Best replacement you can > get.... > Blair > > > > > At 04:27 PM 6/17/2005, you wrote: > >I have a dometic 7030 in my offset isle pt-42. Refer seems to work most > >of the time. I suspect the board needs replacing. I have done this > >before where I can access the back refer from outside the coach. In > >this coach the refer does not backup to the outside wall and vents > >under the coach. I am not sure how to access the board to replace it.I > >need to replace it before a upcoming 7000 mile trip. Its a 3 way > >refer. Thanks. > > > >Jamie > >pt 42 1995 > > > > > > > > > >---------- > >Yahoo! Groups Links > > * To visit your group on the web, go to: > > * > > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.c om/group/WanderlodgeForum/ > > > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > [Non-text portions of this message have been removed] |
06-17-2005, 15:07
Dometci 7030 help
Jamie:
Don't have a 42 angle aisle coach, but I do have the 7030. I suspect there must be some better access to the back of the fridge. The LP connection is in the back right corner (as looking at from the back) and the electric board is right above that. There is also the electric connection for the fridge. Unless BB gave extra length for both of these in order to pull the fridge out forward, There has to be an access panel. How can the fridge be vented from below???? Heat rises in order to cool the fins, There must be a top vent, and a bottom vent in order to cool the unit. Hopefully someone else with the side aisle can give you better advise. Keep us posted. William Jensen 1993 PT40 WBWL Deerfield Beach, Fl |
06-17-2005, 23:02
Dometci 7030 help
sounds like it is time to call benny at blue bird,,for some help on
that fridge,,,,, day jax fla 83 pt-40 [Non-text portions of this message have been removed] |
06-17-2005, 23:40
Dometci 7030 help
i agree that there has to be an access panal.gas refers need service yearly.i
hav a side aisle coach but mine has a house side x side amana refer unit.my refer backs up to the shower,whats behind yours? randydupree93wb ----- Original Message ----- From: William Jensen To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 17, 2005 11:07 PM Subject: [WanderlodgeForum] Re: Dometci 7030 help Jamie: Don't have a 42 angle aisle coach, but I do have the 7030. I suspect there must be some better access to the back of the fridge. The LP connection is in the back right corner (as looking at from the back) and the electric board is right above that. There is also the electric connection for the fridge. Unless BB gave extra length for both of these in order to pull the fridge out forward, There has to be an access panel. How can the fridge be vented from below???? Heat rises in order to cool the fins, There must be a top vent, and a bottom vent in order to cool the unit. Hopefully someone else with the side aisle can give you better advise. Keep us posted. William Jensen 1993 PT40 WBWL Deerfield Beach, Fl ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-18-2005, 02:23
Dometci 7030 help
Mine also backs up to the shower. I have searched every panel, I can
find. It has the roof vent but the not the normal outside wall access. I would be happy to replace it with a all electric refer but dont know if the cabinet will have to be rework to make it fit. HELP. I have looked under, side, every where and not luck. Behind it is the shower. THanks Jamie 1995 pt 42 --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > i agree that there has to be an access panal.gas refers need service yearly.i hav a side aisle coach but mine has a house side x side amana refer unit.my refer backs up to the shower,whats behind yours? randydupree93wb > ----- Original Message ----- > From: William Jensen > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 17, 2005 11:07 PM > Subject: [WanderlodgeForum] Re: Dometci 7030 help > > > Jamie: > > Don't have a 42 angle aisle coach, but I do have the 7030. I > suspect > there must be some better access to the back of the fridge. The LP > connection is in the back right corner (as looking at from the back) > and the electric board is right above that. There is also the > electric connection for the fridge. Unless BB gave extra length > for > both of these in order to pull the fridge out forward, There has to > be an access panel. > > How can the fridge be vented from below???? Heat rises in order to > cool the fins, There must be a top vent, and a bottom vent in order > to cool the unit. Hopefully someone else with the side aisle can > give > you better advise. Keep us posted. > > William Jensen > 1993 PT40 WBWL > Deerfield Beach, Fl > > > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
06-18-2005, 02:34
Dometci 7030 help
From: jvicars4 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 18, 2005 9:23 AM Subject: [WanderlodgeForum] Re: Dometci 7030 help Jamie Have you called Bennie at Blue Bird If not do your self a big favor and do it. Bob Loomas 85 PT 36 Mine also backs up to the shower. I have searched every panel, I can find. It has the roof vent but the not the normal outside wall access. I would be happy to replace it with a all electric refer but dont know if the cabinet will have to be rework to make it fit. HELP. I have looked under, side, every where and not luck. Behind it is the shower. THanks Jamie 1995 pt 42 --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > i agree that there has to be an access panal.gas refers need service yearly.i hav a side aisle coach but mine has a house side x side amana refer unit.my refer backs up to the shower,whats behind yours? randydupree93wb > ----- Original Message ----- > From: William Jensen > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 17, 2005 11:07 PM > Subject: [WanderlodgeForum] Re: Dometci 7030 help > > > Jamie: > > Don't have a 42 angle aisle coach, but I do have the 7030. I > suspect > there must be some better access to the back of the fridge. The LP > connection is in the back right corner (as looking at from the back) > and the electric board is right above that. There is also the > electric connection for the fridge. Unless BB gave extra length > for > both of these in order to pull the fridge out forward, There has to > be an access panel. > > How can the fridge be vented from below???? Heat rises in order to > cool the fins, There must be a top vent, and a bottom vent in order > to cool the unit. Hopefully someone else with the side aisle can > give > you better advise. Keep us posted. > > William Jensen > 1993 PT40 WBWL > Deerfield Beach, Fl > > > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-18-2005, 04:40
Dometci 7030 help
Ok Randy,
I also have the Amana side by side, 19 cu. ft. refer. We have a leak in the water system, i.e. the feed for the ice maker and ice water. When we had the refer out for other repairs last winter, we thought we had found the problem to be the hose washer that was hard. However, a new washer didn't seem to do it. Problem that we are trying to overcome is, how do you trouble shoot it? It only leaks when pressure is on and it is very slow. (yet enough to soak the carpet) To get at the line. etc., you have to pull the refer out. To get the refer our, you have to remove the doors which necessitates breaking the water line that goes up the door. I have not been able to determine if it is the tubing from the angle stop under the lavatory or the tubing in the refer itself. Have you had any experience with this that you can pass on? Thanks, George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD randydupree wrote: > i agree that there has to be an access panal.gas refers need > service yearly.i hav a side aisle coach but mine has a house side x > side amana refer unit.my refer backs up to the shower,whats behind > yours? randydupree93wb ---- > > |
06-18-2005, 09:00
Dometci 7030 help
its gotta come out.no way around it..randydupree93wb
----- Original Message ----- From: jvicars4 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 18, 2005 10:23 AM Subject: [WanderlodgeForum] Re: Dometci 7030 help Mine also backs up to the shower. I have searched every panel, I can find. It has the roof vent but the not the normal outside wall access. I would be happy to replace it with a all electric refer but dont know if the cabinet will have to be rework to make it fit. HELP. I have looked under, side, every where and not luck. Behind it is the shower. THanks Jamie 1995 pt 42 --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > i agree that there has to be an access panal.gas refers need service yearly.i hav a side aisle coach but mine has a house side x side amana refer unit.my refer backs up to the shower,whats behind yours? randydupree93wb > ----- Original Message ----- > From: William Jensen > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 17, 2005 11:07 PM > Subject: [WanderlodgeForum] Re: Dometci 7030 help > > > Jamie: > > Don't have a 42 angle aisle coach, but I do have the 7030. I > suspect > there must be some better access to the back of the fridge. The LP > connection is in the back right corner (as looking at from the back) > and the electric board is right above that. There is also the > electric connection for the fridge. Unless BB gave extra length > for > both of these in order to pull the fridge out forward, There has to > be an access panel. > > How can the fridge be vented from below???? Heat rises in order to > cool the fins, There must be a top vent, and a bottom vent in order > to cool the unit. Hopefully someone else with the side aisle can > give > you better advise. Keep us posted. > > William Jensen > 1993 PT40 WBWL > Deerfield Beach, Fl > > > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
