gen set oil switch
01-02-2010, 12:57
gen set oil switch
My 97 WLWB has a Power Tech Gen, Just above the starter is an oil pressure switch with a 45 degree pipe adapter and 2 wires. It is leaking and was hoping someone would have some information on this switch? Thanks Fred & Jeanne Hulse
01-02-2010, 15:30
gen set oil switch
I think that might be your oil pressure switch Fred. It shuts down the genny when the oil pressure drops too low. I ordered one from Power Tech in Leesburg FL for my 94 two years ago. Randy told me at the time that this pressure switch could be had from various sources. I'd check NAPA
2010/1/2 Fred Hulse <"fhulse@wildblue.net">
-- Rob, Sue and Joey Robinson 94 WLWB |
01-03-2010, 05:46
gen set oil switch
01-03-2010, 07:50
gen set oil switch
Rob
Thanks,I found a Power Tech distributor in South Phoenix and will visit them in the morning.
I have removed the old one and the paint on it is hiding any Identification.
I think we will be ok after I see the guy in the parts department tomorrow, if not,there are lots of good part stores on the way home.
Fred & Jeanne Hulse
01-03-2010, 07:53
gen set oil switch
Thanks Gary
I have the old out and will be looking around tomorrow.
Fred & Jeanne Hulse
