Way past cold
01-08-2010, 06:11
Way past cold
01-08-2010, 07:01
Way past cold
01-08-2010, 07:30
Way past cold
You should be happy to be still there Wallace. It was 17 when I got in my car
about 8:30 this morning. It is expected to get to 14 tomorrow morning. It isn't too bad out there because there is no significant wind. Sorry we missed you when we departed on Monday morning. You were probably having a great breakfast somewhere. R.E. (Ron) Marabito, Dalls, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Wallace Craig wrote: > > Here on SPI I am not out working on the coach; I'm sitting inside trying to stay warm. The OAT is 35.8f forcast for -30 tonight. KOA is almost empty; can't imagine where they went that they think is warmer. Keep the faith; spring is comming, > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > --- On Fri, 1/8/10, Ralph L. Fullenwider > > > From: Ralph L. Fullenwider > Subject: [WanderlodgeForum] Way past cold > To: WanderlodgeForum@... > Date: Friday, January 8, 2010, 1:42 PM > > > Good morning to everyone from BRRRR Oklahoma: > > You know it is cold when the lock on the shed out back is frozen shut hey?! > > I am doing some inside the Coach things that are on my way down the list of > to do things. Like working on the in-line duct fan from the front furnace > to the center bath on the FC's. The fan unit is plastic, as it turns out, > instead of in a metal housing, and the constant heat simply melts the > plastic housing and stops the fan blade. Having run into this same problem > in other older Coaches, I am assuming much the same is going on there as > well. I am in process of converting a refrigerator compartment 12vdc fan > into an in line duct fan. Shurflo has a unit for marine use called the > yellow tail that is a 4 inch in line duct fan but I can't find any info on > pricing or where to buy one, but this gives me something to do. > > Ok guys, your right, in answer to what your thinking, (what is he doing out > in this cold weather working on stuff?) I got "the look" earlier today and > though this item on my to do list needed to be done! ahem > > For those on the way to "Q" be safe out there. > > Safe travels, > > Ralph and Charolette Fullenwider > "84FC35 "Ruff Diamond" > Duncan, Oklahoma > > > > ------------------------------------ > > Yahoo! Groups Links > |
01-08-2010, 07:42
Way past cold
You know it is cold when the lock on the shed out back is frozen shut hey?! I am doing some inside the Coach things that are on my way down the list of to do things. Like working on the in-line duct fan from the front furnace to the center bath on the FC's. The fan unit is plastic, as it turns out, instead of in a metal housing, and the constant heat simply melts the plastic housing and stops the fan blade. Having run into this same problem in other older Coaches, I am assuming much the same is going on there as well. I am in process of converting a refrigerator compartment 12vdc fan into an in line duct fan. Shurflo has a unit for marine use called the yellow tail that is a 4 inch in line duct fan but I can't find any info on pricing or where to buy one, but this gives me something to do. Ok guys, your right, in answer to what your thinking, (what is he doing out in this cold weather working on stuff?) I got "the look" earlier today and though this item on my to do list needed to be done! ahem For those on the way to "Q" be safe out there. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma |
01-08-2010, 08:26
Way past cold
if you are looking for those yellow tail fans, in the marine world, they are called blowers and are available from west marine. in my catalogue they are 34.99 for the 4 inch. www.westmarine.com
Wanderlodge wannabee and cruising boater
1986 Citation Class c
Peter Sanderson
Comox Valley, BC
01-08-2010, 09:25
Way past cold
I'll bet you could pick just about any spot you wanted on the beach.
"bbartonwx@hotmail.com" To: WanderlodgeForum@yahoogroups.com From: wallacecraig1@... Date: Fri, 8 Jan 2010 10:11:37 -0800 Subject: Re: [WanderlodgeForum] Way past cold
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. Sign up now. |
01-08-2010, 09:46
Way past cold
01-08-2010, 09:50
Way past cold
Ralph, we've hit our high of 9F here in Rolla and expect slightly below 0F for
the next two nites...and then warmer. Dick Gideon 89 FC35 Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" wrote: > > It was 9F here this morning at 7:30AM but we are having a heat wave at > 3:00PM as it is 23F. > > Safe travels, > > Ralph and Charolette Fullenwider > "84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 10:11 AM 1/8/2010 -0800, you wrote: > > > >Here on SPI I am not out working on the coach; I'm sitting inside trying > >to stay warm. The OAT is 35.8f forcast for -30 tonight. KOA is almost > >empty; can't imagine where they went that they think is warmer. Keep the > >faith; spring is comming, > > > >Wallace Craig > >95 WLWB 42 > >Azle, Texas > > > > > >--- On Fri, 1/8/10, Ralph L. Fullenwider > >From: Ralph L. Fullenwider > >Subject: [WanderlodgeForum] Way past cold > >To: WanderlodgeForum@... > >Date: Friday, January 8, 2010, 1:42 PM > > > >Good morning to everyone from BRRRR Oklahoma: > > > >You know it is cold when the lock on the shed out back is frozen shut hey?! > > > >I am doing some inside the Coach things that are on my way down the list of > >to do things. Like working on the in-line duct fan from the front furnace > >to the center bath on the FC's. The fan unit is plastic, as it turns out, > >instead of in a metal housing, and the constant heat simply melts the > >plastic housing and stops the fan blade. Having run into this same problem > >in other older Coaches, I am assuming much the same is going on there as > >well. I am in process of converting a refrigerator compartment 12vdc fan > >into an in line duct fan. Shurflo has a unit for marine use called the > >yellow tail that is a 4 inch in line duct fan but I can't find any info on > >pricing or where to buy one, but this gives me something to do. > > > >Ok guys, your right, in answer to what your thinking, (what is he doing out > >in this cold weather working on stuff?) I got "the look" earlier today and > >though this item on my to do list needed to be done! ahem > > > >For those on the way to "Q" be safe out there. > > > >Safe travels, > > > >Ralph and Charolette Fullenwider > >"84FC35 "Ruff Diamond" > >Duncan, Oklahoma > > > > > > > > > > > >------------------------------------ > > > >Yahoo! Groups Links > > > ><http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/\ WanderlodgeForum/ > > > ><http://groups.yahoo.com/group/WanderlodgeForum/join>http://groups.yahoo.com/gr\ oup/WanderlodgeForum/join > > > > (Yahoo! ID required) > > > ><http://us.mc328.mail.yahoo.com/mc/compos...ogrou\ ps.com>WanderlodgeForum-digest@yahoogroups.com > > > > > ><http://us.mc328.mail.yahoo.com/mc/compos...d@yah\ oogroups.com>WanderlodgeForum-fullfeatured@yahoogroups.com > > > ><http://us.mc328.mail.yahoo.com/mc/compos...@yaho\ ogroups.com>WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > "84FC35 "Ruff Diamond" > Duncan, Oklahoma > |
01-08-2010, 10:58
Way past cold
It was 9F here this morning at 7:30AM but we are having a heat wave at 3:00PM as it is 23F. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 10:11 AM 1/8/2010 -0800, you wrote: >Here on SPI I am not out working on the coach; I'm sitting inside trying >to stay warm. The OAT is 35.8f forcast for -30 tonight. KOA is almost >empty; can't imagine where they went that they think is warmer. Keep the >faith; spring is comming, > >Wallace Craig >95 WLWB 42 >Azle, Texas > > >--- On Fri, 1/8/10, Ralph L. Fullenwider >From: Ralph L. Fullenwider >Subject: [WanderlodgeForum] Way past cold >To: WanderlodgeForum@Yahoogroups.com >Date: Friday, January 8, 2010, 1:42 PM > >Good morning to everyone from BRRRR Oklahoma: > >You know it is cold when the lock on the shed out back is frozen shut hey?! > >I am doing some inside the Coach things that are on my way down the list of >to do things. Like working on the in-line duct fan from the front furnace >to the center bath on the FC's. The fan unit is plastic, as it turns out, >instead of in a metal housing, and the constant heat simply melts the >plastic housing and stops the fan blade. Having run into this same problem >in other older Coaches, I am assuming much the same is going on there as >well. I am in process of converting a refrigerator compartment 12vdc fan >into an in line duct fan. Shurflo has a unit for marine use called the >yellow tail that is a 4 inch in line duct fan but I can't find any info on >pricing or where to buy one, but this gives me something to do. > >Ok guys, your right, in answer to what your thinking, (what is he doing out >in this cold weather working on stuff?) I got "the look" earlier today and >though this item on my to do list needed to be done! ahem > >For those on the way to "Q" be safe out there. > >Safe travels, > >Ralph and Charolette Fullenwider >"84FC35 "Ruff Diamond" >Duncan, Oklahoma > > > > > >------------------------------------ > >Yahoo! Groups Links > ><http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/\ WanderlodgeForum/ > ><http://groups.yahoo.com/group/WanderlodgeForum/join>http://groups.yahoo.com/gr\ oup/WanderlodgeForum/join > > (Yahoo! ID required) > ><http://us.mc328.mail.yahoo.com/mc/compos...ogrou\ ps.com>WanderlodgeForum-digest@yahoogroups.com > > ><http://us.mc328.mail.yahoo.com/mc/compos...d@yah\ oogroups.com>WanderlodgeForum-fullfeatured@yahoogroups.com > ><http://us.mc328.mail.yahoo.com/mc/compos...@yaho\ ogroups.com>WanderlodgeForum-unsubscribe@yahoogroups.com > > > > Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma |
01-08-2010, 17:52
Way past cold
Wallace, good thing you are at SPI. Here in San Diego we had to close busines
early yesterday due to 7 inches of accumulated sunshine over 70 degrees. Driving was awful. So many tops down that hair was blowing all over. Tommy Two Shoes McCarthy Pretty Penny 1995 42PT Poway, CA --- In WanderlodgeForum@yahoogroups.com, Wallace Craig wrote: > > I quite agree, rather be here at 35+- than in Dallas. Was having my beauty nap and the sleet woke me up pounding on the coach roof; dashed to the window but it had stopped. Not everyday event; I was here for the snow on Christmas of 04 which was the first in 108 years. Hopefully no repeat. Stay warm. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > --- On Fri, 1/8/10, ronmarabito2002 > > > From: ronmarabito2002 > Subject: [WanderlodgeForum] Re: Way past cold > To: WanderlodgeForum@yahoogroups.com > Date: Friday, January 8, 2010, 1:30 PM > > > You should be happy to be still there Wallace. It was 17 when I got in my car about 8:30 this morning. It is expected to get to 14 tomorrow morning. It isn't too bad out there because there is no significant wind. > > Sorry we missed you when we departed on Monday morning. You were probably having a great breakfast somewhere. > > R.E. (Ron) Marabito, Dalls, tX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > > > Here on SPI I am not out working on the coach; I'm sitting inside trying to stay warm. The OAT is 35.8f forcast for -30 tonight. KOA is almost empty; can't imagine where they went that they think is warmer. Keep the faith; spring is comming, > > > > > > Wallace Craig > > 95 WLWB 42 > > Azle, Texas > > > > --- On Fri, 1/8/10, Ralph L. Fullenwider > > > > > > From: Ralph L. Fullenwider > > Subject: [WanderlodgeForum] Way past cold > > To: WanderlodgeForum@ > > Date: Friday, January 8, 2010, 1:42 PM > > > > > > Good morning to everyone from BRRRR Oklahoma: > > > > You know it is cold when the lock on the shed out back is frozen shut hey?! > > > > I am doing some inside the Coach things that are on my way down the list of > > to do things. Like working on the in-line duct fan from the front furnace > > to the center bath on the FC's. The fan unit is plastic, as it turns out, > > instead of in a metal housing, and the constant heat simply melts the > > plastic housing and stops the fan blade. Having run into this same problem > > in other older Coaches, I am assuming much the same is going on there as > > well. I am in process of converting a refrigerator compartment 12vdc fan > > into an in line duct fan. Shurflo has a unit for marine use called the > > yellow tail that is a 4 inch in line duct fan but I can't find any info on > > pricing or where to buy one, but this gives me something to do. > > > > Ok guys, your right, in answer to what your thinking, (what is he doing out > > in this cold weather working on stuff?) I got "the look" earlier today and > > though this item on my to do list needed to be done! ahem > > > > For those on the way to "Q" be safe out there. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > "84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > ------------------------------------ > > Yahoo! Groups Links > |
