Pressure washing the 6v92
01-08-2010, 08:58
I wanted to clean up the oil mess on the 6v92 motor using a pressure washer. Is
there anything I need to do or be careful with? I just plan on doing the bottom where all the oil/dirt gathers then falls on the toad. Should I leave it running while I do this? Jerry 85 PT40 Sent via BlackBerry from T-Mobile |
01-08-2010, 11:47
01-08-2010, 12:14
Keep the alternator dry.
Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, jburgessx2@... wrote: > > I wanted to clean up the oil mess on the 6v92 motor using a pressure washer. Is there anything I need to do or be careful with? I just plan on doing the bottom where all the oil/dirt gathers then falls on the toad. Should I leave it running while I do this? > > Jerry > 85 PT40 > Sent via BlackBerry from T-Mobile > |
01-08-2010, 12:31
01-08-2010, 12:54
Thanks Ernie. I thought it was okay but just wanted to check. Try not to freeze there. It was cold here today too - only made it to 69 degrees Jerry 85 PT40 Port Hueneme, CA Sent via BlackBerry from T-Mobile From: Ernie Ekberg Date: Fri, 8 Jan 2010 15:47:42 -0800 (PST) To: Subject: Re: [WanderlodgeForum] Pressure washing the 6v92
01-08-2010, 13:04
01-24-2010, 01:01
01-24-2010, 01:02
