Damage
06-18-2005, 13:00
Damage
i can't help with your problems, as my 83 pt40 is not the same, as it
has basement air, and different hook-ups,,, but i did want to offer you my sympathy, and say glad you are alright.,,,as i hit a deer last month,, just grazed him,, a big buck,,, but found out how good it was to have that big solid bumper across the front of this old bird !! i just knew the front end was wiped out, but almost no damage !! glad you were not hurt,,,,, you never know how bad it could have been,,,, day jax fla 83pt-40 n a message dated 6/19/2005 12:25:02 AM Eastern Standard Time, ssbreese@... writes: > Subj: [WanderlodgeForum] Damage > Date:6/19/2005 12:25:02 AM Eastern Standard Time > From:ssbreese@... > Reply-to:WanderlodgeForum@yahoogroups.com > To:WanderlodgeForum@yahoogroups.com > Received from Internet: > > > > We are back from a 3500 mile trip. Coach worked fine for the most > part. I am learning a lot about these birds. Two things happened and > I need advice. I will check out the database, but wanted to get the > groups advice. > 1. We had our left tag tire blow. It damaged the shore power box. > All hookups seem to work, but the lock disappeared and the door will > not close. The compartment is pretty banged up. Anyone know of a > place for a salvage or new one? > 2. We went thru a severe wind storm in Wyoming. The shrouds for the > middle ac and dash ac blew off. I was able to get a new shroud for > the middle ac, but wondered about something for the front/dash ac. I > does not work and I notice some have removed them. Any suggestions? > Thanks, > Sid Breese > 85PT40 > St. Joseph, MO > > > > > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > [Non-text portions of this message have been removed] |
06-18-2005, 14:34
Damage
Hi Sid, Glad to hear you are getting to know your bird. Sorry about the
dammage. I would suggest you check the DOT code on ALL of your tires if you haven't already. If your tires are older then 7 years, I would replace them. These tires of our's are made to run 100,000+ miles but only have a life of around 7 years before they start to deteriorate. I have a rotation going with mine. Newest on the steering next on the duels and then the tags. My steering go to the tags and the duels get changed by them selves. About the shrouds, I don't know where you can find the parts but give BB a call and they might be able to direct you to some. You probably have gone up and checked the others. Mine were lose also but I caught them before loosing them. I did find that the sheetmetal screws were stripped. I tapped down the holes with a ball-peen hammer and went to the next larget screw. that seems to have done the trick. Hope you find the parts quickly. I'm still trying to get my basement repaired from the gen. muffler being shuved up into it. The insurance is moving forward slowly, but moving. Good luck again, Paul Williams 88XXV 8V92 stuck here in South Lake Tahoe hehe. [Non-text portions of this message have been removed] |
06-18-2005, 16:23
Damage
part. I am learning a lot about these birds. Two things happened and I need advice. I will check out the database, but wanted to get the groups advice. 1. We had our left tag tire blow. It damaged the shore power box. All hookups seem to work, but the lock disappeared and the door will not close. The compartment is pretty banged up. Anyone know of a place for a salvage or new one? 2. We went thru a severe wind storm in Wyoming. The shrouds for the middle ac and dash ac blew off. I was able to get a new shroud for the middle ac, but wondered about something for the front/dash ac. I does not work and I notice some have removed them. Any suggestions? Thanks, Sid Breese 85PT40 St. Joseph, MO |
06-19-2005, 05:00
Damage
Welcome back Sid, and sorry to hear about your damage.
The service entrance box is available as one piece: door and box are welded to the hinge, I've had the door welded/repaired in the past and it is much less work (hours = $$) to repair in most cases and locks are easily available. The dash A/C shroud might still be available from BB, I saw a new one at HMH in Holland just before last RIV, Ken told me that he had recently ordered it for a customer. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Sidney Breese" <ssbreese@a...> wrote: > We are back from a 3500 mile trip. Coach worked fine for the most > part. I am learning a lot about these birds. Two things happened and > I need advice. I will check out the database, but wanted to get the > groups advice. > 1. We had our left tag tire blow. It damaged the shore power box. > All hookups seem to work, but the lock disappeared and the door will > not close. The compartment is pretty banged up. Anyone know of a > place for a salvage or new one? > 2. We went thru a severe wind storm in Wyoming. The shrouds for the > middle ac and dash ac blew off. I was able to get a new shroud for > the middle ac, but wondered about something for the front/dash ac. I > does not work and I notice some have removed them. Any suggestions? > Thanks, > Sid Breese > 85PT40 > St. Joseph, MO |
