foggy humid wet windows
02-05-2010, 04:41
Can anyone help us? Everytime we hit rain the windshield fogs so badly the coach
is undrivable. We wipe them down, the defroster is on (does not help). Seems the only thing that improves the condition is to turn the airconditioners on all around to a popcicle temperature and freeze but hey the windshield is clear. I cant believe they made the coach to run this way, it must be some settings that we are overlooking. Anyone experience this and find out how to correct it? It is just so annoying and time consuming. Thanks in advance for anything that could help us out, Patty Austin 88 wanderlodge PT40 Tampa FL |
02-05-2010, 04:51
Is your dash air working? The a/c is used with the defroster so if its not working, the defrost won't work as well in humid conditions.
Markus To: WanderlodgeForum@yahoogroups.com From: patty_austin@... Date: Fri, 5 Feb 2010 16:41:01 +0000 Subject: [WanderlodgeForum] foggy humid wet windows
Can anyone help us? Everytime we hit rain the windshield fogs so badly the coach is undrivable. We wipe them down, the defroster is on (does not help). Seems the only thing that improves the condition is to turn the airconditioners on all around to a popcicle temperature and freeze but hey the windshield is clear. I cant believe they made the coach to run this way, it must be some settings that we are overlooking. Anyone experience this and find out how to correct it? It is just so annoying and time consuming.
Thanks in advance for anything that could help us out, Patty Austin 88 wanderlodge PT40 Tampa FL Hotmail: Trusted email with Microsoftâs powerful SPAM protection. Sign up now. |
02-05-2010, 04:59
I have found that when we are in really - Chuck 1982 FC 31SB From: Can anyone help us? Everytime we hit rain the windshield fogs so badly the coach is undrivable. We wipe them down, the defroster is on (does not help). Seems the only thing that improves the condition is to turn the airconditioners on all around to a popcicle temperature and freeze but hey the windshield is clear. I cant believe they made the coach to run this way, it must be some settings that we are overlooking. Anyone experience this and find out how to correct it? It is just so annoying and time consuming. Thanks in advance for anything that could help us out, Patty Austin 88 wanderlodge PT40 |
02-05-2010, 05:06
02-05-2010, 05:09
Markus is asking you the right question. My understanding is that the defrost/defog setting should activate the dash a/c compressor to de-humidify the air.
Elliot 1995 WLWB 40 RARA AVIS NW ILLINOIS -----Original Message-----
From: Markus Meyer To: wanderlodgeforum@yahoogroups.com Sent: Fri, Feb 5, 2010 10:51 am Subject: RE: [WanderlodgeForum] foggy humid wet windows
Markus To: WanderlodgeForum@ From: patty_austin@ Date: Fri, 5 Feb 2010 16:41:01 +0000 Subject: [WanderlodgeForum] foggy humid wet windows
Thanks in advance for anything that could help us out, Patty Austin 88 wanderlodge PT40 Tampa FL Hotmail: Trusted email with Microsoftââ¬â¢s powerful SPAM protection. Sign up now. |
02-05-2010, 05:22
I don't believe that's physically possible on my coach, and I would be surprised
if it were possible on other older coaches. The "dash air" isn't dash here. It is overhead. The defrosters come from the dash heaters. There is no connection between the two. My defrosters do work fairly well. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 2/5/2010 at 12:09 PM Elliot wrote: >Markus is asking you the right question. My understanding is that the >defrost/defog setting should activate the dash a/c compressor to >de-humidify the air. >Elliot >1995 WLWB 40 >RARA AVIS >NW ILLINOIS |
02-05-2010, 05:26
This is an '88 PT and the controls for the dash air and defrost is separate
systems I believe. The common AC/Heat control was not introduced until the '90's Coach's. But I could be mistaken on this point. So warm air inside, glass (inside) cold equals moisture on the inside glass and fog. So if the glass (inside) is warmer than the cold out side, the moisture forms on the out side. I have not thought about this since high school. lol Is the defrost switch on the lower dash with a front heat on/off switch? I know the defrost in my FC barely stems the tide of fog on the drivers side, and not very good until the inside of the windshield warms up. I have helped it out by switching on the Coach air, fan only, on the overhead to assist the air moving. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 12:09 PM 2/5/2010 -0500, you wrote: >Markus is asking you the right question. My understanding is that the >defrost/defog setting should activate the dash a/c compressor to >de-humidify the air. >Elliot >1995 WLWB 40 >RARA AVIS >NW ILLINOIS > > > >-----Original Message----- >From: Markus Meyer >To: wanderlodgeforum@yahoogroups.com >Sent: Fri, Feb 5, 2010 10:51 am >Subject: RE: [WanderlodgeForum] foggy humid wet windows > > >Is your dash air working? The a/c is used with the defroster so if its >not working, the defrost won't work as well in humid conditions. > >Markus > > >---------- >To: WanderlodgeForum@yahoogroups.com >From: patty_austin@... >Date: Fri, 5 Feb 2010 16:41:01 +0000 >Subject: [WanderlodgeForum] foggy humid wet windows > > >Can anyone help us? Everytime we hit rain the windshield fogs so badly the >coach is undrivable. We wipe them down, the defroster is on (does not >help). Seems the only thing that improves the condition is to turn the >airconditioners on all around to a popcicle temperature and freeze but hey >the windshield is clear. I cant believe they made the coach to run this >way, it must be some settings that we are overlooking. Anyone experience >this and find out how to correct it? It is just so annoying and time consuming. > >Thanks in advance for anything that could help us out, >Patty Austin >88 wanderlodge PT40 >Tampa FL > > > |
02-05-2010, 05:50
02-05-2010, 06:28
02-05-2010, 16:52
When our coach gets saturated with humidity we hook up to 50 amps and run the
air conditioners and the heat together for however long it takes, a couple hours at least, better yet on and off for a day or two. The excess coach humidity runs out the AC condensation drains and you are done with if for a while. A leaking heater core usually makes itself known because the coach starts to smell like a radiator. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, Patty Austin > > It is not just the windshield it is the entire coach, all windows become so wet they soak the frames at the bottoms. Does this still sound like a heater core leak? How can i tell the difference? Is the fresh air the vents? > Thanks > > Patty Austin > 88 BB Wanderlodge WBPT40 > Tampa Fl > > --- On Fri, 2/5/10, Chuck Wheeler > > > From: Chuck Wheeler > Subject: RE: [WanderlodgeForum] foggy humid wet windows > To: WanderlodgeForum@yahoogroups.com > Date: Friday, February 5, 2010, 11:59 AM > > > > > > > > > > > > > > > I have found that when we are in really humid weather I have to open the fresh air to the heater to help the defrosters prevent fogging. There is also a possibility that you have a leak in the heater core. This will cause severe fogging. > > > - Chuck Wheeler- > 1982 FC 31SB Fort Worth TX > > > > > From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of patty_austin > Sent: Friday, February 05, 2010 10:41 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] foggy humid wet windows > > > > > > Can anyone help us? Everytime we hit rain the windshield fogs so badly the coach is undrivable. We wipe them down, the defroster is on (does not help). Seems the only thing that improves the condition is to turn the airconditioners on all around to a popcicle temperature and freeze but hey the windshield is clear. I cant believe they made the coach to run this way, it must be some settings that we are overlooking. Anyone experience this and find out how to correct it? It is just so annoying and time consuming. > > Thanks in advance for anything that could help us out, > Patty Austin > 88 wanderlodge PT40 > Tampa FL > |
