Expansion tank for primus heat
03-07-2010, 03:45
one of my expansion tanks recently started leaking, my tanks are the one inlet
and one outlet type, Dupree has the the one inlet with two outlets, after many
phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact
Hank @ 478-6273700 Lee Brown 94 WLWB40
03-07-2010, 05:22
I hope you checked the price before you ordered. When I checked with them some months ago, they were expensive!!
Rick Davis
1993 WBSA
Loudon, TN
Sent: Sun, March 7, 2010 10:45:53 AM
Subject: [WanderlodgeForum] Expansion tank for primus heat
one of my expansion tanks recently started leaking, my tanks are the one inlet and one outlet type, Dupree has the the one inlet with two outlets, after many phone calls I found 2 at Bleakley in Ga. they have one more in stock, contact Hank @ 478-6273700 Lee Brown 94 WLWB40
03-07-2010, 05:38
> Rick Davis
> 1993 WBSA
> Loudon, TN
> they were $75.00 ea, don't see that I had any other choice
Lee Brown, 94WLWB40
> ________________________________
> From: dreamcatcher7300 <bat73@...>
> Â
03-07-2010, 08:15
If you prep the tank properly you can repair it with that hot black radiator
repair compound. I have replaced both of mine long ago but did repair one just
for drill. I still have it and it works fine. Keeping it as a spare.
> Rick Davis
> 1993 WBSA
> Loudon, TN
> Â
03-07-2010, 12:56
Lee
I changed mine to a stainless steel tank when I converted to Webasto, kind of
high priced but has greater capacity than the plastic ones. See this link to
Canton Racing
http://www.cantonracingproducts.com/cgi-...80-20\
2
Steve Quandt
1993 PT-40
Iron Mountain, MI
Winter Marblefalls, TX
--- In WanderlodgeForum@yahoogroups.com, "dreamcatcher7300" <bat73@...> wrote:
03-07-2010, 13:05
I'm going to make one of those with a sight guage in it so I can look between the engine cover louvers and see the level. I have started shopping around for a Webasto system, even though I am going to fix my Primus one more time. Thinking of going to a standard 12 VDC coolant pump for some of the new cars - about $80.00 on e-bay rated for constant service.
Sent: Sun, March 7, 2010 6:56:44 PM
Subject: [WanderlodgeForum] Re: Expansion tank for primus heat
Lee
I changed mine to a stainless steel tank when I converted to Webasto, kind of high priced but has greater capacity than the plastic ones. See this link to Canton Racing http://www.cantonra cingproducts. com/cgi-bin/ commerce. cgi?preadd= action&key= 80-202
Steve Quandt
1993 PT-40
Iron Mountain, MI
--- In "WanderlodgeForum%40yahoogroups.com", "dreamcatcher7300" <bat73@...> wrote:
03-07-2010, 14:34
How can you access the take to remove it? My tank has a minor
leak.
Bill
1983 PT 35
PC FL
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of SteveQ
Sent: Sunday, March 07, 2010 6:57 PM
Lee
Canton Racing http://www.cantonracingproducts.com/cgi-...key=80-202
Steve Quandt
1993 PT-40
Iron Mountain, MI
