Flourescent light issue
03-16-2010, 21:21
I have an issue with the front interior flourescent lighting on an '86 PT40.
There are three switches over the entry door that control the flourescent lights in the forward area of my bus.(Over the sofa, and side mini-desk salon area). These lights will not work for long periods of time at all, then suddenly work fine for a long period, then back again to inoperative. I'm trying to determine if they all run off a SINGLE ballast. If so, that is probably my problem, if they're all independantly ballasted ... then I have an intermittent short of some sort to run down. The exterior light that runs off the same power loop works fine all the time, but those are incandescent so .... I've discovered many time that a simple ground issue kills lights. Anyone dealt with the ballasts in this part of the bus ? One ? Three ? Where is it ... and what contemporary model number is it if it's just one ? I'd like to fix it the first time I have to tear that open ... |
03-17-2010, 01:04
03-17-2010, 01:23
I had a similar problem in my 85 PT40. It turned out to be a canon connector. The connector is a large (1 1/2 - 2") and can be found by removing the back panels in the overhead cabinets. I found my problem by emptying the passenger side cabinets and removing the panels aft of the mini-desk area. The contacts within the connector become slightly corroded and/or loose. Undo the connector and check the contacts and clean. You may also have to bend a contact or two to make the connection. Hope this helps. Jerry 85 PT40 Sent via BlackBerry from T-Mobile From: "zboy59" Date: Wed, 17 Mar 2010 08:21:32 -0000 To: Subject: [WanderlodgeForum] Flourescent light issue I have an issue with the front interior flourescent lighting on an '86 PT40. There are three switches over the entry door that control the flourescent lights in the forward area of my bus.(Over the sofa, and side mini-desk salon area). These lights will not work for long periods of time at all, then suddenly work fine for a long period, then back again to inoperative. I'm trying to determine if they all run off a SINGLE ballast. If so, that is probably my problem, if they're all independantly ballasted ... then I have an intermittent short of some sort to run down. The exterior light that runs off the same power loop works fine all the time, but those are incandescent so .... I've discovered many time that a simple ground issue kills lights. Anyone dealt with the ballasts in this part of the bus ? One ? Three ? Where is it ... and what contemporary model number is it if it's just one ? I'd like to fix it the first time I have to tear that open ... |
03-17-2010, 06:53
one ballast for each light
Stephen 97 BMC 35 77 fc for sale --- In WanderlodgeForum@yahoogroups.com, "zboy59" > > I have an issue with the front interior flourescent lighting on an '86 PT40. > > There are three switches over the entry door that control the flourescent lights in the forward area of my bus.(Over the sofa, and side mini-desk salon area). > > These lights will not work for long periods of time at all, then suddenly work fine for a long period, then back again to inoperative. > > I'm trying to determine if they all run off a SINGLE ballast. If so, that is probably my problem, if they're all independantly ballasted ... then I have an intermittent short of some sort to run down. > > The exterior light that runs off the same power loop works fine all the time, but those are incandescent so .... > > I've discovered many time that a simple ground issue kills lights. > > Anyone dealt with the ballasts in this part of the bus ? One ? Three ? > > Where is it ... and what contemporary model number is it if it's just one ? > > I'd like to fix it the first time I have to tear that open ... > |
03-19-2010, 20:11
Thanks guys !
Now that I know it's not the ballast ... I can trace wiring. I've had the switch bank apart and found nothing there. Must be wiring elsewhere. Marty 86 PT40 Kalamazoo --- In WanderlodgeForum@yahoogroups.com, "cape0001" > > one ballast for each light > > Stephen 97 BMC 35 > 77 fc for sale > > --- In WanderlodgeForum@yahoogroups.com, "zboy59" > > > > I have an issue with the front interior flourescent lighting on an '86 PT40. > > > > There are three switches over the entry door that control the flourescent lights in the forward area of my bus.(Over the sofa, and side mini-desk salon area). > > > > These lights will not work for long periods of time at all, then suddenly work fine for a long period, then back again to inoperative. > > > > I'm trying to determine if they all run off a SINGLE ballast. If so, that is probably my problem, if they're all independantly ballasted ... then I have an intermittent short of some sort to run down. > > > > The exterior light that runs off the same power loop works fine all the time, but those are incandescent so .... > > > > I've discovered many time that a simple ground issue kills lights. > > > > Anyone dealt with the ballasts in this part of the bus ? One ? Three ? > > > > Where is it ... and what contemporary model number is it if it's just one ? > > > > I'd like to fix it the first time I have to tear that open ... > > > |
04-04-2010, 05:33
