air steps
03-28-2010, 06:18
air steps
Hi,
I have not posted here before,I am working with a air step and my Question is, in using the schematic supplied in this forums files (see http://autos.groups.yahoo.com/group/Wand...ir%20Step/ file). Is the door switch open or closed when the door is open and the micro switches nc or no when no pressure is applied to the switch? |
03-28-2010, 10:01
air steps
Please read the forum rules. We would be glad to help you, but we need your
name, location and coach model with every post. Thank you, R.E. Marabito, Dallas, TX 92WB40 Forum Moderator --- In WanderlodgeForum@yahoogroups.com, "pmh_mts" > > Hi, > I have not posted here before,I am working with a air step and my Question is, in using the schematic supplied in this forums files (see http://autos.groups.yahoo.com/group/Wand...ir%20Step/ > file). Is the door switch open or closed when the door is open and the micro switches nc or no when no pressure is applied to the switch? > |
03-28-2010, 10:42
air steps
Paul Hess
Midway Truck Service bethel,pa repair tech for '86 pt40 > Hi, > > I have not posted here before,I am working with a air step and my Question is, in using the schematic supplied in this forums files (see http://autos.groups.yahoo.com/group/Wand...ir%20Step/ > > file). Is the door switch open or closed when the door is open and the micro switches nc or no when no pressure is applied to the switch? --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Please read the forum rules. We would be glad to help you, but we need your name, location and coach model with every post. > > Thank you, > > R.E. Marabito, Dallas, TX 92WB40 > Forum Moderator > > --- In WanderlodgeForum@yahoogroups.com, "pmh_mts" > > > > > > |
03-28-2010, 13:49
air steps
Hi Paul
I have to take an educated stab at this with out much experience ,but the door jamb switch should be in contact when the door is open and likewise with the micro switches.
My therory on this is the switches are controlled by a master step switch on the dash or by the door.
I hope I am not leading you astray,but that is how it is on my coach.
Fred & Jeanne Hulse
