New AGM Batteries....RC7 settings
04-02-2010, 06:40
We had Batteries Plus, (Bandera Rd) of San Antonio, come out and install 6 new
Concorde Lifeline AGMs (4DA). They did a great job at a fair price and the batteries are working great. This is our 2nd set of Concordes. The 1st set lasted nearly 7 yrs and all things considered, I think I could have gotten 10 yrs out of them if I had turned off the chargers more often while parked. Anyway, I have the original Trace 3000 watt inverter/chargers and they do seem to be functioning properly. I want to be sure that the inverters are (programmed with the Trace RC7 remote) properly programmed so I got out the Trace manual and of course with my meager electrical skills I am now a bit confused. I don't undestand how to set it for battery capacity. There are 6 options. The 1rst is Auto, then it goes from 125 amp hrs to 250 amp hrs and in steps up to 1000 amp hrs. Let's see, I have 6 batteries rated at 210 amp hrs at a 20 hr rate: 6 x 210 = 1260 amp hrs. So I set it at the max setting of 1000amp hrs... or should I be setting it at the 250 amp hrs setting? Thanks Ron & Ruth 2000 LXI marking time in San Antonio |
04-02-2010, 11:23
Hi Ron
My theory is that your charger doesn't know how many batteries you have and needs to know what the amp hrs you have collectively.
Fred & Jeanne Hulse
04-05-2010, 07:36
Thanks for the input Fred. I'm using the maximum setting now and will go to the
auto setting after cycling another 15 or so times. I also checked with Concorde. No surprise, they don't make my inverter so they couldn't stick their neck out and make any suggestions on configuring it. However, the rep did give me a handy formula for computing charging time based upon depth of discharge, etc. Plugging in the numbers, I was amazed to learn that it takes about 31 hrs to fully charge these 6 AGMs with our Trace Inverter/Chargers i.e., when the batteries are down around 50%. Also, when the charging current has dropped down to around 12 amp, the batteries are full and you can turn off the chargers. Another day and no alzheimers, Hmmm Ron & Ruth 2000 LXI marking time in San Antonio --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > > Hi Ron > My theory is that your charger doesn't know how many batteries you have and needs to know what the amp hrs you have collectively. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > |
04-11-2010, 01:09
