location of center AC drain tube on 2000 LXI
04-06-2010, 07:18
The center AC is leaking over the LR slide. We've ruled out the Front and Rear
ACs and have located and blown out their respective drain tubes. We've blown
the center one but it's still clogged. Now we're trying to get at it from
underneath. Anyone know where it is?
Thanks.
Ron & Ruth
2000 LXI (hussy for sale)
marking time in San Antonio
04-06-2010, 13:55
Found it! It comes out underneath the coach just ahead of the drivers side
tandem. It begins from the center AC, straight West to the driver's side of the
room/slide-out. You have to drop the piano hinged access to get at it, and when
you do you'll see that it runs back to the rear of the slide-out and angles down
unseen from there. (typical BB) @2##**.
FYI, the front AC drain comes out just forward of the LF tire in the wheel well;
the rear AC drain comes out dead center rear engine.
Ron & Ruth
2000 LXI (Hussy for sale)
Marking time in San Antonio
Rear ACs and have located and blown out their respective drain tubes. We've
blown the center one but it's still clogged. Now we're trying to get at it from
> Thanks.
> Ron & Ruth
04-06-2010, 13:57
My center A/C drains on the road side, just at the joint between the front
bumper, where it meets the side body of the bus, about a foot forward of the
drain for the front A/C unit.
Eric Perplies
96 PT-42
currently in Fredericksburg, TX
> Thanks.
> Ron & Ruth
04-07-2010, 08:06
In my opinion they should have continued doing it your way. It makes much more
sense, especially when you have a slide. Murphy's law for sure. The in and out
movement of the slide was going to eventually loosen the fittings and if one
wasn't home one could have a real disaster from all of the potential water
damage. We were lucky. For now, we are sealing our middle AC drain off and
diverting the flow to the roof top.
Thanks for your input.
Ron & Ruth
2000 LXI marking time in San Antonio
> Eric Perplies
> 96 PT-42
> > Thanks.
> > Ron & Ruth
04-08-2010, 04:33
Good luck wiht the water stains
Scooter 2000 LX Ocqueoc, MI
Date: Wed, 7 Apr 2010 20:06:37 +0000
Subject: [WanderlodgeForum] Re: location of center AC drain tube on 2000 LXI
In my opinion they should have continued doing it your way. It makes much more sense, especially when you have a slide. Murphy's law for sure. The in and out movement of the slide was going to eventually loosen the fittings and if one wasn't home one could have a real disaster from all of the potential water damage. We were lucky. For now, we are sealing our middle AC drain off and diverting the flow to the roof top.
Ron & Ruth
--- In "WanderlodgeForum@yahoogroups.com", "Eric" ...> wrote:
> My center A/C drains on the road side, just at the joint between the front bumper, where it meets the side body of the bus, about a foot forward of the drain for the front A/C unit.
> Eric Perplies
> 96 PT-42
> --- In "WanderlodgeForum@yahoogroups.com", "luckyron1" wrote:
> > The center AC is leaking over the LR slide. We've ruled out the Front and Rear ACs and have located and blown out their respective drain tubes. We've blown the center one but it's still clogged. Now we're trying to get at it from underneath. Anyone know where it is?
> > Thanks.
> > Ron & Ruth
